Heyo! I’m having some issues with the latest update. I haven’t had issues with previous updates, so it’s a bit baffling.
(I didn’t realize I replied to a specific post, that was not intentional)
I have also tried updating my pacman mirrors.
Please let me know what info I could provide if I missed anything useful, this is my first time posting in a forum.
My hardware:
- AMD 5800x
- EVGA Nvidia 3070ti
I did try updating video-nvidia with mhwd, but there were conflicts, and I foolishly forgot to grab the logs of what they were. I assume this is due to me trying to use the repo below.
MY guess is that it’s a combination of gcc15 updating and how I currently install Nvidia drivers.
I’ve been using this repo as an easy way to update my nvidia drivers.
However, I know this commit exist for the GCC 15 version
But, when I try rebuilding these AFTER the update inside TTY, I only get errors, it’s possible I’m somehow failing to update properly, but it seems hard to type makepkg -si
(and I updated the code with latest)
Updating and getting stuck
The general flow of this went as such:
- Reboot after update as per usual
- Don’t see booting animation like I usually do.
- Open TTY2
- Check journalctl logs, don’t see anything out of the ordinary.
- Reboot
- Check journalctl logs, notice it says Nvidia kernel modules can no longer be found.
- Use timeshift to restore to point just before update.
Here’s my driver info before updating. Note here, these did not change after running the update.
~> mhwd-kernel -li
Currently running: 6.12.25-1-MANJARO (linux612)
* linux54
* linux612
~> mhwd -l
> 0000:09:00.0 (0300:10de:2482) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2025.01.13 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
Here are my journalctl logs after the first reboot. To me, these aren’t anything crazy or to suspect issues from.
May 14 19:09:04 kraken (sd-worker)[40301]: Failed start worker process: No such file or directory
May 14 19:09:04 kraken (sd-worker)[40302]: Failed start worker process: Text file busy
May 14 19:11:58 kraken dbus-broker-launch[813]: Activation request for 'org.bluez' failed.
May 14 19:11:58 kraken dbus-broker-launch[813]: Activation request for 'org.freedesktop.UDisks2' failed.
May 14 19:11:58 kraken systemd-coredump[99970]: Failed to send pidfd: Connection reset by peer
May 14 19:11:58 kraken dbus-broker-launch[813]: Activation request for 'org.freedesktop.UPower' failed.
May 14 19:11:59 kraken dbus-broker-launch[813]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
May 14 19:11:59 kraken dbus-broker-launch[813]: Activation request for 'org.bluez' failed.
May 14 19:11:59 kraken systemd-coredump[100227]: Failed to send coredump datagram: Connection reset by peer
May 14 19:11:59 kraken systemd-coredump[100318]: Failed to send coredump fd: Broken pipe
May 14 19:12:00 kraken (sd-pam)[1015]: pam_systemd(systemd-user:session): Failed to release session: No session '2' known
May 14 19:12:00 kraken dbus-broker-launch[813]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
May 14 19:12:01 kraken kernel: watchdog: watchdog0: watchdog did not stop!
After this I rebooted. Which I was met with the same screen where I see my motherboards logo.
Checking logs again, they changed to this.
May 14 19:12:26 kraken systemd-modules-load[412]: Failed to find module 'nvidia'
May 14 19:12:26 kraken systemd-modules-load[412]: Failed to find module 'nvidia_drm'
May 14 19:12:26 kraken systemd-modules-load[412]: Failed to find module 'nvidia-uvm'
May 14 19:23:22 kraken dbus-broker-launch[817]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
And here are some pacman logs.
[2025-05-14T19:10:04-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod nvidia/570.123.14 -k 5.4.293-1-MANJARO
[2025-05-14T19:10:24-0500] [ALPM-SCRIPTLET]
[2025-05-14T19:10:24-0500] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 5.4.293-1-MANJARO (x86_64)
[2025-05-14T19:10:24-0500] [ALPM-SCRIPTLET] Consult /var/lib/dkms/nvidia/570.123.14/build/make.log for more information.
[2025-05-14T19:10:24-0500] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod nvidia/570.123.14 -k 5.4.293-1-MANJARO' exited 10
[2025-05-14T19:10:24-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.14.0 -k 6.12.28-1-MANJARO
[2025-05-14T19:10:25-0500] [ALPM-SCRIPTLET] Deprecated feature: CLEAN (/usr/src/v4l2loopback-0.14.0/dkms.conf)
[2025-05-14T19:10:27-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.14.0 -k 5.4.293-1-MANJARO
[2025-05-14T19:10:28-0500] [ALPM-SCRIPTLET] Deprecated feature: CLEAN (/var/lib/dkms/v4l2loopback/0.14.0/source/dkms.conf)
[2025-05-14T19:10:30-0500] [ALPM-SCRIPTLET] ==> dkms install --no-depmod nvidia/570.123.14 -k 6.12.28-1-MANJARO
[2025-05-14T19:10:49-0500] [ALPM-SCRIPTLET]
[2025-05-14T19:10:49-0500] [ALPM-SCRIPTLET] Error! Bad return status for module build on kernel: 6.12.28-1-MANJARO (x86_64)
[2025-05-14T19:10:49-0500] [ALPM-SCRIPTLET] Consult /var/lib/dkms/nvidia/570.123.14/build/make.log for more information.
[2025-05-14T19:10:49-0500] [ALPM-SCRIPTLET] ==> WARNING: `dkms install --no-depmod nvidia/570.123.14 -k 6.12.28-1-MANJARO' exited 10
