Hi, I’m using Manjaro Openbox and currently I’ve got the issue with third monitor. It’s connected via USB-C and it works, but the problem is when 2 monitors are connected in the same time. After that monitor that is plugged into HDMI2 disapears. When I plug off the monitor on HDMI2 slot the one on DP2 works.
For me it looks like the graphic card problem, but it works earlier, so i don’t know where might be the problem.
Here is an output with both cable attachted:
Blockquote
~ >>> inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 4.19.139-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=c4d78379-5dde-406d-b12d-5569d0b566fd rw quiet
resume=UUID=36ce07c9-46d2-4e8e-8a16-2885c72314d0
Desktop: Xfce info: tint2, polybar, docker wm: Openbox 3.6.1 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20N2S1S100 v: ThinkPad T490 serial: Chassis: type: 10
serial:
Mobo: LENOVO model: 20N2S1S100 serial: UEFI: LENOVO v: N2IET75W (1.53 ) date: 08/21/2019
Battery: ID-1: BAT0 charge: 51.5 Wh condition: 51.5/50.5 Wh (102%) volts: 12.9/11.6 model: LGC 02DL007
type: Li-poly serial: status: Full cycles: 10
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545 serial: charge: Full
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: charge: Normal
status: Discharging
Memory: RAM: total: 15.45 GiB used: 4.20 GiB (27.2%)
CPU: Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: C (12) microcode: D6 L2 cache: 8192 KiB bogomips: 31872
Speed: 1087 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 1298 2: 1141 3: 1779 4: 1190 5: 1371 6: 1635
7: 1463 8: 1129
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2
bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: srbds mitigation: TSX disabled
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3ea0
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:4 chip ID: 13d3:56bc
serial:
Display: x11 server: XOrg 1.20.8 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3") s-diag: 1055mm (41.6")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: DP2 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k4.19.139-1-MANJARO
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3
chip ID: 8086:9df0
IF: wlp0s20f3 state: up mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
chip ID: 8086:15be
IF: enp0s31f6 state: down mac:
IF-ID-1: br-1daa30316e39 state: up speed: N/A duplex: N/A mac:
IP v4: scope: global broadcast:
IP v6: scope: link
IF-ID-2: docker0 state: down mac:
IF-ID-3: veth016eee1 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-4: veth08e65aa state: up speed: 10000 Mbps duplex: full mac:
IF-ID-5: veth42d85f3 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-6: veth45ab949 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-7: veth4ea4956 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-8: veth5fbf53e state: up speed: 10000 Mbps duplex: full mac:
IF-ID-9: veth642fa58 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-10: veth6aae204 state: up speed: 10000 Mbps duplex: full mac:
IF-ID-11: vethbe964fa state: up speed: 10000 Mbps duplex: full mac:
IF-ID-12: vethd47f3ce state: up speed: 10000 Mbps duplex: full mac:
IF-ID-13: vethdb6581c state: up speed: 10000 Mbps duplex: full mac:
IF-ID-14: vethfc7b9aa state: up speed: 10000 Mbps duplex: full mac:
WAN IP:
Drives: Local Storage: total: 476.94 GiB used: 97.56 GiB (20.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 SDBQNTY-512G-1001 size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: rev: 11110101
scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 459.65 GiB size: 451.43 GiB (98.21%) used: 97.56 GiB (21.6%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: c4d78379-5dde-406d-b12d-5569d0b566fd
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 264 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 3384-BBAA
ID-3: /run/timeshift/backup raw size: 459.65 GiB size: <superuser/root required>
used: <superuser/root required> fs: ext4 dev: /dev/nvme0n1p2 label: N/A
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 17.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
label: N/A uuid: 36ce07c9-46d2-4e8e-8a16-2885c72314d0
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:7 info: Realtek BillBoard Device type: Billboard driver: N/A interfaces: 1 rev: 2.0
speed: 12 Mb/s chip ID: 0bda:2172 serial:
Device-2: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
Device-3: 1-8:4 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s chip ID: 13d3:56bc serial:
Device-4: 1-9:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader type:
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:00bd serial:
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3527
Info: Processes: 403 Uptime: 29m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1105 lib: 237
Shell: Zsh v: 5.8 running in: termite inxi: 3.1.05
After plugged off USB-C:
Blockquote
serial:
Battery: ID-1: BAT0 charge: 51.5 Wh condition: 51.5/50.5 Wh (102%) volts: 12.9/11.6 model: LGC 02DL007 type: Li-poly
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: charge: Normal status: Discharging
Memory: RAM: total: 15.45 GiB used: 4.23 GiB (27.4%)
CPU: Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
Speed: 3218 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2
bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
serial:
Display: x11 server: XOrg 1.20.8 driver: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Monitor-2: HDMI2 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
chip ID: 8086:9df0
chip ID: 8086:15be
IP v6: scope: link
WAN IP:
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 SDBQNTY-512G-1001 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: rev: 11110101 scheme: GPT
Partition: ID-1: / raw size: 459.65 GiB size: 451.43 GiB (98.21%) used: 97.56 GiB (21.6%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 264 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /run/timeshift/backup raw size: 459.65 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/nvme0n1p2 label: N/A uuid: c4d78379-5dde-406d-b12d-5569d0b566fd
ID-1: swap-1 type: partition size: 17.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 label: N/A
Device-1: 1-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
Device-2: 1-8:4 info: IMC Networks Integrated Camera type: Video driver: uvcvideo interfaces: 4 rev: 2.0
Device-3: 1-9:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader type: driver: N/A
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3504
Info: Processes: 405 Uptime: 31m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1105 lib: 237 Shell: Zsh
After plug-in USB-C it’s connecting into DP2 and HDMI2 is turned off. I’ve got no idea what’s the problem.
