0:05:00] Still working on:
[0:05:00] src/third_party/electron_node
[0:05:10] Still working on:
[0:05:10] src/third_party/electron_node
[0:05:20] Still working on:
[0:05:20] src/third_party/electron_node
[0:05:30] Still working on:
[0:05:30] src/third_party/electron_node
[0:05:40] Still working on:
[0:05:40] src/third_party/electron_node
[0:05:50] Still working on:
[0:05:50] src/third_party/electron_node
[0:06:00] Still working on:
[0:06:00] src/third_party/electron_node
[0:06:10] Still working on:
[0:06:10] src/third_party/electron_node
[0:06:12] Still working on:
[0:06:12] src/third_party/electron_node
Syncing projects: 100% (7/7), done.
/home/euki/.cache/yay/electron24/PKGBUILD: Zeile 182: patch: Kommando nicht gefunden.
==> FEHLER: Ein Fehler geschah in prepare().
Breche ab...
-> error making: electron24
0:04:50] Still working on:
[0:04:50] src/third_party/electron_node
[0:05:00] Still working on:
patching file patches/chromium/feat_add_data_parameter_to_processsingleton.patch
patching file shell/browser/api/electron_api_app.cc
Hunk #1 succeeded at 512 (offset -11 lines).
Hunk #2 succeeded at 1091 (offset -11 lines).
patching file shell/browser/api/electron_api_app.h
Running hooks...
/home/euki/.cache/yay/electron24/PKGBUILD: Zeile 187: src/build/landmines.py: Datei oder Verzeichnis nicht gefunden
Breche ab...
Open the PKGBUILD in an editor and look at the line numbers. Either way, this is AUR stuff and doesn’t belong on this thread. As you’ve been told already, open a new thread.
Hint: Prefix your command with LANG=C, so that your error messages will be in English.
Either find a fix yourself or ask maintainer. Btw, you should always read AUR comments before commenting here. Because same thing was already mentioned there 3 times.
Contact the maintainer and let them know that the package won’t build due to missing files/directories. As you can see here — scroll down a bit — others have reported the issue as well.
This here is the content of the PKGBUILD. As you can see, line 187 corresponds to the error message you’re getting, which is that the file landmines.py cannot be found, and apparently there’s another missing file as well, starch.py.
