I recently updated my system to kernel version 6.8.5-1-MANJARO and am now encountering an issue when trying to use Snap packages. The error occurs when I attempt to install or update Snap packages.
Error Message:
error: system does not fully support snapd: cannot mount squashfs image using "squashfs":
mount: /tmp/syscheck-mountpoint-2375228621: /dev/loop0 is already mounted or busy.
dmesg(1) might provide more information after a failed mount system call.
System Details:
Kernel Version: 6.8.5-1-MANJARO
Snap Version: 2.61.2
Affected Packages: Attempts to update/install Anydesk
Steps Taken to Troubleshoot:
Checked and restarted snapd.
Checked loop devices with losetup -a, found no active loop devices.
Reinstalled snapd.
Various kernel modules (including squashfs) have been checked and are loaded.
Despite these steps, the problem persists. I am wondering if the recent kernel update could be playing a role and whether anyone has had similar experiences or suggestions for resolving this issue.
Thank you in advance for any assistance or insights you can provide!
What does it say? dmesg | less
then scroll through using page up /page down - the arrow keys
or journalctl --reverse
and go back in time the same way …
Can you not install and use an LTS kernel instead of what appears to be a very new one?
I do not use snaps and have zero experience with them.
KDE has got an app to view the systemd journal (the log) as well if I recall correctly.
But terminal output may be easier to obtain and possibly share.
Hey, thanks for the quick reply. Well - I tried to switch back to the latest LTE Kernel and the Problem is gone. Not really sure whats the problem, I did not check the logs though.
Anyways, thanks for quick help. Topic can be closed.
You may choose to investigate further.
It may depend on your hardware … or it may be a “known” problem with that kernel and snap, as @Yochanan just said.
I’d always choose the way that he chose - use what works.
Except when I’m curious.
