I use the 5.13.9 version of the kernel, and SR-IOV support has been enabled in the BIOS.
echo 4 > /sys/class/nvme/nvme0/device/sriov_numvfs
dmesg | grep -E 'nvme|pci'
[ 154.374020] pci 0000:01:00.2: [144d:a824] type 00 class 0x010802
[ 154.374261] pci 0000:01:00.2: Adding to iommu group 32
[ 154.374455] nvme nvme1: pci function 0000:01:00.2
[ 154.374486] pci 0000:01:00.3: [144d:a824] type 00 class 0x010802
[ 154.374676] pci 0000:01:00.3: Adding to iommu group 33
[ 154.374696] nvme 0000:01:00.2: enabling device (0000 -> 0002)
[ 154.374785] nvme nvme2: pci function 0000:01:00.3
[ 154.374826] nvme 0000:01:00.3: enabling device (0000 -> 0002)
[ 154.374855] pci 0000:01:00.4: [144d:a824] type 00 class 0x010802
[ 154.375232] pci 0000:01:00.4: Adding to iommu group 34
[ 154.375351] nvme nvme3: pci function 0000:01:00.4
[ 154.375379] pci 0000:01:00.5: [144d:a824] type 00 class 0x010802
[ 154.375387] nvme 0000:01:00.4: enabling device (0000 -> 0002)
[ 154.375683] pci 0000:01:00.5: Adding to iommu group 35
[ 154.375785] nvme nvme4: pci function 0000:01:00.5
[ 154.375798] nvme 0000:01:00.5: enabling device (0000 -> 0002)
[ 184.877170] nvme nvme1: Device not ready; aborting initialisation, CSTS=0x2
[ 184.877171] nvme nvme4: Device not ready; aborting initialisation, CSTS=0x2
[ 184.877173] nvme nvme3: Device not ready; aborting initialisation, CSTS=0x2
[ 184.877176] nvme nvme1: Removing after probe failure status: -19
[ 184.877177] nvme nvme4: Removing after probe failure status: -19
[ 184.877179] nvme nvme3: Removing after probe failure status: -19
[ 184.879156] nvme nvme2: Device not ready; aborting initialisation, CSTS=0x2
[ 184.879160] nvme nvme2: Removing after probe failure status: -19
Is this a similar bug?
https://www.mail-archive.com/qemu-block@nongnu.org/msg80546.html
