hello everyone. i’ve been having the problem for a few weeks that the microphone of my JAbra 510 spider no longer appears in my sound settings and i don’t know why not. unfortunately i’m not an expert with linux but only switched out of sympathy - i urgently need help here. thank you in advance.
Since I have already read a similar thread by JSJ_15 from April and he has posted the information, here is my output from inxi…
inxi -Faxzy ✔
Kernel: 6.1.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0d218fb4-18ec-4775-b315-f5d84d155a8c rw quiet
cryptdevice=UUID=93ce3209-9d45-4029-a341-11b51d505acc:luks-93ce3209-9d45-4029-a341-11b51d505acc
root=/dev/mapper/luks-93ce3209-9d45-4029-a341-11b51d505acc splash
resume=/dev/mapper/luks-4a65bb64-d328-4642-9981-d37a0cef521d
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Laptop System: LENOVO product: 20XF006GGE v: ThinkPad T14s Gen 2a
Mobo: LENOVO model: 20XF006GGE v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20XF_BU_Think_FM_ThinkPad
T14s Gen 2a uuid: <superuser required> UEFI: LENOVO v: R1NET56W (1.26)
date: 02/21/2023
ID-1: BAT0 charge: 57.0 Wh (100.0%) condition: 57.0/57.0 Wh (99.9%)
volts: 17.1 min: 15.4 model: LGC 5B10W13976 type: Li-poly serial: <filter>
status: full cycles: 23
Device-1: hid-34:88:5d:ec:74:a3-battery model: Keyboard K380 serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_4 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3578 high: 3911 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3865 2: 3797
3: 3792 4: 3822 5: 3552 6: 3667 7: 3822 8: 3822 9: 3341 10: 3383 11: 3911
12: 3822 13: 3822 14: 3822 15: 3419 16: 1600 bogomips: 60717
Type: spec_rstack_overflow mitigation: safe RET, no microcode
affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: DP-3,DP-4,eDP-1 empty: DP-1,
DP-2, DP-5, HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 53.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 13d3:5405
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x3240 s-dpi: 96 s-size: 2030x856mm (79.92x33.70")
s-diag: 2203mm (86.74") monitors: <missing: xrandr>
Monitor-1: DP-3 model: ASUS VG289 serial: <filter> built: 2022
res: 3840x2160 dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43")
diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-4 model: ASUS VG289 serial: <filter> built: 2021
Monitor-3: eDP-1 model: AU Optronics 0x573d built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.49 6.1.90-1-MANJARO) device-ID: 1002:1638
memory: 1000 MiB unified: no
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:1638 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: GN Netcom Jabra SPEAK 510 USB driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.3.4:12
chip-ID: 0b0e:0422 class-ID: 0300 serial: <filter>
Device-5: Lenovo ThinkPad USB-C Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1.2:5 chip-ID: 17ef:30b0 class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.90-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u1 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 97.74 GiB (10.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170101 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 920.36 GiB size: 904.84 GiB (98.31%)
used: 97.72 GiB (10.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-93ce3209-9d45-4029-a341-11b51d505acc
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 33.21 GiB used: 26 MiB (0.1%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-4a65bb64-d328-4642-9981-d37a0cef521d
System Temperatures: cpu: 61.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 32 GiB note: est. available: 30.19 GiB used: 13.97 GiB (46.3%)
Processes: 436 Power: uptime: 21h 0m states: freeze,mem,disk
suspend: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.07 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1466 pm: pacman pkgs: 1451 libs: 424 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 15 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh
v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
