I am trying to follow a guide and there is a step that I need to know if my system uses GRUB
What is the proper way to check that?
Yes, GRUB is used by default.
What guide? Not all of them are written properly and may or may not apply to Arch-based distros like Manjaro.
You can check if it’s installed by searching your installed programs via Add/Remove Software in your application menu or from the terminal:
With pamac
pamac search --installed grub
Or pacman
pacman -Qs grub
See:
ty bro
the guide its on youtube GPU Pass-through On Linux/Virt-Manager
but i need 2 gpu so i wont be able too
i was trying to eliminate the windows partition cause i only use windows to play on bluestacks(android emulator)
