Issues after updating/reinstalling in July 2024
Hello, this is my first post about an issue here. I’m on Manjaro XFCE since 2021 and I have to say that everything went mostly smoothly until now. I’ll try to explain it… Some weeks ago, on my main machine, I updated Manjaro after quite some time (I know, I know…). There were some issues, and I thought that the long time without updates created some mess. So, I reinstalled everything from scratch (twice!) and wiped away all my /home folders to do a clean reinstall, but the issues persist (which, by the way, had never happened before in this machine). They are quite weird, and I haven’t been able to find a soultion by searching in the forum. The version in which I’m seeing right now these issues is 24.0.3 (installed with the .iso from the official webpage)
These are some things that I observe right now :
  1. After reinstalling and configuring the OS to my preferences, after various reboots, then it happens that the desktop misses its icons (not the panel, though). I can’t even right-click in the background to change the desktop settings, theme, etc. Since I use a solid color background, all I see now is a black screen with the panel and the Manjaro whisker menu. I tried resetting the xfce-minimal-settings but nothing changes with any reboot. If I open the desktop settings from the whisker menu, I can’t change anything…
  2. Thunar acts very strangely; I have to double-click several times (sometimes killing some Thunar stuck process in the task manager) to make it run. It also, randomly, doesn’t run it’s root mode with the right-click option. Besides, when I try to run it both from the panel icon or from the whisker menu, it sometimes shows a sign saying that there was an input/output error. After that, it can happen that it runs fine after retrying (or not), Everything is quite unpredictable. Hence, I installed Nemo alongside Thunar, and I use both depending on the occasion.
  3. Notepadqq (and the Mousepad) tend to shutdown soon after I open any simple text file. This is really strange. Sublime-text doesn’t crash, so I’ll stay with it for now.
If I see or remember other strange issues like these, I’ll post them here. Needless to say, these things never happened during these years with Manjaro. I can’t speak about a couple of other machines I have, since I have just reinstalled the OS in them (these things seem to happen, as I said, after a number of reboots). I’m clueless about the cause of all of this; I tweak the machine for realtime audio work and do some other modifications, but I’ve been doing it for years and nothing weird ever happened. I wonder if it could be hardware-related (since the machine in which I have these issues is an I7 from 2013).
I even tried to switch the kernel from 6.9 to 6.6, but the problem persist. These things don’t reach (for now) the dealbreaker status (and I’d like not to move to another distro since Manjaro is the most convenient for me), but they are really weird and it feels rather uncomfortable to deal with all of this. I hope there can be a solution, if it’s not related to my hardware.
While I’m no Linux wizard, I’ve learnt a thing or two during these Manjaro years, and I’m certainly not afraid of the terminal. Any insight about this will be deeply appreciated.
Thanks in advance!
can you report
inxi -Fza
sudo mhwd -li
sudo mhwd-kernel -li
sudo journalctl -b0 -p err
pacman -Qdt
Impossible to say - provide the output
pacman -Qqem
Some ideas to check
  • disk failure
  • no swap
Please elaborate - and please document the tweaks and the modifications
> System:
>   Kernel: 6.6.40-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
>     clocksource: tsc avail: hpet,acpi_pm
>     parameters: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
>     root=UUID=5a881853-ce3b-42ad-a147-25a3a2922892 rw threadirqs
>     mitigations=off cpufreq.default_governor=performance quiet splash
>     udev.log_priority=3
>   Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
>     with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
>     Distro: Manjaro base: Arch Linux
> Machine:
>   Type: Desktop Mobo: ASUSTeK model: P8H77-V LE v: Rev X.0x
>     serial: <superuser required> part-nu: SKU uuid: <superuser required>
>     UEFI: American Megatrends v: 1001 date: 02/04/2013
> Battery:
>   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M280/320/275
>     serial: <filter> charge: 55% (should be ignored) rechargeable: yes
>     status: discharging
>   Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
>     serial: <filter> charge: 100% (should be ignored) rechargeable: yes
>     status: discharging
> CPU:
>   Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
>     gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
>     model-id: 0x3A (58) stepping: 9 microcode: 0x21
>   Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
>     L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
>     L3: 8 MiB desc: 1x8 MiB
>   Speed (MHz): avg: 3015 high: 3900 min/max: 1600/3900 scaling:
>     driver: intel_cpufreq governor: performance cores: 1: 2882 2: 2000 3: 3702
>     4: 3348 5: 2792 6: 1600 7: 3900 8: 3900 bogomips: 56014
>   Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
>   Vulnerabilities:
>   Type: gather_data_sampling status: Not affected
>   Type: itlb_multihit status: KVM: VMX disabled
>   Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
>   Type: mds status: Vulnerable; SMT vulnerable
>   Type: meltdown status: Vulnerable
>   Type: mmio_stale_data status: Unknown: No mitigations
>   Type: reg_file_data_sampling status: Not affected
>   Type: retbleed status: Not affected
>   Type: spec_rstack_overflow status: Not affected
>   Type: spec_store_bypass status: Vulnerable
>   Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
>     usercopy barriers only; no swapgs barriers
>   Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
>     PBRSB-eIBRS: Not affected; BHI: Not affected
>   Type: srbds status: Vulnerable: No microcode
>   Type: tsx_async_abort status: Not affected
> Graphics:
>   Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: ASUSTeK P8 series
>     driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
>     active: HDMI-A-2 empty: DP-1, DP-2, HDMI-A-1, VGA-1 bus-ID: 00:02.0
>     chip-ID: 8086:0162 class-ID: 0300
>   Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0
>     driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
>     display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
>   Monitor-1: HDMI-A-2 model: Samsung S23C350 built: 2012 res: 1920x1080
>     dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23")
>     ratio: 16:9 modes: max: 1920x1080 min: 720x400
>   API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
>     device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
>     inactive: gbm,wayland
>   API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.1.3-manjaro1.1
>     glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
>     GT2) device-ID: 8086:0162 memory: 1.46 GiB unified: yes
> Audio:
>   Device-1: Intel 7 Series/C216 Family High Definition Audio
>     vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
>     chip-ID: 8086:1e20 class-ID: 0403
>   Device-2: M-Audio Fast Track Pro driver: snd-usb-audio type: USB rev: 1.1
>     speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.5:3 chip-ID: 0763:2012
>     class-ID: 0102
>   Device-3: M-Audio Keystation 88es driver: snd-usb-audio type: USB rev: 1.0
>     speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.7:6 chip-ID: 0763:0192
>     class-ID: 0103
>   API: ALSA v: k6.6.40-1-MANJARO status: kernel-api with: aoss
>     type: oss-emulator tools: alsactl,alsamixer,amixer
>   Server-1: JACK v: 1.9.22 status: active with: a2jmidid status: active
>     tools: cadence,jack_control
>   Server-2: PipeWire v: 1.2.1 status: off tools: pw-cli
>   Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
>     type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
> Network:
>   Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
>     vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
>     speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168
>     class-ID: 0200
>   IF: enp3s0 state: down mac: <filter>
>   Device-2: D-Link System DWA-125 Wireless N 150 Adapter(rev.A2) [Ralink
>     RT3070] driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
>     mode: 2.0 bus-ID: 3-3:2 chip-ID: 07d1:3c16 class-ID: 0000 serial: <filter>
>   IF: wlp0s20u3 state: up mac: <filter>
>   Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
> Drives:
>   Local Storage: total: 4.77 TiB used: 2.59 TiB (54.4%)
>   SMART Message: Required tool smartctl not installed. Check --recommends
>   ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: SSD2SC240G3LC709B121-460P
>     size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
>     tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
>   ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 2TB
>     size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
>     tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
>   ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 1TB
>     size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
>     tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
>   ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
>     model: WD2002FAEX-007BA0 size: 1.82 TiB block-size: physical: 512 B
>     logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05
>     scheme: MBR
> Partition:
>   ID-1: / raw-size: 216.57 GiB size: 212.11 GiB (97.94%)
>     used: 15.11 GiB (7.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
>   ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
>     used: 296 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
> Swap:
>   Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
>     compressor: zstd max-pool: 20%
>   ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
>     dev: /dev/sda3 maj-min: 8:3
> Sensors:
>   System Temperatures: cpu: 41.0 C mobo: N/A
>   Fan Speeds (rpm): N/A
> Info:
>   Memory: total: 32 GiB note: est. available: 31.04 GiB used: 2.16 GiB (7.0%)
>   Processes: 248 Power: uptime: 1h 54m states: freeze,mem,disk suspend: deep
>     avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
>     suspend, test_resume image: 12.4 GiB services: upowerd,xfce4-power-manager
>     Init: systemd v: 256 default: graphical tool: systemctl
>   Packages: pm: pacman pkgs: 1116 libs: 327 tools: pamac,yay Compilers:
>     gcc: 14.1.1 Shell: Bash v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.35
>     Warning: No installed PCI configs!
> Warning: No installed USB configs!
> Currently running: 6.6.40-1-MANJARO (linux66)
> The following kernels are installed in your system:
>    * linux610
>    * linux66
>    * linux69
>    * linux66-rt
>    * linux67-rt
And then, there are many blocks of these warning messages (in red in the original) :
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT1._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT1._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT2._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT2._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT4._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT5._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT5._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT0._GTF.DSSP], AE_NOT_FOUND (20230628/psargs-330)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT0._GTF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
> jul 27 11:07:02 sdg1441gat-systemproductname kernel: ldm_parse_tocblock(): Cannot find TOCBLOCK, database may be corrupt.
Finally, these lines :
alsa-card-profiles 1:1.2.1-1
aribb24 1.0.3-4
base-devel 1-3
lua 5.4.7-1
Regarding the installed programs :
cadence
chowbyod-bin
debtap
google-chrome
insync
insync-thunar
masterpdfeditor-free
rtapp
spotify
sublime-text-4
And the modifications for realtime audio, you can find them here :
GitHub - chmaha/ArchProAudio: A Pro Audio Tuning Guide for Arch (and other Arch-based distros)
Thank you for editing your post and changing the presentation of your terminal output from Blockquote to Preformatted text; it is much easier to read now. As a general practice, it is also helpful to include the initial command with the output, so that everyone knows what they are looking at. For example
$ pacman -Qdt
aribb24 1.0.3-4
base-devel 1-3
lua 5.4.7-1
While this may or may not be related, I note that kernel 6.7 reached EOL some 3 months (or more) ago; which means it’s no longer receiving any updates, security or otherwise.
If you do actually use the 6.7 rt it might be beneficial to switch back to 6.6 rt, and remove 6.7 rt, until the next realtime kernel is released.
I note that your mainboard has a BIOS update available;
albeit rather old, it’s more recent than the BIOS you’re currently using;
Perhaps it will make some difference:
P8H77-V LE BIOS 1307
Version 1307
4.19 MB
2014/05/09
Improve memory compatibility.
Did you remove any orphans at some point? Blindly removing them can unintentionally remove some important packages, so if you did, please post which orphans you removed.
Thanks so much for all the replies! Beginning with these ideas, I’ll check out the disk, you’re right. I’ve have had some debacle with a SSD in the past, so it’s a possibility. Regarding swap, I have 6 GBs of it (without hibernation) in a machine with 32 GBs of RAM, so I think that I’m fine with that…
Thanks for the suggestions, I’ll take note. These are my first posts here, and I was rather nervous yesterday with these issues.
Definitely! Anyway, I could even switch back to 6.9, since the issues appear the same in any context. For realtime audio work, I understand that the “normal” kernel is just fine with the threadirqs flag in grub…
Yes, you’re right. I never updated the BIOS. I’ll do it now, since these strange things are happening…
Good question… I can only think of two things :
  • I removed cmake dependencies while installing a couple of things (I don’t think this can be related, but I mention it anyway).
  • I removed all things pipewire, to use just Pulseaudio, ALSA and JACK. Maybe I erased something important?
Apart from these things, I didn’t really have too much time to break stuff, since I had just reinstalled the OS. I’ll do another reinstall today (since being Sunday, I have a couple of hours). I’ll try not to remove anything, to see if it does the same during these days. And I’ll check the disk and load the BIOS update, to see if there’s any improvement…
I’ll report back after all of this. Thanks again for the ideas!
Possibly. Though kernel 6.6.x is arguably the more stable, due to it being LTS.
That is also my understanding; and that one should ensure a Linux system is as stable as possible before considering a realtime kernel.
Yes, you’re right. I’ll switch to it…
I hear you, definitely! A couple of questions, regarding 6.6 : If I switch from 6.9 to 6.6, do I have to mark it as non-upgradable? That is, until I see that another LTS kernel is released? Or LTS kernels stay automatically without upgrades until another one of the same type appears?
And, besides, just out of curiosity : is the RT version of 6.6 supposed to be as stable as the “normal” one?
Regarding a possible disk failure : I did an extended test with GSmartControl and it showed no errors on the disk. I don’t know if there is another deeper way to check it…
They are different packages.
And you can have as many kernels installed as you like - with the ability to choose them at boot.
linux66 will continue to receive updates for as long as it is supported.
Which, according to kernel.org, will be until the end of 2026.
Thanks so much for the info!
I`ve just reinstalled Manjaro from scratch and…
  • I’m on Linux 6.6.40 (LTS)
  • I haven’t removed anything important (only a couple of pipewire things that didn´t remove any dependency)
  • There seem to be no errors in the disk
  • I have updated the BIOS
  • I did the usual audio tweaks that never cause any issue in the other machines (see above).
And still, after some reboots, the same happens : the background has no icons and Thunar behaves very strangely, as stated above. Really weird indeed…
This just sounds like the desktop is disabled.
I dont have an XFCE system to look at right now, but maybe check such settings.
I might wonder if thunar is just being slow to open.
Do you have network shares or similar? I recall this being a source of issues in the past.
As to thunar-root … you really should never do that.
No graphical program should be run as root/sudo.
No answers for this one. Dont know notepadqq, but if its qt maybe it has something to do with theming?
Sorry for the delay in the answer… Yes, that could be the case here. What do you recommend about it?
I have to click several times before it starts. Sometimes, the thunar process is seen on the task manager, but after a long while, nothing happens anyway. When I kill once or twice that process, then it starts. Sometimes, it even gives a warning sign saying that there is an input/output error. All of this doesn’t seem to happen before the desktop is supposedly disabled.
I know… I have only just used it to place some vst/vst3 plugins in a folder. But I see your point.
Maybe… The same applies with it as in the Thunar case. It seemingly starts to misbehave when the desktop appears as if it was disabled.
Should be something in Desktop Settings. (Settings Manager > Desktop)
I believe you can check/uncheck items in the Icons tab, but there should also be an option for “Icon Type” which if set to “None” would disable the interactive Desktop.
Please review settings in this area.
Though I just re-read that in the original situation you could not affect any changes to these settings.
Is this still the case?
Have you tried launching thunar from the terminal to see if it spits out anything useful?
Similarly you may go checking in the journal for any clues.
In the mean time I can leave some general ‘make sure you are up to date’ commands;
sudo pacman-mirrors --continent
sudo pacman -Syu
Oh, and so we can see what you did remove we can check the pacman log:
grep -i removed /var/log/pacman.log
Well, none of the settings there seem to change anything. No icons appears, no matter how many options you check/uncheck… Regarding the original situation, (which also happens right now), I can´t right-click in the background of the desktop to access the settings.
Well, the first time I try to run it, it shows this :
GDBus.Error:org.freedesktop.DBus.Error.NoReply: Remote peer disconnected
The second time :
(thunar:1294): thunarx-python-WARNING **: 08:36:41.831: g_module_open libpython failed: /usr/lib/lib.so.1.0: cannot open shared object file: No such file or directory
ImportError: could not import gobject (error was: ImportError('/usr/lib/python3.12/site-packages/gi/_gi.cpython-312-x86_64-linux-gnu.so: undefined symbol: PyUnicode_FromFormat'))
(thunar:1294): thunarx-python-WARNING **: 08:36:41.853: pygobject initialization failed
(thunar:1294): thunarx-python-WARNING **: 08:36:41.853: thunarx_python_init_python failed
  File "/usr/share/thunarx-python/extensions/insync-thunar-plugin.py", line 15, in <module>
    import socket
  File "/usr/lib/python3.12/socket.py", line 52, in <module>
    import _socket
ImportError: /usr/lib/python3.12/lib-dynload/_socket.cpython-312-x86_64-linux-gnu.so: undefined symbol: PyUnicode_FromFormat
Segmentation fault (core dumped)
And on a third try :
(thunar:1822): thunarx-python-WARNING **: 08:38:57.210: g_module_open libpython failed: /usr/lib/lib.so.1.0: cannot open shared object file: No such file or directory
(thunar:1822): thunarx-python-WARNING **: 08:38:57.233: pygobject initialization failed
(thunar:1822): thunarx-python-WARNING **: 08:38:57.233: thunarx_python_init_python failed
    import socket
    import _socket
On this third try, the process is stuck and I have to kill in the Task Manager.
Then, on the fourth try it runs, while giving these lines in the terminal :
(thunar:1872): thunarx-python-WARNING **: 08:40:58.308: g_module_open libpython failed: /usr/lib/lib.so.1.0: cannot open shared object file: No such file or directory
(thunar:1872): thunarx-python-WARNING **: 08:40:58.332: pygobject initialization failed
(thunar:1872): thunarx-python-WARNING **: 08:40:58.332: thunarx_python_init_python failed
    import socket
    import _socket
(thunar:1872): thunar-WARNING **: 08:40:58.558: Name 'org.freedesktop.FileManager1' lost on the message dbus.
I`ll show the output of the journalctl command. In the beginning it says “Linux 6.9.5-1”, but I’m on 6.6.40-1 right now (at some point, it just changed to 6.9 again without my intervention, and I had to revert to 6.6 at boot. I thought that once you chose a kernel, it just kept loading it on every boot…
jul 28 19:39:33 systemproductname kernel: Linux version 6.9.5-1-MANJARO (builduser@fv-az977-530) (gcc (GCC) 14.1.1 20240522, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC >
jul 28 19:39:33 systemproductname kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64 root=UUID=5404206a-9952-4657-863b-41418bacc6c9 rw quiet splash udev.log_priority=3
jul 28 19:39:33 systemproductname kernel: BIOS-provided physical RAM map:
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000040005000-0x00000000cc534fff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cc535000-0x00000000cc9b7fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cc9b8000-0x00000000cc9c7fff] ACPI data
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cc9c8000-0x00000000ccaecfff] ACPI NVS
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000ccaed000-0x00000000cd800fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cd801000-0x00000000cd801fff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cd802000-0x00000000cd844fff] ACPI NVS
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cd845000-0x00000000cdc77fff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cdc78000-0x00000000cdff3fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cdff4000-0x00000000cdffffff] usable
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000cf000000-0x00000000df1fffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
jul 28 19:39:33 systemproductname kernel: BIOS-e820: [mem 0x0000000100000000-0x000000081fdfffff] usable
jul 28 19:39:33 systemproductname kernel: NX (Execute Disable) protection: active
jul 28 19:39:33 systemproductname kernel: APIC: Static calls initialized
jul 28 19:39:33 systemproductname kernel: e820: update [mem 0xb53dc018-0xb53ec057] usable ==> usable
jul 28 19:39:33 systemproductname kernel: e820: update [mem 0xb53cf018-0xb53db857] usable ==> usable
jul 28 19:39:33 systemproductname kernel: extended physical RAM map:
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x000000000009f000-0x000000000009ffff] reserved
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000000100000-0x000000001fffffff] usable
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000020000000-0x00000000201fffff] reserved
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000020200000-0x0000000040003fff] usable
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000040004000-0x0000000040004fff] reserved
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x0000000040005000-0x00000000b53cf017] usable
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x00000000b53cf018-0x00000000b53db857] usable
jul 28 19:39:33 systemproductname kernel: reserve setup_data: [mem 0x00000000b53db858-0x00000000b53dc017] usable
lines 1-41
I’m up to date…
You can see here that only a handful of Pipewire things were removed :
[2024-07-28T21:02:09-0300] [ALPM] removed pipewire-alsa (1:1.2.1-1)
[2024-07-28T21:02:09-0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/user/sockets.target.wants/pipewire-pulse.socket'.
[2024-07-28T21:02:09-0300] [ALPM] removed pipewire-pulse (1:1.2.1-1)
[2024-07-28T21:19:48-0300] [ALPM] removed manjaro-pipewire (20231009-1)
[2024-07-28T21:33:12-0300] [ALPM] removed qjackctl (1.0.0-1)
I finally discovered what was causing the desktop debacle in my system : an aur package related to Insync, the application I use to sync my Google Drive folder across computers. The package is insync-thunar, and it simply broke the desktop due to some python stuff mess. I removed it with yay -Rsn and voilá! The XFCE desktop returned as usual…
Nevertheless, thanks so much for all the replies!
