Lycan
March 27, 2023, 2:59pm
1
Non manjaro specific
Each time I do java --version
i got
[0.021s][warning][os,thread] Failed to start thread "GC Thread#0" - pthread_create failed (EINVAL) for attributes: stacksize: 1024k, guardsize: 4k, detached.
[0.021s][error ][gc,task ] Failed to create worker thread
This means I can’t compile anything (maven, gradle).
I have tried reinstalling all java versions, use archlinux-java status
yields
Available Java environments:
java-11-openjdk
java-19-openjdk (default)
java-8-openjdk
switching to the different versions still gave the same result. Please Help!!
Zesko
March 27, 2023, 3:04pm
2
That should be java -version , not java --version
Lycan
March 27, 2023, 3:07pm
4
Same thing
[alex@alex-b450aoruselite ~]$ java --version
[0.002s][warning][os,thread] Failed to start thread "GC Thread#0" - pthread_create failed (EINVAL) for attributes: stacksize: 1024k, guardsize: 4k, detached.
[0.002s][error ][gc,task ] Failed to create worker thread
--------------------------------------------------------------------------------------------------------------------------- 17:02:48
[alex@alex-b450aoruselite ~]$ java -version
maven and gradle fails with the same error, so it is java specific
mvn compile -f "/home/alex/GIT/NMQC/pom.xml" -D scijava.app.directory=/home/alex/Programas/Fiji.app/
Zesko
March 27, 2023, 3:08pm
5
Did you reboot, then the problem still appeared?
Lycan
March 27, 2023, 3:09pm
6
Yep, Rebooted, changed kernel to LTS, nothing works. Its not manjaro or linux specific
Zesko
7
Does other Java version e.g. 8 have the same problem?
Lycan
March 27, 2023, 3:10pm
8
yes, all versions show the same. I tried $ sudo archlinux-java fix
and nothing, still happening the same
Zesko
March 27, 2023, 3:14pm
9
I have no problem with all Java versions. But:
I am not sure if this is related to some bad config for your CPU.
Lycan
10
I just can’t find anything helpful in google. I am not running anything, so the memory error they mention makes no sense to me.
Lycan
March 27, 2023, 3:15pm
11
Everything else works fine. Just java fails
Zesko
12
Can you provide info: inxi -Fazy
Lycan
March 27, 2023, 3:16pm
13
[alex@alex-b450aoruselite ~]$ inxi -Fazy
Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=10db63cd-2294-494c-8b33-b85abc208398 rw quiet nowatchdog
resume=UUID=62aa6a62-d638-465d-b76c-335425b00b70 udev.log_priority=3
amdgpu.dc=0 acpi_enforce_resources=lax amd_pstate=passive audit=0
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F63
date: 01/24/2022
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2166 high: 2200 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2143 2: 2191
3: 2176 4: 2131 5: 2138 6: 2192 7: 2149 8: 2142 9: 2189 10: 2186 11: 2184
12: 2200 13: 2184 14: 2174 15: 2181 16: 2111 bogomips: 118217
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-2 empty: DP-1, DP-3, DVI-D-1, HDMI-A-1 bus-ID: 07:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 45.0 C
Device-2: Sonix USB Camera type: USB driver: uvcvideo bus-ID: 1-5.1:6
chip-ID: 26e0:3c13 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 23.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-2 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.7 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.21-1-MANJARO) direct-render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel bus-ID: 1-5.3:9 v: kernel pcie:
chip-ID: 1b3f:2008 gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16
bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Generalplus Usb Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: DSEA A/S EPOS BTD 800 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.2:8 chip-ID: 1395:0382
class-ID: 0300 serial: <filter>
Device-5: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.4:11 chip-ID: 0c76:1695
class-ID: 0300
Sound API: ALSA v: k6.1.21-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.67 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: pan1 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-7:7 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 3.21 TiB used: 2.06 TiB (64.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZRZ-00Z5HB0
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDT725050VLA360
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: A7EA scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HTS725050A9A364
type: HDD rpm: 7200 serial: <filter> rev: C70E scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Force
size: 29.81 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 229.05 GiB (50.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.79 TiB size: 1.76 TiB (98.37%)
used: 1.33 TiB (75.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 29.3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
ID-2: swap-2 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram0
ID-3: swap-3 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-7: swap-7 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-8: swap-8 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-9: swap-9 type: zram size: 1000.7 MiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-10: swap-10 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram11
ID-14: swap-14 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram12
ID-15: swap-15 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram13
ID-16: swap-16 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram14
ID-17: swap-17 type: zram size: 1000.7 MiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram15
System Temperatures: cpu: 44.5 C mobo: 35.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): cpu: 1397 fan-1: 0 fan-3: 1421 fan-4: 1159 gpu: amdgpu
fan: 1903
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.36 gpu: amdgpu watts: 34.07
Processes: 431 Uptime: 3h 40m wakeups: 0 Memory: 31.27 GiB
used: 7.11 GiB (22.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 10/11/9 clang: 15.0.7
Packages: 2920 pm: dpkg pkgs: 0 pm: pacman pkgs: 2901 libs: 601
tools: pamac,paru pm: flatpak pkgs: 17 pm: snap pkgs: 2 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Zesko
March 27, 2023, 3:20pm
14
Test:
Try disabling CPU hyperthreading and SVM in BIOS, if the problem is gone?
Lycan
March 27, 2023, 3:21pm
15
I can’t restart now. But I will try this later, thanks for the hint!
Are you in testing branch ?
Lycan
March 27, 2023, 4:00pm
17
I’ve tried stable, testing and unstable: no change. There shall be some dirtiness in my system, I just don’t know where
Zesko
March 27, 2023, 4:04pm
18
When did the problem appear? → After switching from the unstable branch to the stable branch it happened?
There sure is something odd:
uname -a
Linux manjaro18 6.1.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023 x86_64 GNU/Linux
java -version
find-the-command: "java" is not found locally, searching in repositories...
find-the-command: /var/cache/pkgfile/*.files are out of date, update? [Y/n] n
find-the-command: "java" may be found in the following packages:
extra/java-runtime-common
extra/jdk8-openjdk
extra/jre-openjdk-headless
extra/jre11-openjdk-headless
extra/jre17-openjdk-headless
extra/jre8-openjdk-headless
community/gephi
java-11-openjdk
java-17-openjdk
java-19-openjdk
java-20-openjdk-bin
java-21-openjdk
java-8-openjdk
No Java environment set as default
A few days ago this was set on my system
How to solve:
sudo archlinux-java set java-19-openjdk
[sudo] Passwort für andreas:
java-11-openjdk
java-17-openjdk
java-20-openjdk-bin
java-21-openjdk
java-8-openjdk
java --version
openjdk 19.0.2 2023-01-17
OpenJDK Runtime Environment (build 19.0.2+7)
OpenJDK 64-Bit Server VM (build 19.0.2+7, mixed mode)
For me it sounds like a wrong memory config somewhere on your system.
Would you try if
java -Djdk.lang.processReaperUseDefaultStackSize=true -version
could be a workaround?
Lycan
March 27, 2023, 4:19pm
21
Nope
[alex@alex-b450aoruselite ~]$ java -Djdk.lang.processReaperUseDefaultStackSize=true -version
