Issue with Steam
I am having this issue when i run prime-run steam
steam.sh[66101]: Running Steam on manjarolinux 24.0.1 64-bit
steam.sh[66101]: STEAM_RUNTIME is enabled automatically
setup.sh[66174]: Steam runtime environment up-to-date!
steam.sh[66101]: Steam client's requirements are satisfied
[2024-06-01 12:26:19] Startup - updater built May 24 2024 20:46:19
[2024-06-01 12:26:19] Startup - Steam Client launched with: '/home/<usrname>/.local/share/Steam/ubuntu12_32/steam'
06/01 12:26:19 minidumps folder is set to /tmp/dumps
06/01 12:26:19 Init: Installing breakpad exception handler for appid(steam)/version(1716584667)/tid(66230)
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Then the process just hangs up. Any ideas?
Output of inxi -Fz
  Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 46.2 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Nitro AN515-43 v: V1.12
    serial: <superuser required>
  Mobo: PK model: Octavia_PKS v: V1.12 serial: <superuser required>
    UEFI: Insyde v: 1.12 date: 11/05/2020
  ID-1: BAT1 charge: 38.0 Wh (100.0%) condition: 38.0/57.5 Wh (66.1%)
  Info: quad core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP cache: L2: 2 MiB
  Speed (MHz): avg: 2276 min/max: 1400/2100 cores: 1: 3692 2: 3693 3: 2462
    4: 2462 5: 1477 6: 1475 7: 1477 8: 1477
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia
    v: 550.78
  Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel
  Device-3: Quanta HD User Facing driver: uvcvideo type: USB
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 driver:
    X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon dri: radeonsi
    gpu: amdgpu resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
    renderer: AMD Radeon Vega 8 Graphics (radeonsi raven LLVM 17.0.6 DRM 3.54
    6.6.32-1-MANJARO)
  API: Vulkan v: 1.3.279 drivers: radv surfaces: xcb,xlib
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  API: ALSA v: k6.6.32-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.0.7 status: active
    driver: r8169
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  Device-1: Lite-On driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 136.48 GiB (14.7%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
  ID-1: / size: 318.83 GiB used: 136.48 GiB (42.8%) fs: ext4 dev: /dev/sda7
  ID-2: /boot/efi size: 4.99 GiB used: 300 KiB (0.0%) fs: vfat
    dev: /dev/sda8
  System Temperatures: cpu: 72.4 C mobo: N/A gpu: amdgpu temp: 72.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 13.59 GiB used: 8.44 GiB (62.1%)
  Processes: 362 Uptime: 2d 2h 6m Shell: Zsh inxi: 3.3.34
Any help would be appropriated. Thanks in advance.
Moderator edit: Fix formatting typo
This is not advisable.
Instead the suggestion is to add prime-run to a games launch options, like
prime-run %command%
PS.
As it seems you are having trouble formatting your post here is a guide.
Thanks. That Helps.
