Title is intentionally vague, pertains to issues:
whose solution work. For a brief period after restart (after clearing out .cache and using sudo locale-gen I can copy and paste foreign characters.
But after a short period of time, both break again
. How should I tackle this?
EDIT 0: I think I solved the Dolphin issue, but the Japanese (and foreign characters such as the greek alpha character) still get pasted as ???
System Specs:
Host: MidnightStarSign Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3001 date: 12/04/2020
Info: 16-Core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 rev: 0
cache: L2: 8 MiB
bogomips: 217667
Speed: 3842 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz): 1: 3842
2: 3080 3: 4551 4: 3947 5: 3641 6: 4554 7: 3649 8: 3640 9: 3903 10: 3344 11: 3072
12: 2944 13: 3043 14: 2985 15: 3061 16: 3698 17: 3081 18: 3639 19: 3642 20: 4553
21: 3660 22: 3645 23: 4553 24: 3453 25: 3641 26: 3645 27: 2966 28: 2963 29: 3635
30: 2927 31: 3641 32: 3643
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia v: 465.31
bus-ID: 0b:00.0
Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080 3: 1920x1080
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0e:00.4
Device-3: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2
Device-4: Schiit Audio Schiit Modi 3+ type: USB driver: snd-usb-audio
bus-ID: 3-2:3
Device-5: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-5:3
Device-6: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: d000
bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 3c:7c:3f:a6:c3:22
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: c000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: 24:4b:fe:5b:08:2a
driver: btusb v: 0.8 bus-ID: 3-5.3:6
Local Storage: total: 3.89 TiB used: 1.83 TiB (47.1%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
ID-3: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
ID-4: /dev/sdb type: USB vendor: Generic model: USB3.0 CRW -SD size: 119.08 GiB
ID-5: /dev/sdd type: USB vendor: Samsung model: Flash Drive FIT size: 119.51 GiB
ID-6: /dev/sde type: USB vendor: Toshiba model: TransMemory size: 14.92 GiB
ID-7: /dev/sdf type: USB vendor: SanDisk model: Gaming Xbox 360 size: 7.48 GiB
ID-1: / size: 767 GiB used: 727.85 GiB (94.9%) fs: btrfs dev: /dev/dm-0
mapped: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450
ID-2: /boot/efi size: 511 MiB used: 26.1 MiB (5.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 767 GiB used: 727.85 GiB (94.9%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 64 GiB used: 139.8 MiB (0.2%) dev: /dev/dm-1
mapped: luks-81b2dc57-06f5-4471-b484-77c3a516f307
System Temperatures: cpu: 73.2 C mobo: 0 C gpu: nvidia temp: 41 C
Processes: 962 Uptime: 1d 5h 39m Memory: 62.78 GiB used: 39.66 GiB (63.2%)
Init: systemd Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: 2014 Shell: Bash
v: 5.1.8 inxi: 3.3.04
