Iwlwifi Failed to run INIT ucode: -110
Hello,
My lwlwifi suddently stopped running with error “Failed to run INIT ucode: -110”
I tried most of the solutions found on this forum, as well as arch, ubuntu and linux forum without success…
Machine Info:
Type: Laptop
Model: Dell Latitude 5420
Kernel: 6.1.31-1-MANJARO or 5.15.114-1-MANJARO (tried both)
Wifi hardware : Intel WiFi 6 AX201
$ rfkill list
0: dell-wifi: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: dell-bluetooth: Bluetooth
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
$ sudo dmesg | grep iwlwifi
[    4.040181] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    4.062245] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    4.062261] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    4.062527] iwlwifi 0000:00:14.3: loaded firmware version 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode op_mode iwlmvm
[    4.418169] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    5.457223] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x5962, CPU2 Status: 0x3
[    5.457344] iwlwifi 0000:00:14.3: UMAC PC: 0x8047430e
[    5.457449] iwlwifi 0000:00:14.3: LMAC PC: 0x14cfc
[    5.457452] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    5.458559] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[    5.458561] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[    5.458562] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
[    5.458563] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[    5.458565] iwlwifi 0000:00:14.3: 0x00000000 | branchlink2
[    5.458566] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink1
[    5.458566] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[    5.458567] iwlwifi 0000:00:14.3: 0x00000000 | data1
[    5.458568] iwlwifi 0000:00:14.3: 0x00000000 | data2
[    5.458569] iwlwifi 0000:00:14.3: 0x00000000 | data3
[    5.458570] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[    5.458571] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[    5.458572] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[    5.458572] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[    5.458573] iwlwifi 0000:00:14.3: 0x00000000 | time gp2
[    5.458574] iwlwifi 0000:00:14.3: 0x00000000 | uCode revision type
[    5.458575] iwlwifi 0000:00:14.3: 0x00000000 | uCode version major
[    5.458576] iwlwifi 0000:00:14.3: 0x00000000 | uCode version minor
[    5.458577] iwlwifi 0000:00:14.3: 0x00000000 | hw version
[    5.458578] iwlwifi 0000:00:14.3: 0x00000000 | board version
[    5.458579] iwlwifi 0000:00:14.3: 0x00000000 | hcmd
[    5.458580] iwlwifi 0000:00:14.3: 0x00000000 | isr0
[    5.458581] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[    5.458582] iwlwifi 0000:00:14.3: 0x00000000 | isr2
[    5.458583] iwlwifi 0000:00:14.3: 0x00000000 | isr3
[    5.458584] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[    5.458585] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
[    5.458586] iwlwifi 0000:00:14.3: 0x00000000 | wait_event
[    5.458587] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[    5.458588] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[    5.458589] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[    5.458590] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[    5.458591] iwlwifi 0000:00:14.3: 0x00000000 | lmpm_pmg_sel
[    5.458592] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[    5.458593] iwlwifi 0000:00:14.3: 0x00000000 | flow_handler
[    5.458648] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    5.458649] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 7
[    5.458650] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[    5.458652] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[    5.458653] iwlwifi 0000:00:14.3: 0x80455AE6 | umac branchlink2
[    5.458654] iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink1
[    5.458655] iwlwifi 0000:00:14.3: 0xC008417A | umac interruptlink2
[    5.458656] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[    5.458657] iwlwifi 0000:00:14.3: 0xC008417A | umac data2
[    5.458659] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[    5.458660] iwlwifi 0000:00:14.3: 0x00000042 | umac major
[    5.458661] iwlwifi 0000:00:14.3: 0xF1C864E0 | umac minor
[    5.458662] iwlwifi 0000:00:14.3: 0x000FA6D7 | frame pointer
[    5.458663] iwlwifi 0000:00:14.3: 0xC0887EFC | stack pointer
[    5.458664] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[    5.458665] iwlwifi 0000:00:14.3: 0x00000004 | isr status reg
[    5.458774] iwlwifi 0000:00:14.3: IML/ROM dump:
[    5.458775] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
[    5.458784] iwlwifi 0000:00:14.3: 0x00005962 | IML/ROM data1
[    5.458793] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[    5.458799] iwlwifi 0000:00:14.3: Fseq Registers:
[    5.458802] iwlwifi 0000:00:14.3: 0x20000000 | FSEQ_ERROR_CODE
[    5.458805] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[    5.458839] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[    5.458866] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[    5.458892] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[    5.458918] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[    5.458944] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[    5.458971] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[    5.458997] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[    5.459017] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[    5.459050] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    5.459077] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    5.459102] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[    5.459103] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    6.493459] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[    6.505965] iwlwifi 0000:00:14.3: retry init count 0
[    6.511950] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    7.537449] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x5a9f, CPU2 Status: 0x3
[    7.537578] iwlwifi 0000:00:14.3: UMAC PC: 0x8047430e
[    7.537682] iwlwifi 0000:00:14.3: LMAC PC: 0x14cfc
[    7.537685] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    7.540020] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[    7.540022] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[    7.540024] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
[    7.540025] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[    7.540026] iwlwifi 0000:00:14.3: 0x00000000 | branchlink2
[    7.540027] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink1
[    7.540028] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[    7.540028] iwlwifi 0000:00:14.3: 0x00000000 | data1
[    7.540029] iwlwifi 0000:00:14.3: 0x00000000 | data2
[    7.540030] iwlwifi 0000:00:14.3: 0x00000000 | data3
[    7.540031] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[    7.540032] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[    7.540033] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[    7.540034] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[    7.540035] iwlwifi 0000:00:14.3: 0x00000000 | time gp2
[    7.540036] iwlwifi 0000:00:14.3: 0x00000000 | uCode revision type
[    7.540037] iwlwifi 0000:00:14.3: 0x00000000 | uCode version major
[    7.540038] iwlwifi 0000:00:14.3: 0x00000000 | uCode version minor
[    7.540039] iwlwifi 0000:00:14.3: 0x00000000 | hw version
[    7.540040] iwlwifi 0000:00:14.3: 0x00000000 | board version
[    7.540041] iwlwifi 0000:00:14.3: 0x00000000 | hcmd
[    7.540042] iwlwifi 0000:00:14.3: 0x00000000 | isr0
[    7.540043] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[    7.540044] iwlwifi 0000:00:14.3: 0x00000000 | isr2
[    7.540044] iwlwifi 0000:00:14.3: 0x00000000 | isr3
[    7.540045] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[    7.540046] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
[    7.540047] iwlwifi 0000:00:14.3: 0x00000000 | wait_event
[    7.540048] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[    7.540049] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[    7.540050] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[    7.540051] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[    7.540052] iwlwifi 0000:00:14.3: 0x00000000 | lmpm_pmg_sel
[    7.540053] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[    7.540054] iwlwifi 0000:00:14.3: 0x00000000 | flow_handler
[    7.540557] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    7.540559] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 7
[    7.540561] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[    7.540563] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[    7.540564] iwlwifi 0000:00:14.3: 0x80455AE6 | umac branchlink2
[    7.540565] iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink1
[    7.540566] iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink2
[    7.540567] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[    7.540568] iwlwifi 0000:00:14.3: 0x8047430E | umac data2
[    7.540569] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[    7.540570] iwlwifi 0000:00:14.3: 0x00000042 | umac major
[    7.540571] iwlwifi 0000:00:14.3: 0xF1C864E0 | umac minor
[    7.540572] iwlwifi 0000:00:14.3: 0x000F74F0 | frame pointer
[    7.540574] iwlwifi 0000:00:14.3: 0xC0886260 | stack pointer
[    7.540575] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[    7.540576] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[    7.540694] iwlwifi 0000:00:14.3: IML/ROM dump:
[    7.540695] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
[    7.540799] iwlwifi 0000:00:14.3: 0x00005A9F | IML/ROM data1
[    7.540904] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[    7.540956] iwlwifi 0000:00:14.3: Fseq Registers:
[    7.540983] iwlwifi 0000:00:14.3: 0x60000041 | FSEQ_ERROR_CODE
[    7.541009] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[    7.541035] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[    7.541061] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[    7.541087] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[    7.541114] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[    7.541140] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[    7.541166] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[    7.541192] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[    7.541221] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[    7.541247] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    7.541273] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    7.541297] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[    7.541299] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   17.094843] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[   17.107313] iwlwifi 0000:00:14.3: retry init count 1
[   17.111690] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[   18.310812] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x6382, CPU2 Status: 0x3
[   18.310941] iwlwifi 0000:00:14.3: UMAC PC: 0x8047430e
[   18.310966] iwlwifi 0000:00:14.3: LMAC PC: 0x14cfc
[   18.310970] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   18.313343] iwlwifi 0000:00:14.3: Loaded firmware version: 66.f1c864e0.0 QuZ-a0-hr-b0-66.ucode
[   18.313347] iwlwifi 0000:00:14.3: 0x00000000 | ADVANCED_SYSASSERT
[   18.313351] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status0
[   18.313353] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[   18.313355] iwlwifi 0000:00:14.3: 0x00000000 | branchlink2
[   18.313356] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink1
[   18.313358] iwlwifi 0000:00:14.3: 0x00000000 | interruptlink2
[   18.313360] iwlwifi 0000:00:14.3: 0x00000000 | data1
[   18.313362] iwlwifi 0000:00:14.3: 0x00000000 | data2
[   18.313363] iwlwifi 0000:00:14.3: 0x00000000 | data3
[   18.313365] iwlwifi 0000:00:14.3: 0x00000000 | beacon time
[   18.313367] iwlwifi 0000:00:14.3: 0x00000000 | tsf low
[   18.313369] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[   18.313370] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[   18.313372] iwlwifi 0000:00:14.3: 0x00000000 | time gp2
[   18.313374] iwlwifi 0000:00:14.3: 0x00000000 | uCode revision type
[   18.313376] iwlwifi 0000:00:14.3: 0x00000000 | uCode version major
[   18.313377] iwlwifi 0000:00:14.3: 0x00000000 | uCode version minor
[   18.313379] iwlwifi 0000:00:14.3: 0x00000000 | hw version
[   18.313381] iwlwifi 0000:00:14.3: 0x00000000 | board version
[   18.313383] iwlwifi 0000:00:14.3: 0x00000000 | hcmd
[   18.313384] iwlwifi 0000:00:14.3: 0x00000000 | isr0
[   18.313386] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[   18.313388] iwlwifi 0000:00:14.3: 0x00000000 | isr2
[   18.313389] iwlwifi 0000:00:14.3: 0x00000000 | isr3
[   18.313391] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[   18.313393] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id
[   18.313394] iwlwifi 0000:00:14.3: 0x00000000 | wait_event
[   18.313396] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[   18.313398] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration
[   18.313400] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid
[   18.313401] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[   18.313403] iwlwifi 0000:00:14.3: 0x00000000 | lmpm_pmg_sel
[   18.313405] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[   18.313407] iwlwifi 0000:00:14.3: 0x00000000 | flow_handler
[   18.313920] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[   18.313923] iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 7
[   18.313926] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[   18.313928] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[   18.313930] iwlwifi 0000:00:14.3: 0x80455AE6 | umac branchlink2
[   18.313932] iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink1
[   18.313934] iwlwifi 0000:00:14.3: 0x8047430E | umac interruptlink2
[   18.313936] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[   18.313938] iwlwifi 0000:00:14.3: 0x8047430E | umac data2
[   18.313940] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[   18.313942] iwlwifi 0000:00:14.3: 0x00000042 | umac major
[   18.313944] iwlwifi 0000:00:14.3: 0xF1C864E0 | umac minor
[   18.313945] iwlwifi 0000:00:14.3: 0x000F9279 | frame pointer
[   18.313947] iwlwifi 0000:00:14.3: 0xC0886260 | stack pointer
[   18.313949] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[   18.313951] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[   18.314070] iwlwifi 0000:00:14.3: IML/ROM dump:
[   18.314071] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
[   18.314095] iwlwifi 0000:00:14.3: 0x00006382 | IML/ROM data1
[   18.314209] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[   18.314261] iwlwifi 0000:00:14.3: Fseq Registers:
[   18.314288] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[   18.314315] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[   18.314342] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[   18.314381] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[   18.314419] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[   18.314457] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[   18.314491] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[   18.314519] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[   18.314554] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[   18.314594] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[   18.314634] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   18.314674] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   18.314701] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[   18.314705] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   23.322667] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
[   23.335422] iwlwifi 0000:00:14.3: retry init count 2
  Kernel: 5.15.114-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=5c755150-dff7-43e8-886a-910abd75fab1 rw quiet apparmor=1
    security=apparmor resume=UUID=5b38cced-151e-42c2-9621-b1f387be5d16
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Dell product: Latitude 5420 v: N/A
  Mobo: Dell model: 054CCV v: A00 serial: <superuser required> UEFI: Dell
    v: 1.8.0 date: 06/08/2021
  ID-1: BAT0 charge: 47.0 Wh (100.0%) condition: 47.0/62.4 Wh (75.3%)
    volts: 16.9 min: 15.2 model: SWD-ATL4.175 DELL 1K2CF14 type: Li-poly
    serial: <filter> status: full
  System RAM: available: 30.93 GiB used: 4.21 GiB (13.6%)
  Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 1333 high: 2196 min/max: 400/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1358 2: 1074 3: 1371
    4: 2196 5: 956 6: 1470 7: 1285 8: 955 bogomips: 28888
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3
    chip-ID: 1bcf:28cc class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: xfwm v: 4.18.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x068d built: 2020 res: 1920x1080 hz: 60
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k5.15.114-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fb class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 736.09 GiB (77.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41001131 temp: 39.9 C
    scheme: GPT
  ID-1: / raw-size: 919.54 GiB size: 904.03 GiB (98.31%)
    used: 736.08 GiB (81.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 5c755150-dff7-43e8-886a-910abd75fab1
    used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 8835-0F2C
  ID-1: swap-1 type: partition size: 34.03 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 5b38cced-151e-42c2-9621-b1f387be5d16
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Logitech RX1000 Laser Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c046 class-ID: 0301
  Device-2: 3-6:3 info: Sunplus Innovation Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 1bcf:28cc class-ID: 0e02 serial: <filter>
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 255 Uptime: 24m wakeups: 4302 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 2306 libs: 450 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.27
Thanks in advance for any help !
UEFI/BIOS: Fast boot or partially initialization enabled? Disable it.
Thx !
I don’t think fastboot is involved, since I never had windows on my laptop (only manjaro is installed on it).
For partially initialization, I am not sure about what you mean…
Do not confuse fastboot (partial hibernation) in Windows with fastboot (skipping initiation processes) in the BIOS/UEFI. fastboot in the BIOS/UEFI has often different names and options, but does the same. It plays not well with Linux because of how Linux handles drivers.
Okay, now try 6.2 (probably nearing EOL) and 6.3, restart after installation and see how it goes. If you are dual booting Windows make sure fastboot, hibernation, hybrid boot and whatever else is disabled in Windows and Windows is completely shutdown.
Oh ok ! Sorry for the misunderstanding…
Fastboot was indeed activated, but disabling it did not solve the problem…
I also tried to boot an Ubuntu live key and I got the same problem…
Maybe it is a hardware problem…
Last thing I could imagine is that some buggy firmware needs to add PXE boot on the boot list. So check the boot priority, add something like that to the list so that it searches first PXE network boots and then Manjaro. I know that sounds silly, but some UEFI needs this to fully initialize the wifi card. Also sometimes it needs a cold boot, instead of a warm boot (reboot).
Necroposting to help others stumbling to this issue on Google. I had a similar issue, my dmesg log:
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80000400
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_LMAC1_PD_NOTIFICATION: 0x1f
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: HPM_SECONDARY_DEVICE_STATE: 0x42
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_ADDR: 0x0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WFPM_MAC_OTP_CFG7_DATA: 0x0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0xd05c18
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd05c1c
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: 1485243924
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 89.7207fc64.0 so-a0-gf-a0-89.ucode
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x973502D5 | ADVANCED_SYSASSERT
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x70245D79 | trm_hw_status0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xE2A640BA | trm_hw_status1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xF52305B3 | branchlink2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xEB180FF3 | interruptlink1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xFA27186C | interruptlink2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x57710CFE | data1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xB293491C | data2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x858607AD | data3
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xA06B3605 | beacon time
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xFCDA8CCD | tsf low
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xD102DBEF | tsf hi
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x8A26A058 | time gp1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x9E2BE485 | time gp2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xBB5E9854 | uCode revision type
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x99DB095E | uCode version major
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xB2CDD84C | uCode version minor
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x327F57F9 | hw version
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xDBA3F7C0 | board version
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xD0EFEB6E | hcmd
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x38D8467B | isr0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x1727DD48 | isr1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x950FB6FA | isr2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x30D220D5 | isr3
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x3653D71F | isr4
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x7057D26C | last cmd Id
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x545612F8 | wait_event
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xFD570294 | l2p_control
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x39C992BA | l2p_duration
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x365B6B6B | l2p_mhvalid
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x2855767B | l2p_addr_match
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x4CE3E3EE | lmpm_pmg_sel
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x5628EC6F | timestamp
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x3112C9A9 | flow_handler
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Transport status: 0x00000042, valid: -1092791669
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xC8C00B83 | ADVANCED_SYSASSERT
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x696EEDE8 | umac branchlink1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x81D3AD74 | umac branchlink2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xB7B5D601 | umac interruptlink1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x54F5B576 | umac interruptlink2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xF4E733E4 | umac data1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xA3EC38BE | umac data2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x77C5166F | umac data3
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xE38FF59D | umac major
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x82639F59 | umac minor
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xCCAFAF59 | frame pointer
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xFB21282B | stack pointer
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xD193208E | last host cmd
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x79BB3228 | isr status reg
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: IML/ROM dump:
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x0310 | IML/ROM SYSASSERT
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x03100000 | IML/ROM error/state
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x00000000 | IML/ROM data1
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x80000400 | IML/ROM WFPM_AUTH_KEY_0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Fseq Registers:
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x699283D8 | FSEQ_ERROR_CODE
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x46EFE7C5 | FSEQ_TOP_INIT_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x4DCAB215 | FSEQ_CNVIO_INIT_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xCB31C96A | FSEQ_OTP_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xFFC8F5DB | FSEQ_TOP_CONTENT_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xAEEE07B9 | FSEQ_ALIVE_TOKEN
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x3C959710 | FSEQ_CNVI_ID
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xBFDE15E7 | FSEQ_CNVR_ID
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_AUX_MISC_CHIP
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xBB861FEC | FSEQ_PREV_CNVIO_INIT_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xC87C2D6E | FSEQ_WIFI_FSEQ_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0x7AC9ABD4 | FSEQ_BT_FSEQ_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: 0xC8669FAB | FSEQ_CLASS_TP_VERSION
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0xc00c06d2
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0x0
jan 12 09:28:08 e kernel: iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
jan 12 09:28:09 e kernel: iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
jan 12 09:28:09 e kernel: iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
on Arch Linux on Lenovo Yoga 7 laptop. A reboot didn’t fix the issue. The issue was fixed by booting Windows 11 once and then rebooting again into Arch Linux.
