I have a Lenovo L14 AMD with an 4750U and I generally love it but there are a couple major of issues with the computer, maybe someone can give me some advice:
- The cpu clocks down under heavy load (usually if more than 8 cores are used), often as low as 400-600MHz, fans are spinning but far from their maximum speed, power consumption of the laptop is also way down,
sensorsshows that the CPU only consumes 5-6W when this happens. Here is a similar issue. - After sleeping, the screen sometimes has a white noise overlay which can only be fixed by a reboot. I have tried changing resolution, it works but the white noise stays, I cannot turn off the laptop monitor, because the external HDMI port does not send any signal, it recognizes the screen though.
- The keyboard gets locked up from time to time: It stops reacting and sends the same key over and over again. Closing the lid and putting the computer to sleeps helps here. Here is someone with the same Problem.
- The wifi card gets only 1.5Mbit download on my home router, I have to add
11n_disable=1to theiwlwifimodule, which is very suboptimal. This seems to be a known issue with the Intel WIFI card under Linux - The touchpad is very jumpy from time to time. It sometimes happens if I am trying to press a button, which makes it extra annoying because the click always happens somewhere else.
Going through the journald logs I have just discovered that xorg fails on every boot, not sure where to report it.
core dump
Feb 07 20:05:14 orange ModemManager[573]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:02:00.0': not supported by any plugin
Feb 07 20:05:14 orange systemd-coredump[1325]: Process 565 (Xorg) of user 0 dumped core.
Stack trace of thread 565:
#0 0x00007f4cebe5e615 raise (libc.so.6 + 0x3d615)
#1 0x00007f4cebe47862 abort (libc.so.6 + 0x26862)
#2 0x000055b3b65276ea OsAbort (Xorg + 0x14a6ea)
#3 0x000055b3b65291b1 FatalError (Xorg + 0x14c1b1)
#4 0x000055b3b652ee09 n/a (Xorg + 0x151e09)
#5 0x00007f4cebe5e6a0 __restore_rt (libc.so.6 + 0x3d6a0)
#6 0x00007f4cebe5e615 raise (libc.so.6 + 0x3d615)
#7 0x00007f4cebe47862 abort (libc.so.6 + 0x26862)
#8 0x00007f4cebe47747 __assert_fail_base.cold (libc.so.6 + 0x26747)
#9 0x00007f4cebe56bf6 __assert_fail (libc.so.6 + 0x35bf6)
#10 0x000055b3b6472870 n/a (Xorg + 0x95870)
#11 0x00007f4cdc2c7fb9 glamor_init (libglamoregl.so + 0xcfb9)
#12 0x00007f4ceb13b0fd n/a (modesetting_drv.so + 0x140fd)
#13 0x000055b3b645640e AddGPUScreen (Xorg + 0x7940e)
#14 0x000055b3b6562eb9 n/a (Xorg + 0x185eb9)
#15 0x000055b3b6598288 n/a (Xorg + 0x1bb288)
#16 0x000055b3b6598b12 n/a (Xorg + 0x1bbb12)
#17 0x000055b3b6527331 n/a (Xorg + 0x14a331)
#18 0x000055b3b6522c00 WaitForSomething (Xorg + 0x145c00)
#19 0x000055b3b6416914 n/a (Xorg + 0x39914)
#20 0x00007f4cebe49152 __libc_start_main (libc.so.6 + 0x28152)
#21 0x000055b3b64175de _start (Xorg + 0x3a5de)
Stack trace of thread 617:
#0 0x00007f4cebd166a2 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf6a2)
#1 0x00007f4ce8fe2004 n/a (swrast_dri.so + 0x6df004)
#2 0x00007f4ce8fc6bb8 n/a (swrast_dri.so + 0x6c3bb8)
#3 0x00007f4cebd103e9 start_thread (libpthread.so.0 + 0x93e9)
#4 0x00007f4cebf21293 __clone (libc.so.6 + 0x100293)
Stack trace of thread 1313:
#1 0x00007f4ce8df0c4c n/a (swrast_dri.so + 0x4edc4c)
#2 0x00007f4ce8def418 n/a (swrast_dri.so + 0x4ec418)
Stack trace of thread 1309:
Stack trace of thread 636:
Stack trace of thread 1321:
Stack trace of thread 615:
Stack trace of thread 1318:
Stack trace of thread 1301:
Stack trace of thread 601:
Stack trace of thread 1307:
Stack trace of thread 621:
#1 0x00007f4ce8fce8a4 n/a (swrast_dri.so + 0x6cb8a4)
#2 0x00007f4ce8fc6b88 n/a (swrast_dri.so + 0x6c3b88)
Stack trace of thread 629:
Stack trace of thread 1312:
Stack trace of thread 619:
Stack trace of thread 1305:
Stack trace of thread 611:
Stack trace of thread 1322:
Stack trace of thread 608:
Stack trace of thread 603:
Stack trace of thread 1323:
Stack trace of thread 616:
Stack trace of thread 605:
Stack trace of thread 604:
Stack trace of thread 606:
Stack trace of thread 624:
Stack trace of thread 610:
Stack trace of thread 613:
Stack trace of thread 612:
Stack trace of thread 607:
Stack trace of thread 620:
Stack trace of thread 609:
Stack trace of thread 631:
Stack trace of thread 623:
Stack trace of thread 618:
Stack trace of thread 622:
Stack trace of thread 626:
Stack trace of thread 632:
Stack trace of thread 628:
Stack trace of thread 637:
Stack trace of thread 614:
Stack trace of thread 1314:
Stack trace of thread 1304:
Stack trace of thread 633:
Stack trace of thread 634:
Stack trace of thread 1311:
Stack trace of thread 1315:
Stack trace of thread 627:
Stack trace of thread 630:
Stack trace of thread 1306:
Stack trace of thread 1316:
Stack trace of thread 625:
Stack trace of thread 635:
Stack trace of thread 1319:
Stack trace of thread 1302:
Stack trace of thread 1303:
Stack trace of thread 1310:
Stack trace of thread 1317:
Stack trace of thread 1308:
Stack trace of thread 1320:
Feb 07 20:05:14 orange systemd[1]: systemd-coredump@0-1324-0.service: Succeeded.
Feb 07 20:05:14 orange audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1324-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
