Hello, I’m having problems when taking screenshots, a spectacle message appears saying remote peer disconected at the moment I press the scrn img button. this started to happen after installed the gpu switcher from plasma. now to take a screenshot i have to change the mode to integrated, reboot, etc. Is there a way to fix this? Thank you.
Kernel: 6.7.11-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=c30ba29b-0487-47e7-aafd-cf612d8e3c3f rw quiet splash
resume=UUID=b542c1fa-dcdd-41be-9763-9fc132d06814 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Acer product: Nitro AN515-44 v: V1.04
serial: <superuser required>
Mobo: RO model: Stonic_RNS v: V1.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.04
date: 02/04/2021
ID-1: BAT1 charge: 19.8 Wh (50.5%) condition: 39.2/57.5 Wh (68.3%)
volts: 16.0 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: charging
Device-1: hid-f4:73:35:9f:dc:37-battery model: Keyboard K380 serial: N/A
charge: N/A status: N/A
System RAM: total: 16 GiB available: 15 GiB used: 4.94 GiB (32.9%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 8ATF1G64HZ-3G2J1 serial: <filter>
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1699 high: 3218 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1396
3: 1397 4: 1400 5: 2900 6: 1397 7: 1397 8: 1400 9: 1397 10: 1400 11: 3218
12: 1397 13: 1400 14: 1400 15: 1397 16: 2900 bogomips: 92662
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 550.67
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: Acer Incorporated ALI
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 39.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0408:a061
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1745x982 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.4-manjaro1.1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.57 6.7.11-3-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.67 device-ID: 10de:1f99
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: mesa radv v: 24.0.4-manjaro1.1.1
device-ID: 1002:1636 surfaces: xcb,xlib,wayland
Device-1: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated ALI
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.11-3-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
lmp-v: 11 sub-v: 20f9 hci-v: 11 rev: 20f9 class-ID: 6c010c
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 1.14 TiB used: 462.05 GiB (39.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1014 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 21103900 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-21Z10T0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 221.67 GiB size: 217.13 GiB (97.95%)
used: 73.94 GiB (34.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c30ba29b-0487-47e7-aafd-cf612d8e3c3f
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: EC51-31E9
ID-3: /data raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 388.11 GiB (42.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 759f8476-f3a7-4349-9c7a-f9842ff6395f
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 16.5 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: b542c1fa-dcdd-41be-9763-9fc132d06814
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-1: 3-3:2 info: Quanta HD User Facing type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:a061 class-ID: 0e02
System Temperatures: cpu: 55.1 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): N/A
Processes: 372 Power: uptime: 1h 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1615 libs: 497 tools: pamac,yay Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.33
