Hi guys!!! Hope all is fine for u!!! This morning ive turned on my pc and i see my arc-menu just go on with the wind…try the enable again running
gnome-extensions enable arcmenu@arcmenu.com
But didnt work, any idea?
Hi @boris_perez,
Which extension did you use? I’m presuming this one:
https://extensions.gnome.org/extension/1228/arc-menu/
Which says, right at the top there:
## Unmaintained Project ##
So, maybe try this one:
https://extensions.gnome.org/extension/3628/arcmenu/
Hope it helps!
Sorry, I don’t know what you mean by that. ArcMenu works fine for me.
Please see the following and help us help you:
I realize that English may not be your first language. If you’d rather post in your native language, you may create a topic in our Other Languages category. If you don’t see your language there, just tag it with the applicable language; i.e. for Portuguese: português
He’s already using it. That’s the official ArcMenu extension which is also in the Arch and Manjaro repos. ![]()
EDIT: By the way, I’ve unmarked the Solution as there’s no way the reply marked can be. Also, this topic will never help anyone in the future as is. I’m going to unlist it so it’s hidden from the public (at least temporarily) until @boris_perez provides more information.
Hi @Yochanan …you are right, english is not my first language…and when i’ve said that “arcmenu went with the wind” wanna means that i can’t see nor use it…
Also ive solved the issue following @Mirdarthos suggestion, that’s why i’ve marked that post as the solution…because ive installed arc-menu extension from web and i have it again…Sorry if i’ve broken some rules here…and thanks for your suggestion and help…
Hi again!!! I’ve uninstalled arcmenu extension (the one installed from web) cause i ve founded the official one on “extra” repo…which is pointed as “installed” as can u see on attached screenshot, but can’t find it on extensions list…i’ve tried reinstallling but still not working…
My “inxi -Fazy” output is:
~ inxi -Fazy ✔
Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=034cce20-46f0-4762-a989-90f4125f7af9 rw apparmor=1
security=apparmor resume=UUID=35dedb6e-40ca-4832-b4a1-6fa39675484b
udev.log_priority=3
Desktop: GNOME v: 46.3.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1500CEAEY_B1500CEAE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: B1500CEAEY v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: ASUSTeK v: B1500CEAEY.321 date: 12/22/2022
ID-1: BAT0 charge: 33.1 Wh (100.0%) condition: 33.1/42.1 Wh (78.6%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 156
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 847 high: 1119 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1077 2: 400 3: 999 4: 1119
5: 778 6: 400 7: 966 8: 1039 bogomips: 44864
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:5 chip-ID: 13d3:56a2
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
model: Philips PHL 221V8 serial: <filter> built: 2024 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: left model: ChiMei InnoLux 0x15f5 built: 2017
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.48 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
IF: eno2 state: down mac: <filter>
Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.15 TiB used: 312.12 GiB (26.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9300 scheme: GPT
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 34.09 GiB (89.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 29.3 GiB size: 28.67 GiB (97.86%)
used: 17.56 GiB (61.3%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2000
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 5.51 GiB (36.0%)
Processes: 326 Power: uptime: 4h 18m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.11 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1435 libs: 345 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.35
any suggestion? Thanks in advance
Please provide the output of:
ls -lah ~/.local/share/gnome-shell/extensions/
Also, try clearing your cache:
rm -fr ~/.cache/*
Thanks @Midarthos …i’ ve founded the solution…by uninstalling web extensions and reinstalling the ones on repos…still without to know the causes behind the issues…but problem soved!!! Thanks anyway!!!
