Hey guys!
I get curious problem: when i try attach some file to Trello card i see unredadble letters. There are no problems on other electron applications.
screenshot:
https://paste.pics/19859c4214854f6728c861831650790f
Hey guys!
screenshot:
Welcome to Manjaro forum
AUR packages trello
and trello-bin
use the same github source that shows code has not been updated for 4 years
And this question posted over a year ago has not been has not been answered
Is this project still maintained? · Issue #79 · danielchatfield/trello-desktop · GitHub
These packages appear to be out of date and abandoned
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
