I been using Manjaro for over 6 months now, however recently I been facing an issue with it freezing multiple times a day requiring me to RESUIB it.
here is my system output
i think the issue might be related to my GPU drivers, I been following several tutorials but might be that I have very specific issue (have an APU and a GPU on the same sistem, I only use the GPU) but don’t want to jump into conclusion, any help or feedback will be highly appreciated.
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=1f5997db-2064-476c-93dc-539f29aaa3e1 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: TUF GAMING B550-PLUS (WI-FI) v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2407 date: 07/13/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 62.66 GiB used: 4.86 GiB (7.7%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 size: No Module Installed
Device-2: DIMM_A2 size: 32 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Kingston part-no: KF3200C16D4/32GX
serial: <filter>
Device-3: DIMM_B1 size: No Module Installed
Device-4: DIMM_B2 size: 32 GiB speed: 3200 MT/s type: DDR4
total: 64 bits manufacturer: Kingston part-no: KHX3200C16D4/32GX
serial: <filter>
Info: model: AMD Ryzen 7 5700G with Radeon Graphics socket: AM4 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1850 high: 3800 min/max: 1400/4672 boost: enabled
base/boost: 3800/4650 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.4 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 3800 8: 3800 9: 3800 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 121649
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GP107GL [Quadro P400] driver: nvidia v: 510.47.03
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1cb3
class-ID: 0300
Device-2: Realtek RTL2838 DVB-T type: USB driver: dvb_usb_rtl28xxu
bus-ID: 3-2:2 chip-ID: 0bda:2838 class-ID: 0000 serial: <filter>
Device-3: Microsoft LifeCam HD-3000 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2:3 chip-ID: 045e:0810
class-ID: 0102
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x2340 s-dpi: 107 s-size: 1216x555mm (47.9x21.9")
s-diag: 1337mm (52.6")
Monitor-1: DP-0 res: 2560x1440 hz: 75 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-2 res: 2560x1440 hz: 75 dpi: 109
Monitor-3: DP-5 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Microsoft LifeCam HD-3000 type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.45 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Local Storage: total: 581.45 GiB used: 82.82 GiB (14.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 1B2QGXA7 temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 4h cycles: 455
read-units: 24,530,968 [12.5 TB] written-units: 45,210,512 [23.1 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Ultra
size: 115.69 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
used: 82.82 GiB (17.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 1f5997db-2064-476c-93dc-539f29aaa3e1
used: 568 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 6E15-E3BA
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-4: /var/cache raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-5: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 114.55 GiB fs: exfat label: Sandisk_128
uuid: CC3C-0343
ID-2: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda5 maj-min: 8:5 size: 1.13 GiB fs: swap label: N/A
uuid: 4d06e0fa-8c15-4d51-afc4-47e4b610dd97
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-9:5 info: foostan Corne Keyboard Rev.1 (Split Common)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 4653:0001 class-ID: 0300
Device-2: 1-10:6 info: Logitech 2.4GHz Cordless Desktop
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c52a class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Realtek RTL2838 DVB-T type: Video
driver: dvb_usb_rtl28xxu interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 5-1.3:4 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 5-2:3 info: Microsoft LifeCam HD-3000 type: Video,Audio
power: 500mA chip-ID: 045e:0810 class-ID: 0102
Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-9: 6-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 6-1.4:3 info: SanDisk Ultra Dual type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5590 class-ID: 0806 serial: <filter>
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 372 Uptime: 26m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1352 pacman: 1330 lib: 371
flatpak: 13 snap: 9 Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
