How did you create the live media? I’m asking because I had permission issues inside the home folder in the past with isos booted through ventoy
I’ve used the iso file downloaded from the official site, then i flashed it with balena etcher.
Look what the cat just dragged in:
My suggestion would be to download the latest iso and go from there, since you only just installed Manjaro anyway
I was about to share it too.
They have dropped the Gnome initial setup apparently, that had as you are aware some issues.
Try this new iso, should be better.
Perfect, i’ll try and i’ll keep you updated!
The Issue has been solved by installing the new version of Gnome!
Thank you very much for your help!
