Issues with Vulkan and my PC is freezing
Hello.
I’m a newbie to this forum and I couldn’t find a solution to this
I’ve encountered the problem that my Arch system is running down below the usual refresh rate. Also I can’t get Vulkaninfo to work at some point. I think my drivers are up-to-date, but something is really wrong.
Here it is:
vulkaninfo
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Received return code -3 from call to vkCreateInstance in ICD /usr/lib/amdvlk64.so. Skipping this driver.
amdgpu: DRM version is 3.40.0, but this driver is only compatible with 3.42.0 (kernel 5.15+) or later.
WARNING: [../mesa-25.1.4/src/amd/vulkan/radv_physical_device.c:2085] Code 0 : failed to initialize winsys (VK_ERROR_INITIALIZATION_FAILED)
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs: Call to 'vkEnumeratePhysicalDevices' in ICD /usr/lib/libvulkan_radeon.so failed with error code -3
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs:  Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools/vulkaninfo/./vulkaninfo.h:247:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
My PC info
inxi -F
  Host: kumi-81w4 Kernel: 5.10.239-2-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.4.1 Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 81W4 v: IdeaPad 3 15ARE05
    serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: DZCN43WW date: 04/28/2022
  ID-1: BAT0 charge: 23.4 Wh (78.5%) condition: 29.8/35.0 Wh (85.1%)
    volts: 7.9 min: 7.5
  Info: quad core model: AMD Ryzen 3 4300U with Radeon Graphics bits: 64
    type: MCP cache: L2: 2 MiB
  Speed (MHz): avg: 2251 min/max: 1400/2700 cores: 1: 2251 2: 2251 3: 2251
    4: 2251
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon gpu: amdgpu resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,swrast
  API: OpenGL v: 4.5 vendor: mesa v: 25.1.4-arch1.1 renderer: llvmpipe
    (LLVM 20.1.6 256 bits)
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi,radeontop
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
  API: ALSA v: k5.10.239-2-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.5 status: active
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8822ce
  IF: wlp1s0 state: up mac: dc:e9:94:2a:91:23
  Device-1: Realtek Bluetooth Radio driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: N/A
  Local Storage: total: 238.47 GiB used: 88.15 GiB (37.0%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ256HAJD-000L2
  ID-1: / size: 115.44 GiB used: 88.12 GiB (76.3%) fs: ext4
    dev: /dev/nvme0n1p5
  ID-2: /boot/efi size: 96 MiB used: 25.6 MiB (26.7%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB note: est. available: 7.2 GiB used: 3.74 GiB (51.9%)
  Processes: 255 Uptime: 23h 30m Shell: Bash inxi: 3.3.38
GPU, drivers and others
inxi -Ga
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 43.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 174f:118d
    class-ID: 0e02 serial: 200901010001
    unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
    display-ID: 0
  Monitor-1: eDP-1 model: LG Display 0x05e5 built: 2018 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 platforms: device: 1 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
    inactive: device-0
  API: OpenGL v: 4.5 vendor: mesa v: 25.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 20.1.6 256 bits)
    device-ID: ffffffff:ffffffff memory: 7.03 GiB unified: yes
    display-ID: :0.0
glxgears
7662 frames in 5.0 seconds = 1532.318 FPS
9532 frames in 5.0 seconds = 1905.708 FPS
9382 frames in 5.0 seconds = 1875.508 FPS
7830 frames in 5.0 seconds = 1565.314 FPS
8817 frames in 5.0 seconds = 1762.693 FPS
8866 frames in 5.0 seconds = 1773.163 FPS
9140 frames in 5.0 seconds = 1827.992 FPS
9017 frames in 5.0 seconds = 1803.319 FPS
9463 frames in 5.0 seconds = 1892.512 FPS
mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
pacman -Qs nvidia
local/egl-gbm 1.1.2.1-1
    The GBM EGL external platform library
local/egl-wayland 4:1.1.19-1
    EGLStream-based Wayland external platform
local/egl-x11 1.0.2-1
    NVIDIA XLib and XCB EGL Platform Library
local/lib32-libvdpau 1.5-3
    Nvidia VDPAU library
local/libvdpau 1.5-3
local/linux-firmware-nvidia 20250613.12fe085f-5
    Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/mhwd-nvidia 575.64-2
    MHWD module-ids for nvidia 575.64
local/mhwd-nvidia-390xx 390.157-21
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-14
    MHWD module-ids for nvidia 470.256.02
local/nvidia-driver-assistant 0.21.57.08-1
    Detect and install the best NVIDIA driver packages for the system
local/nvidia-prime 1.0-5
    NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 575.64.05-1
    NVIDIA drivers utilities
local/xf86-video-nouveau 1.0.18-1 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards
Any input is appreciated :slight_smile:
maybe this is the reason?:
you are using the 5.10 kernel, and you need a newer one… so install the 5.15 and also the 6.1, reboot, and test with both of them…
and you dont have nvidia, so why the nvidia output?
oh yeah, you’re right. It worked like a charm.
Maybe I should observe the output more intently next time… Thank you, nevertheless!
