Hello, on brand new installs with the latest GNOME iso, Firefox Home (new tab page) isn’t working after the second start of Firefox and is showing as blank:
Also Add Water isn’t launching (looking for Firefox profile in the wrong place, I think):
~ addwater ✔
/home/pacu/.cache/add-water already exists. Skipped.
/home/pacu/.cache/add-water/downloads already exists. Skipped.
/home/pacu/.cache/add-water/logs already exists. Skipped.
All paths initialized.
[INFO] addwater.apps.firefox.firefox_details — 06:09 || Setting Firefox data path:
[ERROR] addwater.apps.firefox.firefox_details — 06:09 || Tried to set app_path to non-existant path. Path given:
[CRITICAL] addwater.apps.firefox.firefox_details — 06:09 || Could not find any valid data paths. App cannot function.
File "/usr/share/addwater/addwater/apps/firefox/firefox_details.py", line 90, in __init__
self.set_data_path(current_path)
File "/usr/share/addwater/addwater/apps/firefox/firefox_details.py", line 167, in set_data_path
raise FileNotFoundError("Invalid data path")
FileNotFoundError: Invalid data path
During handling of the above exception, another exception occurred:
File "/usr/bin/addwater", line 46, in <module>
sys.exit(main.main(VERSION))
File "/usr/share/addwater/addwater/main.py", line 179, in main
app = AddWaterApplication()
File "/usr/share/addwater/addwater/main.py", line 63, in __init__
self.backends = self.construct_backends()
File "/usr/share/addwater/addwater/main.py", line 133, in construct_backends
ff_app_detail = FirefoxAppDetails()
File "/usr/share/addwater/addwater/apps/firefox/firefox_details.py", line 94, in __init__
self.set_data_path(available_paths[0]["path"])
IndexError: list index out of range
As from Firefox 147 on Linux, profile and other directories have been changed (mainly) to reside under the ~/.config/ heirarchy instead of ~/.mozilla. This is a generally seamless change, however, there may be applications (such as “Add Water” that you mentioned) that have hard-coded paths, for example; only a guess, as I have no idea what this “AddWater” might be.
This looks to be a path that you have previously set in AddWater – that being the case, you should probably change it to the correct path – if the application was installed via the AUR, you might simply need to rebuild it.
I suggest deleting ~/.cache firstly, to see if that makes a difference – this must be done without being logged into the GUI – logout, and login via a TTY – then delete ~/.cache and reboot.
Let’s see if the app devs will update it to work out of the box.
About Firefox, I tried going to about:support, clicking “Refresh Firefox”, “Clear startup cache”, I even deleted manjaro-browser-settings, but the home page still breaks after opening and closing a few tabs/windows.
Update: Reinstalling Firefox fixed it, probably so it can start without manjaro-browser-settings. Maybe the issue is in that package, since I’m not getting this problem on other Arch distros
