i was trying to run the optifine installer and got the error below:
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Did you already read what google says ?
However, because OptiFine is a Java application, you'll need to get Java to use OptiFine. Go to the **Java SE 16** download page and download the installer for your operating system.26.07.2021
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in reading
