While running update action I got also:
Package (17) Old Version New Version Net Change Download Size
extra/accountsservice 0.6.55-3 22.04.62-2 -0.07 MiB 0.16 MiB
Is there is not error? Really version could mutate that much?
SemVer:
MAJOR
: 0
β 22
like possible renaming if it was included into some project and now it matches all other components around some integrated system. ok that sometimes could be.
But how MINOR
could downgrade while also that update?
Thatβs really odd version update, Team please re-check it.
Also:
( 3/17) upgrading accountsservice [###########################################################] 100%
warning: directory permissions differ on /var/lib/AccountsService/
filesystem: 755 package: 775
( 4/17) upgrading libcups [###########################################################] 100%
The sudo chmod 775 /var/lib/AccountsService/
fixed it. I did package reinstall after this: sudo pacman -S accountsservice
