Iwlwifi stopped working after a recent update
Hi
I have updated my system a few days ago and since then my wifi has stopped working completely. Appreciate any advice.
inxi -N
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    driver: r8168
lshw -C network
  *-network
       description: Wireless interface
       product: Dual Band Wireless-AC 3168NGW [Stone Peak]
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:29:00.0
       logical name: wlan3
       version: 10
       serial: 9c:29:76:c1:cf:32
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=6.1.44-1-MANJARO firmware=29.198743027.0 3168-29.ucode ip=192.168.1.184 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:81 memory:fc600000-fc601fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:2a:00.0
       logical name: enp42s0
       version: 15
       serial: 2c:f0:5d:8c:97:fa
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.050.03-NAPI duplex=full ip=192.168.1.94 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:82 ioport:f000(size=256) memory:fc504000-fc504fff memory:fc500000-fc503fff
inxi -Fazy
  Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=41842a12-6b2a-4b25-b1af-237f1d287cf0 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
    serial: <filter> UEFI: American Megatrends LLC. v: 2.A0 date: 03/16/2022
  Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
    gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 1x32 MiB
  Speed (MHz): avg: 3125 high: 3700 min/max: 2200/4650 boost: enabled
    base/boost: 3700/4650 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 2200 4: 2200
    5: 3700 6: 2200 7: 3700 8: 2200 9: 2800 10: 3700 11: 3700 12: 3700
    bogomips: 88844
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
    v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 2b:00.0
    chip-ID: 10de:1d01 class-ID: 0300
  Display: server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
    s-diag: 1102mm (43.38")
  Monitor-1: DVI-D-0 pos: left res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 93
  API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce GT
    1030/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
    bus-ID: 2b:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Microsoft LifeChat LX-3000 Headset
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 045e:070f class-ID: 0300
  API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process) with:
    tools: pacat,pactl
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlan3 state: up mac: <filter>
    vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0aa7
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 8 state: down bt-service: enabled,running
  Local Storage: total: 2.73 TiB used: 2.26 TiB (83.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 35.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 280d 22h cycles: 1,823
    read-units: 47,735,807 [24.4 TB] written-units: 78,660,892 [40.2 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: 0001 temp: 32.0 C
  SMART: yes state: enabled health: PASSED on: 6562h+00m+15.664s cycles: 1822
    read: 4.65 TiB written: 6.02 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-1: / raw-size: 931.01 GiB size: 915.33 GiB (98.32%)
    used: 593.67 GiB (64.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p3
    maj-min: 259:2
    used: 6.8 MiB (1.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  System Temperatures: cpu: N/A mobo: N/A
  Fan Speeds (RPM): cpu: 1440 fan-2: 0 fan-3: 1041 fan-4: 991 fan-5: 0
    fan-6: 0 fan-7: 0 fan-8: 0 fan-9: 0 fan-10: 0
  Processes: 334 Uptime: 3d 39m wakeups: 4 Memory: total: 32 GiB
  available: 31.27 GiB used: 9 GiB (28.8%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1946 libs: 498 tools: pamac,yay pm: appimage
  pkgs: 0 pm: flatpak pkgs: 0 Shell: Bash (su) v: 5.1.16 running-in: konsole
  inxi: 3.3.28
System log is full of these
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Queue 11 is active on fifo 1 and stuck for 10000 ms. SW [79, 26] HW [79, 26] FH TRB=0x0c010b05e
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Microcode SW error detected.  Restarting 0x2000000.
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Start IWL Error Log Dump:
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Transport status: 0x0000004A, valid: 6
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Loaded firmware version: 29.198743027.0 3168-29.ucode
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00800634 | trm_hw_status0
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | trm_hw_status1
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00043D6C | branchlink2
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0004AFA2 | interruptlink1
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0004FDAA | interruptlink2
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | data1
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000080 | data2
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x07030000 | data3
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x1BC16396 | beacon time
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0xD46A8C6A | tsf low
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x000000C4 | tsf hi
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | time gp1
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0114D288 | time gp2
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000001 | uCode revision type
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0000001D | uCode version major
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0BD893F3 | uCode version minor
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000220 | hw version
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00C89200 | board version
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0B4F001C | hcmd
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0xA4022002 | isr0
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | isr1
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0000000A | isr2
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0041A8C5 | isr3
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | isr4
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x007301D2 | last cmd Id
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | wait_event
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000094 | l2p_control
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00012030 | l2p_duration
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x0000000F | l2p_mhvalid
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | l2p_addr_match
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000005 | lmpm_pmg_sel
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x14100601 | timestamp
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00346070 | flow_handler
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Fseq Registers:
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_ERROR_CODE
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_TOP_INIT_VERSION
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_CNVIO_INIT_VERSION
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_OTP_VERSION
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_TOP_CONTENT_VERSION
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_ALIVE_TOKEN
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_CNVI_ID
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | FSEQ_CNVR_ID
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | CNVI_AUX_MISC_CHIP
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | CNVR_AUX_MISC_CHIP
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Aug 14 21:42:11 mrr kernel: iwlwifi 0000:29:00.0: Collecting data: trigger 2 fired.
have a look at; [SOLVED] iwlwifi: Microcode SW error detected. Restarting 0x0. (Page 2) / Kernel & Hardware / Arch Linux Forums
I was going to mention the iwlmvm module.
Which is where intel wifi power management is. A separate module? yes.
It seems it is stated somewhere in that thread.
But a few things to mention - theres a lot of stuff posted there that is either old … or likely too extreme for your issue.
See this related thread:
So … if I were you I would start with the antenna option:
(not disabling modern/faster standards)
/etc/modprobe.d/iwlwifi.conf
options iwlwifi 11n_disable=8 # enable antenna aggregation
And if thats not good then also check disabling power saving:
/etc/modprobe.d/iwlmvm.conf
options iwlmvm power_scheme=1 # disable power saving, default=2
And then if it still doesnt work … you can try a few other things.
Unfortunately neither of these options had any effect.
While trying the suggestions from the post linked above at some point I was able to get a stable connection but that only lasted until restart and I’m not quite sure what exactly I’ve done to achieve this.
I’m not sure either. If it was options in the configuration files … then it should persist across reboots.
I suspect it was due to the fact I reloaded the module. I have tried it a few times since later and it worked, although the speed was pretty bad.
So unloading and reloading the module works?
Have you reset the options and/or removed the files?
( remember a bunch of the options in the other thread are disabling modern standrds, so it means only using the slower a/b/g … 2.4 ghz and an absolute maximum of 54 mb )
Also … I guess I could mention you can pass options while loading the module;
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi 11n_disable=8
I’d say sometimes? Not sure. And the speed is still not great (I’ve previously asked about the speed issue on this forum as well)
Oh that’s nice, I didn’t know that.
I found a partial workaround: disabling network stack in BIOS + setting 11n_disable=1 prevents the driver from crashing, but the speed is slow - about 20Mbit/s while it should be ~150. Oh well, better than nothing.
The maximum with N disabled is about 20-22-24Mbps, so it is expected. (802.11G: 54Mbps for both directions with some overhehead included)
