I’m using Manjaro-ARM-kde-plasma-rpi4-22.04.img
After installing fcitx-mozc fcitx-im fcitx-configtool,
Create a .xprofile file with the following contents in the home hierarchy.
export LANG=”ja_JP.UTF-8″
export XMODIFIERS=”@im=fcitx”
export XMODIFIER=”@im=fcitx”
export GTK_IM_MODULE=fcitx
export QT_IM_MODULE=fcitx
export DefaultIMModule=fcitx
With the above settings, I have been able to use Japanese input after re-logging in, but the input method does not switch in 22.04.
If you know what has been changed, I would be glad to know.
Thank you in advance.
