I have a Razer 2020 15 base model with manjaro newly installed.
I’ve had some issues regarding two things.
Firstly, after a while in sleep or just a while of use the mouse starts stuttering and I can see large CPU spikes on btm when I start moving the mouse, without the mouse responding. This is when I use my trackpad.
The second problem I have is when i close the laptop manjaro, sometimes, doesn’t go to sleep, i believe it almost keeps the screen on even though I’ve set it so that it should go to sleep in the system settings.
I hope you have some good input on this, literally the only two issues I’ve had with Manjaro on my crisp new razer computer ![]()
Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=d63bbfd5-3644-491e-99a8-20066c948219 rw quiet apparmor=1
security=apparmor resume=UUID=0b82ffe2-a896-494d-ad53-6cd3634ee879
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Razer
product: Blade 15 Base Model (Early 2020) - RZ09-0328 v: 5.04
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Razer model: DA550 v: 4 serial: <filter> UEFI: Razer v: 01.04
date: 06/04/2020
ID-1: BAT0 charge: 53.6 Wh condition: 67.4/65.0 Wh (104%) volts: 16.0/15.4
model: Razer Blade type: Unknown serial: <filter> status: Discharging
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 2 microcode: E0 L2 cache: 12.0 MiB
bogomips: 62431
Speed: 900 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 902 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
Device-1: Intel UHD Graphics vendor: Razer USA driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: Razer USA driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1f14
Device-3: IMC Networks USB Camera type: USB driver: uvcvideo bus ID: 1-7:2
chip ID: 13d3:56bd serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia unloaded: intel alternate: fbdev,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:06c8
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Sound Server: ALSA v: k5.4.80-2-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 5000
bus ID: 00:14.3 chip ID: 8086:06f0
vendor: Razer USA driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
Local Storage: total: 476.94 GiB used: 93.94 GiB (19.7%)
ID-1: /dev/nvme0n1 model: NVMe CA5-8D512 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: CQ20903 scheme: GPT
ID-1: / raw size: 459.59 GiB size: 451.38 GiB (98.21%)
used: 93.94 GiB (20.8%) fs: ext4 dev: /dev/nvme0n1p2
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 288 Uptime: 21m Memory: 15.50 GiB used: 2.59 GiB (16.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1562 pacman: 1540
lib: 458 rpm: 1 flatpak: 12 snap: 9 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.1.08
