Iaith
4 January 2021 01:41
1
I have been getting errors about locale for quiet a while now, but the simple solutions didn’t change anything - and it didn’t seem to actually be an issue.
Today i tried to start pulseeffects and got the error
$ pulseeffects
terminate called after throwing an instance of 'std::runtime_error'
what(): locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)
After that i found out that in my etc/ directory i don’t have /etc/locale.gen only /etc/locale.gen.pacnew but i can access /etc/locale.gen via nano. So what should i do now?
Not sure what the proper category is since an error with pulse prompted me to action but it doesn’T seem to be the originator of the problem, probably.
$ inxi --full --verbosity=7 --filter --no-host
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_GB:en_US",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "io_001.UTF-8",
LC_COLLATE = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
System: Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: MEDIONPC model: MS-7728 v: 2.0 serial: <filter>
BIOS: American Megatrends v: E7728MLN.209 date: 12/22/2011
Memory: RAM: total: 15.62 GiB used: 8.3 GiB (53.1%)
CPU: Info: Quad Core model: Intel Core i5-2320 bits: 64 type: MCP arch: Sandy Bridge rev: 7
L2 cache: 6 MiB bogomips: 23955
Speed: 3097 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 3097 2: 3105 3: 3106
4: 3102
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est flexpriority flush_l1d fpu fxsr
ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp
rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia v: 455.45.01
bus ID: 01:00.0 chip ID: 10de:1380
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia resolution:
1: 1920x1080~60Hz 2: 1280x1024~60Hz s-dpi: 101
OpenGL: renderer: GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbc
Device-3: Bose Bose USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1.1:3 chip ID: 05a7:1020
Device-4: Thesycon System & Consulting D10 type: USB driver: snd-usb-audio
bus ID: 2-1.1:3 chip ID: 152a:8750
Sound Server: ALSA v: k5.10.2-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: IMC Networks Mediao 802.11n WLAN [Realtek RTL8191SU] type: USB driver: r8712u
bus ID: 2-1.6:6 chip ID: 13d3:3306 serial: <filter>
IF: wlp0s29u1u6 state: down mac: <filter>
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 1.36 TiB used: 1.06 TiB (77.4%)
ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 3.0 Gb/s
serial: <filter> rev: 023
ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKX-00ERMA0 size: 465.76 GiB
speed: 3.0 Gb/s serial: <filter> rev: 1H15
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-216AB rev: MD00 dev-links: cdrom
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
state: running
Partition: ID-1: / size: 898.98 GiB used: 842.83 GiB (93.8%) fs: ext4 dev: /dev/sda1 label: N/A
uuid: c9c07722-f3ef-4038-a3ef-f4803e917bde
ID-2: /run/media/jan/4AD42B71D42B5E87 size: 194.72 GiB used: 122.23 GiB (62.8%) fs: ntfs
dev: /dev/sdb2 label: N/A uuid: 4AD42B71D42B5E87
ID-3: /run/media/jan/Daten size: 270.45 GiB used: 116.01 GiB (42.9%) fs: ntfs
dev: /dev/sdb4 label: Daten uuid: 18DCF506DCF4DF46
ID-4: /run/media/jan/System-reserviert size: 100 MiB used: 65.6 MiB (65.6%) fs: ntfs
dev: /dev/sdb1 label: System-reserviert uuid: E48225DD8225B4C8
Swap: ID-1: swap-1 type: partition size: 17.19 GiB used: 61.8 MiB (0.4%) priority: -2
dev: /dev/sda2 label: N/A uuid: e055263f-df22-4160-9468-005831f77676
Unmounted: ID-1: /dev/sdb3 size: 510 MiB fs: ntfs label: N/A uuid: 3AA6701FA66FDA41
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:0024
Device-1: 1-1.1:3 info: Bose Bose USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.0 speed: 12 Mb/s
chip ID: 05a7:1020
Device-2: 1-1.2:4 info: Holtek Ducky Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 04d9:0356
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:0024
Device-1: 2-1.1:3 info: Thesycon System & Consulting D10 type: Audio
driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s chip ID: 152a:8750
Device-2: 2-1.2:4 info: Logitech G600 Gaming Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c24a
serial: <filter>
Device-3: 2-1.5:5 info: Realtek RTS5182 Card Reader type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0184
serial: <filter>
Device-4: 2-1.6:6 info: IMC Networks Mediao 802.11n WLAN [Realtek RTL8191SU]
type: Network driver: r8712u interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:3306
serial: <filter>
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Info: Processes: 236 Uptime: 10h 24m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1501 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
I haven’t had any such problems, but I realized I also didn’t have any locales set on /etc/locale.gen
in my Gnome. Maybe it is set other way/place?
Maybe try to uncomment yours and running “locale-gen” like specified here and see if it makes a difference?
You definitively should have an /etc/locale.gen
but if you haven’t got it, copy the pacnew one as it.
pobrn
4 January 2021 13:54
3
I’m wondering if this is a real locale? Can you run printenv | grep LC
Iaith
4 January 2021 17:42
4
I did run locale-gen before, didn’T make a difference. I also did uncomment my language settings in locale.gen,pacnew. You mean just copy and rename locale.gen.pacnew to locale.gen?
The weird thing though is if i type in
nano /etc/locale.gen
i can open a file and the content is slightly different from when i do
nano /etc/locale.gen.pacnew
but when i check in dolphin, there is no file inbetween locale.conf and locale.gen.pacnew
Iaith
4 January 2021 17:48
5
$ printenv | grep LC
LC_ADDRESS=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_MONETARY=de_DE.UTF-8
LC_PAPER=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_TIME=io_001.UTF-8
LC_COLLATE=de_DE.UTF-8
LC_NUMERIC=de_DE.UTF-8
i think the LC_TIME=io_001.UTF-8
might be because i changed my date format in kde to iso standard, i can’t find the setting atm though. That means my date is yyyy-mm-dd
Edit: I found it it is the time setting under regional settings/formats.
https://wiki.archlinux.org/index.php/Pacman/Pacnew_and_Pacsave
.pacnews are files created when devs intend to change or append new config variables in the config files of their apps, but without overwriting your actual one and possibly destroying your own customizations.
You are supposed to merge any changes to the original file, if needed. And then remove those .pacnew files. But of course, the ones counting for real are the original ones and not the .pacnews.
Try to run this and then open again pulseffects, in addition to having a proper generated locale, that should rule out if it really is a locale thing or not:
export LC_ALL=en_US.UTF-8
Which desktop?
If KDE , checkout this thread or this one .
Locale will update /etc/locale.gen
When selected, notice the Add button. There is also a context menu (right-click) on each added language.
Regional Settings will update files in your home directory like $HOME/.config/plasma-localerc
. When selected, if you hover over a language, notice symbols on the right that can be used to remove the language or make it the default.
I use this command often to list changed files:
find -newermt '1 minute ago`
If they are system files, it needs to be changed to something like:
find / \( -path /dev -o -path /proc -o -path /sys \) -a -prune -o -newermt '1 minute ago'
Iaith
4 January 2021 19:27
9
After i use that command i am able to start pulseeffects from the terminal.
Iaith
4 January 2021 19:59
10
I changed the io_001.UTF-8 to the german setting in regional settings and pulseeffects starts now without problems and the locale is no longer lsited as an issue
Memory: RAM: total: 15.62 GiB used: 3.13 GiB (20.0%)
L2 cache: 6 MiB bogomips: 23953
Speed: 1596 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 1596 2: 1596 3: 1596
4: 1596
direct render: Yes
state: running
Partition: ID-1: / size: 898.98 GiB used: 842.74 GiB (93.7%) fs: ext4 dev: /dev/sda1 label: N/A
Swap: ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2
chip ID: 1d6b:0002
chip ID: 8087:0024
chip ID: 05a7:1020
chip ID: 1d6b:0002
chip ID: 8087:0024
serial: <filter>
serial: <filter>
serial: <filter>
chip ID: 1d6b:0002
chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 8%
Info: Processes: 245 Uptime: 2h 39m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0
Edit: But if i change it back again i have the same error again, is there no way to keep the iso standard without getting errors?
Edit2: Also i guess that makes this a KDE Problem now since i am setting lcoale via KDE
Check this out, a report for this issue, 5 years in the making.
https://bugs.kde.org/show_bug.cgi?id=340982
There are some workarounds inside, or kind off, but nothing completely satisfactory it seems.
Iaith
10 January 2021 23:59
12
By complete accident i found a different solution i left the locale same as everything else as de_DE. But if you right click the digital clock and “configure digital clock” you can set iso date as date format.
system
Closed
25 January 2021 23:59
13
