Unfortunately the script seems to be no longer working.The package is not found on the servers. Manually running the script is stuck at User passwords do not match! Restarting OEM script…
The script mentioned - the one you get by syncing the package manjaro-arm-oem-install works as it is supposed to.
If the user passwd doesn’t match then you have to ensure you are inputting the new passwords correct and yes the script restarts if you get it wrong - that is how it works.
