Issues while updating/upgrading system (Error: GPGME Error: No data)
Hello again,
First things first, I am using the latest 5.15 rc Manjaro Linux Kernel. KDE Plasma.
I was trying to update and upgrade my system with sudo pacman -Syu to keep things up to date, everything was going smoothly until my dad’s content filter shut off the wifi at a certain time and interrupted my update.
After that, I got the wifi back on and tried to resume my update. I was greeted with:
sudo pacman -Syyu         ✔
[sudo] password for jlwilt:
error: GPGME error: No data
 core                                      170.7 KiB   166 KiB/s 00:01 [########################################] 100%
 extra                                    1915.6 KiB   541 KiB/s 00:04 [########################################] 100%
 community                                   6.7 MiB  1459 KiB/s 00:05 [########################################] 100%
 multilib                                  176.1 KiB   660 KiB/s 00:00 [########################################] 100%
error: failed to synchronize all databases (unexpected error)
I then proceeded to run many different commands in order to fix my system, however, since many were spliced from different forums I cannot assure their effectiveness. Here is my pacman.conf file:
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
How would I fix this error? Thanks in advance.
Have you checked similar issues?
https://forum.manjaro.org/search?q=error%3A%20GPGME%20error%3A%20No%20data
I had checked all of those previously, none of the commands worked. However, the search for proper tutorials led me to follow the guide on this page.
After following the steps, package updates work flawlessly.
