Hi there, for the past while I’m unable to proceed with application updates via the pacman gui: I keep getting error as per below:
I’ve tried a good few things trying to sort it out to no avail.
Any help would be greately appreciated, Thank you
Cheers Awesome Community!
sudo pacman-mirrors -f && sudo pacman -Syyu && yay -Syu
cscs
3
Since your DB is corrupted…
sudo pacman -Syu && sudo pacman -Fy
Thank you for the prompt reply I proceeded with it and now I’m getting the same prompt errors:
Might be way off with this but might be related to this
try updating with pacman and then see if pamac is working again
