Issues with the screenshot tool of KDE (spectacle)
I am experiencing issues with the screenshot tool of KDE (spectacle) since a few days:
Mod edit:- To help others fully understand the issue you are facing, please fully describe the problem, rather than post a screenshot.
Does anybody else also have these problems? I can’t find any other reports here, so it might be a Manjaro/ Arch specific issue?
It makes selecting a rectangular area of the screen really complicated and results in blurry screenshots.
KDE Plasma Version: 6.4.5
KDE Frameworks Version: 6.18.0
Qt Version: 6.10.0
Kernel Version: 6.12.51-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 6 × Intel® Core™ i5-8600K CPU @ 3.60GHz
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor 1: AMD Radeon RX 6800
Graphics Processor 2: Intel® UHD Graphics 630
Manufacturer: Micro-Star International Co., Ltd.
Product Name: MS-7B46
System Version: 1.0
Mod edit:- See How to Post Command Output as Preformatted Text :eyes:
I suspect this is a local issue - I cannot reproduce
You are using 6.12 - have you verified it is also the case with 6.17?
Summary
 $ kinfo
Qt Version: 6.10.0
Kernel Version: 6.17.1-1-MANJARO (64-bit)
Processors: 24 × AMD Ryzen Threadripper PRO 5945WX 12-Cores
Memory: 128 GiB of RAM (125.6 GiB usable)
Graphics Processor: AMD Radeon RX 7900 XTX
Your post has been moved to a dedicated topic.
If you would like to provide useful detail about your computer please provide the expected system information as described (below).
Mod note:- Minor edits to conform with forum guidelines. No charge.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Yes, i just upgraded to 6.17 and still have the same issues.
Here is the system information that you requested:
inxi --filter --verbosity=8         ✔
  Kernel: 6.17.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
    root=UUID=d308b8a4-924c-4601-b983-c34485cd1d3a rw quiet apparmor=1
    security=apparmor resume=UUID=5ee1d153-9e4d-4840-9b3c-ff5fb8a50026
    udev.log_priority=3 intel_iommu=on preempt=voluntary
  Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.18.0
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: Z370 KRAIT GAMING (MS-7B46) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 1.C3 date: 11/16/2021
  System RAM: total: 32 GiB available: 31.21 GiB used: 10.57 GiB (33.9%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3000C16-8GISB
    serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    data: 64 total: 64 manufacturer: Crucial part-no: CT8G4DFD8213.C16FHP
    serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
    serial: <filter>
  Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 4100 min/max: 800/4300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4100 2: 4100 3: 4100 4: 4100 5: 4100 6: 4100
    bogomips: 43200
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: none off: HDMI-A-1 empty: DP-1,HDMI-A-2,HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800
    XT / 6900 XT] vendor: Sapphire Pulse driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-4
    empty: DP-3,DP-4,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:8
    chip-ID: 0c45:63ab class-ID: 0102 serial: <filter>
  Device-4: MacroSilicon driver: hid-generic,snd-usb-audio,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
    chip-ID: 534d:2109 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    unloaded: radeon alternate: fbdev,vesa dri: radeonsi,iris gpu: amdgpu,i915
    display-ID: 0
  Monitor-1: DP-2 model: Philips PHL 326M6V serial: <filter> built: 2019
    res: mode: 3840x2160 hz: 60 scale: 140% (1.4) to: 2743x1543 dpi: 139
    gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green: x: 0.259 y: 0.686 blue:
    x: 0.153 y: 0.055 white: x: 0.314 y: 0.329 size: 698x398mm (27.48x15.67")
    diag: 801mm (31.5") ratio: 16:9 modes: 3840x2160, 1920x2160, 2560x1440,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
  Monitor-2: HDMI-A-1 model: LG (GoldStar) TV SSCR2 serial: <filter>
    built: 2021 res: 3840x2160 dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
    green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1920x1080i, 1280x1024, 1360x768,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x576i, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
    unhandled CEA mode 98 5: parse_edid: unhandled CEA mode 99 6: parse_edid:
    unhandled CEA mode 100
  Monitor-3: HDMI-A-4 model: Acer S222HQL serial: <filter> built: 2011 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
    x: 0.643 y: 0.349 green: x: 0.286 y: 0.604 blue: x: 0.141 y: 0.071 white:
    x: 0.314 y: 0.329 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
    LLVM 20.1.8 DRM 3.64 6.17.1-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.328 layers: 7 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 (RADV NAVI21) driver: mesa radv v: 25.2.4-arch1.1
    device-ID: 1002:73bf surfaces: N/A device: 1 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 25.2.4-arch1.1 device-ID: 8086:3e92 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
  Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-5: Holtek HT82A834R Audio MCU
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-7.4:11 chip-ID: 04d9:2834 class-ID: 0300
  API: ALSA v: k6.17.1-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF-ID-1: br-746e592ab68b state: down mac: <filter>
  IF-ID-2: br-a61ab5459224 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: FritzBoxHorbach state: unknown speed: N/A duplex: N/A mac: N/A
  IF-ID-5: veth29726d9 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-7: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 2.3 TiB used: 1.1 TiB (48.0%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 53.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHII240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler Max
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
    serial: <filter> fw-rev: 1000 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: DT microDuo 3C
    size: 29.31 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS30 rev: 1.01
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 646.43 GiB (71.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d308b8a4-924c-4601-b983-c34485cd1d3a
    used: 29 MiB (9.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 8C6B-9D91
  ID-3: /media/Festplatte raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 484.58 GiB (52.9%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
    label: Festplatte Neu uuid: 8d2954fc-ff7f-41e1-9784-945a947b25b0
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 5ee1d153-9e4d-4840-9b3c-ff5fb8a50026
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 222.89 GiB fs: ntfs label: N/A
    uuid: 00461D84461D7B9A
  ID-3: /dev/sda3 maj-min: 8:3 size: 675 MiB fs: ntfs label: N/A
    uuid: F83E78FE3E78B6EA
  ID-4: /dev/sdc1 maj-min: 8:33 size: 238.47 GiB fs: exfat label: NicerDicer
    uuid: EFE7-FC62
  ID-5: /dev/sdd1 maj-min: 8:49 size: 29.3 GiB fs: vfat label: USBOTG
    uuid: A315-96A0
  Device-1: 1-2:2 info: MacroSilicon type: video,audio,HID
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 5 rev: 2.0
  Device-2: 1-5:3 info: Kingston DT microDuo 3C type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 300mA chip-ID: 0951:16ae class-ID: 0806
    serial: <filter>
  Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.3:6 info: Solid Year Thermaltake MEKA G-Unit Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 060b:5253 class-ID: 0300
  Device-2: 1-7.4:11 info: Holtek HT82A834R Audio MCU type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 1-8:5 info: Micro Star MSI GM41 Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0d41 class-ID: 0300
  Device-4: 1-9:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 1.1
  Device-5: 1-13:8 info: Microdia USB 2.0 Camera type: video,audio
  Hub-3: 1-14:9 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-14.4:10 info: QinHeng CH340 serial converter
    type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
    chip-ID: 1a86:7523 class-ID: ff00
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Device-1: 2-7:2 info: Transcend Information microSD/SD/CF UHS-II Card
    Reader [RDF8 RDF9] type: mass storage driver: usb-storage interfaces: 1
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    power: 800mA chip-ID: 8564:4000 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Device-1: 4-2:2 info: Kingston DataTraveler Max type: mass storage
    driver: uas interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 0951:177f class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
    mem: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 2693 pm: pacman pkgs: 2690 libs: 493 tools: pamac pm: flatpak
    pkgs: 3
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mirrors.xtom.de/bioarchlinux/$arch
  Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
    1: https://cdn-mirror.chaotic.cx/$repo/$arch
    2: https://geo-mirror.chaotic.cx/$repo/$arch
    3: https://br-mirror.chaotic.cx/$repo/$arch
    4: https://bg-mirror.chaotic.cx/$repo/$arch
    5: https://ca-mirror.chaotic.cx/$repo/$arch
    6: https://cl-mirror.chaotic.cx/$repo/$arch
    7: https://de-2-mirror.chaotic.cx/$repo/$arch
    8: https://de-3-mirror.chaotic.cx/$repo/$arch
    9: https://de-4-mirror.chaotic.cx/$repo/$arch
    10: https://fr-mirror.chaotic.cx/$repo/$arch
    11: https://gr-mirror.chaotic.cx/$repo/$arch
    12: https://in-mirror.chaotic.cx/$repo/$arch
    13: https://in-2-mirror.chaotic.cx/$repo/$arch
    14: https://in-3-mirror.chaotic.cx/$repo/$arch
    15: https://in-4-mirror.chaotic.cx/$repo/$arch
    16: https://kr-mirror.chaotic.cx/$repo/$arch
    17: https://es-mirror.chaotic.cx/$repo/$arch
    18: https://es-2-mirror.chaotic.cx/$repo/$arch
    19: https://us-mi-mirror.chaotic.cx/$repo/$arch
    20: https://us-tx-mirror.chaotic.cx/$repo/$arch
    21: https://us-ut-mirror.chaotic.cx/$repo/$arch
    1: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
Processes:
  CPU top: 5 of 375
  1: cpu: 168% command: qemu-system-x86_64 pid: 1101 mem: 3119.5 MiB (9.7%)
  2: cpu: 68.8% command: QtWebEngineProcess pid: 3709 mem: 807.2 MiB (2.5%)
  3: cpu: 55.0% command: thunderbird pid: 4106 mem: 772.7 MiB (2.4%)
  4: cpu: 51.1% command: firefox pid: 4147 mem: 654.6 MiB (2.0%)
  5: cpu: 28.1% command: spotify pid: 2992 mem: 420.2 MiB (1.3%)
  Memory top: 5 of 375
  1: mem: 3119.5 MiB (9.7%) command: qemu-system-x86_64 pid: 1101 cpu: 168%
  2: mem: 807.2 MiB (2.5%) command: QtWebEngineProcess pid: 3709 cpu: 68.8%
  3: mem: 772.7 MiB (2.4%) command: thunderbird pid: 4106 cpu: 55.0%
  4: mem: 654.6 MiB (2.0%) command: firefox pid: 4147 cpu: 51.1%
  5: mem: 555.8 MiB (1.7%) command: plasmashell pid: 1999 cpu: 19.2%
  Processes: 375 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: konsole inxi: 3.3.39
Even was thinking a GPU driver issue which could have been eliminated with the later kernel.
But it is difficult to suggest a path forward when I cannot reproduce the issue.
Yeah, I see that problem.
I am wondering why there is nobody else experiencing this…
check if shaderc is installed
pamac search shaderc
Yes, it is installed at version 2025.4-2.
Should i just create an upstream bug report?
no, please check if plasma-x11-session is installed
pamac search plasma-x11-session
if not insall it with
sudo pacman -S plasma-x11-session
afterwards you’re able to choose between x11 and wayland at the login-screen (left-bottom-corner).
choose x11 after rebooting and login. check if spectacle works properly under x11.
you can choose at any login which session you want.
Also, @MajorMayer , please update your user profile by visiting this page: Forum Profile Preferences.
Your user profile currently says that you are on Stable branch and running Gnome, not Plasma. That can cause confusion for anyone looking at your user profile to see some info about your system, especially at the moment due to Stable branch still being on a version of Plasma that has not split x11 from Wayland.
Right, the profile was really quite outdated, thanks for the hint.
I updated it, with the specs of my primary desktop PC.
I also have a notebook running Manjaro Gnome Unstable, but that’s not relevant here…
Plasma X11 session was not installed, so I installed it and tried to boot the system with X11.
Unfortunately, after I entered my credentials in SDDM, the display just turned black and nothing happened.
I tried to press every key and key combinations that i knew, but no luck.
If I select Wayland in the display manager, the system boots normally.
So unfortunately I can’t tell you if it works with X11.
Not sure how to debug this properly and if I got the time, but if you have any hints, feel free to tell me.
I noticed that the issue only happens when I enabled my second screen (the Acer) but disabled the third screen (the LG).
