Need some help.
How to keep storage HDD’s instandby/spun down and not be affected by udisks?
Since on AM5 since mid November, after the 1st Ahn-Linh prev update with 6.18.0 release, I am encountering an issue where my external USB storage HDD’s keep spinning up from standby (spun down) state, every 10 minutes.
No difference if they are mounted (via fstab) or not. This did not happen on my former system, til the upgrade to AM5 and or the 1st Ahn-Linh update.
Journalctl logs show the following entries each time for the drive that I added in fstab to be auto mounted:
jan 06 10:04:04 Infinity kernel: sd 6:0:0:0: [sdc] tag#26 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
jan 06 10:04:04 Infinity kernel: sd 6:0:0:0: [sdc] tag#26 CDB: ATA command pass through(16) 85 06 20 00 00 00 00 00 00 00 00 00 00 00 e5 00
jan 06 10:04:04 Infinity kernel: scsi host6: uas_eh_device_reset_handler start
jan 06 10:04:04 Infinity kernel: usb 4-1: reset SuperSpeed USB device number 2 using xhci_hcd
jan 06 10:04:04 Infinity kernel: scsi host6: uas_eh_device_reset_handler success
jan 06 10:04:04 Infinity udisksd[1558]: Error performing housekeeping for drive /org/freedesktop/UDisks2/drives/Hitachi_HDS721010CLA332_JP9921HD30YDXH: Error updating SMART data: Error sending ATA command CHECK POWER MODE: Unexpected sense data returned:
0000: 70 00 02 00 00 00 00 0a 00 00 00 00 04 01 00 00 p...............
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
(g-io-error-quark, 0)
Looking into this seem to indicates udisks systemd service is the issue running every 10 minutes.
Stopping/disabling udisks2.service, as a workaround mentioned in the below github link, does temporarily fixes the spinning issue but leads to issues with removeable media like USB sticks.
Also udisks2.service even when disabled is restarted when mounting one of my external driver leading again to the spin down and up cycle every 10 minutes.
On Stack Exchange there was a similar topic posted 4 months ago: https://unix.stackexchange.com/questions/799483/a-way-to-disable-udisks-housekeeping-short-of-disabling-udisks
It mentions from the Arch wiki Udisks#Broken_standby_timer. Udisk polling for SMART status every 10 minutes has a long standing bug so it seems.
Also there is an issue tracker on udisks github page that goes into this exact issue:
Hdparm output of oneof the drives:
[sudo] password for gkirmathal:
/dev/sdc:
ATA device, with non-removable media
Model Number: Hitachi HDS721010CLA332
Serial Number: JP9921HD30YDXH
Firmware Revision: JP4OA3MA
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6; Revision: ATA8-AST T13 Project D1697 Revision 0b
Standards:
Used: unknown (minor revision code 0x0029)
Supported: 8 7 6 5
Likely used: 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 1953525168
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 953869 MBytes
device size with M = 1000*1000: 1000204 MBytes (1000 GB)
cache/buffer size = 29999 KBytes (type=DualPortCache)
Form Factor: 3.5 inch
Nominal Media Rotation Rate: 7200
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 0
Advanced power management level: disabled
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
Security Mode feature set
* Power Management feature set
* Write cache
* Look-ahead
* Host Protected Area feature set
* WRITE_BUFFER command
* READ_BUFFER command
* DOWNLOAD_MICROCODE
* Advanced Power Management feature set
Power-Up In Standby feature set
* SET_FEATURES required to spinup after power up
SET_MAX security extension
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
Media Card Pass-Through
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* URG for READ_STREAM[_DMA]_EXT
* URG for WRITE_STREAM[_DMA]_EXT
* WRITE_UNCORRECTABLE_EXT command
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Host-initiated interface power management
* Phy event counters
* NCQ priority information
Non-Zero buffer offsets in DMA Setup FIS
DMA Setup Auto-Activate optimization
Device-initiated interface power management
In-order data delivery
Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Write Same (AC2)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
Security:
Master password revision code = 65534
supported
not enabled
not locked
not frozen
not expired: security count
not supported: enhanced erase
232min for SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000cca373eab4f0
NAA : 5
IEEE OUI : 000cca
Unique ID : 373eab4f0
Checksum: correct
lsusb -t output:
lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 005: Dev 002, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 004, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 004, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 004, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 001: Dev 004, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 006, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 006, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 008, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 008, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 010: Dev 003, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 011: Dev 005, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 011: Dev 005, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 012: Dev 007, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 4, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 5, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 6, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 012: Dev 007, If 7, Class=Human Interface Device, Driver=usbhid, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/5p, 20000M/x2
|__ Port 005: Dev 002, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
|__ Port 001: Dev 002, If 0, Class=Mass Storage, Driver=uas, 5000M
/: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 007.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 480M
inxi -v7azy system info:
Kernel: 6.18.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw plymouth.enable=0
disablehooks=plymouth quiet splash udev.log_priority=3
video=DP-1:3440x1440MR@160 amd_pstate=active amd_prefcore=enable
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Desktop Mobo: Micro-Star model: MAG B850M MORTAR WIFI (MS-7E61) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.A45 date: 09/10/2025
System RAM: total: 32 GiB available: 30.4 GiB used: 5.25 GiB (17.3%)
Device-1: DIMMA1 type: no module installed
Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: N/A
part-no: IR-6400D564L32S/16G serial: <filter>
Device-3: DIMMB1 type: no module installed
Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3798 min/max: 426/4201 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3798 2: 3798 3: 3798
4: 3798 5: 3798 6: 3798 7: 3798 8: 3798 9: 3798 10: 3798 11: 3798 12: 3798
13: 3798 14: 3798 15: 3798 16: 3798 bogomips: 134400
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse pse36
rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, HDMI-A-1,
HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: HDMI-A-3,Writeback-2 bus-ID: 11:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 34.0 C
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: AOC CU34G2XP serial: <filter> built: 2024 res:
mode: 3440x1440 hz: 160 scale: 100% (1) dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.6 DRM 3.64 6.18.2-1-MANJARO) device-ID: 1002:7550
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.1-arch1.2
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 7800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 25.3.1-arch1.2 device-ID: 1002:164e surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:7
chip-ID: 0db0:cc78 class-ID: 0300
Device-5: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.1:4 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.18.2-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169 v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
chip-ID: 10ec:8126 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 2
bus-ID: 0d:00.0 chip-ID: 17cb:1107 class-ID: 0280
IF: wlp13s0 state: down mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:5 chip-ID: 0489:e10a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 6.41 TiB used: 2.1 TiB (32.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.23 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM32.1 temp: 30.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 2TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%)
used: 413.98 GiB (49.1%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: N/A uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 402.77 GiB (47.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/data2 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 480.26 GiB (29.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: DATA2
uuid: 4de3dfe5-98c9-438d-9fef-7bd41d5bf67f
ID-5: /mnt/data3 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 262.43 GiB (15.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: DATA3
uuid: e14912f2-9e23-418f-9a32-6eca47b43d8f
ID-6: /mnt/storage raw-size: 755.73 GiB size: 755.73 GiB (100.00%)
used: 586.38 GiB (77.6%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: STORAGE
uuid: B0A0696BA069394C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdc2 maj-min: 8:34 size: 175.78 GiB fs: ext4 label: STORAGE_BACKUP
uuid: b2548556-eb55-44c4-bc73-91b7499dee60
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 1-5.1:4 info: Texas Instruments PCM2902 Audio Codec
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 1-5.3:6 info: Sharkoon SHARK Force 3 type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1440 class-ID: 0300
Device-3: 1-5.4:8 info: SONiX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 320f:500c class-ID: 0301
Device-4: 1-10:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
serial: <filter>
Device-5: 1-11:5 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e10a class-ID: e001
Device-6: 1-12:7 info: Micro Star USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-4: 2-5:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Device-1: 4-2:2 info: JMS578 based SATA bridge type: mass storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 8mA chip-ID: 0080:a001 class-ID: 0806
serial: <filter>
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 39.6 C mobo: N/A
Fan Speeds (rpm): fan-1: 511 fan-2: 0 fan-3: 0 fan-4: 0 fan-13: 709
fan-14: 0 fan-15: 0 fan-16: 635
GPU: device: amdgpu temp: 32.0 C mem: 56.0 C fan: 0 watts: 22.00
device: amdgpu temp: 35.0 C
Power: 12v: 11.90 5v: 4.96 3.3v: 3.30 vbat: 1.84
Processes: 410 Power: uptime: 39m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1561 libs: 436 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
inxi: 3.3.40
