Issue with Nvidia proprietary drivers on 3840x1600 monitor
Hi
  • I have a RTX 3060 12GB
  • I have a 38-inch LG monitor with PIP/PBP functionality, resolution 3840x1600
  • I’m running the latest Manjaro with kernel 6.14.6, with Nvidia proprietary drivers 5.70
Technical datas
  Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=51278d26-f3e5-4389-b628-98b88f89bc0b rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 3222 date: 03/05/2025
  System RAM: total: 32 GiB available: 31 GiB used: 4.87 GiB (15.7%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 6000 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: KF560C30-16 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A level: v4
    note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
    microcode: 0xB404023
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2985 min/max: 600/5271 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2985 2: 2985 3: 2985
    4: 2985 5: 2985 6: 2985 7: 2985 8: 2985 9: 2985 10: 2985 11: 2985 12: 2985
    13: 2985 14: 2985 15: 2985 16: 2985 bogomips: 150399
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext bus_lock_detect
    cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc
    cpb cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe movdir64b movdiri msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_adjust tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd
    wdt x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
    bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4.2.3:10
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
    s-diag: 1165mm (45.88")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled
    model: LG (GoldStar) ULTRAWIDE serial: <filter> built: 2025 res:
    mode: 3840x2160 hz: 120 scale: 100% (1) dpi: 111 gamma: 1.2
    size: 880x370mm (34.65x14.57") diag: 573mm (22.6") ratio: 5:4 modes:
    max: 1920x1600 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  API: Vulkan v: 1.4.313 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 570.144 device-ID: 10de:2504
    surfaces: N/A
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 0b05:1a52 class-ID: 0300
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  Device-4: C-Media BIRD UM1 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.4.2.4:12
    chip-ID: 0d8c:0134 class-ID: 0300
  Device-5: Realtek LG Monitor Headset MIC driver: hid-generic,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4.3.4.2:11
    chip-ID: 0bda:4c8d class-ID: 0300
  API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:125c
    class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 09:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp9s0 state: down mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.4.4:6
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp13s0f4u2u4u4 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5 chip-ID: 0489:e0e2
  Local Storage: total: 10.92 TiB used: 56.05 GiB (0.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 31.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 25.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
  ID-1: / raw-size: 931.4 GiB size: 931.4 GiB (100.00%) used: 56.02 GiB (6.0%)
    fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:8 label: N/A
    uuid: 51278d26-f3e5-4389-b628-98b88f89bc0b
    used: 32 MiB (33.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4 label: N/A
    uuid: 186C-93B7
  ID-3: /home raw-size: 931.4 GiB size: 931.4 GiB (100.00%)
    used: 56.02 GiB (6.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:8
    label: N/A uuid: 51278d26-f3e5-4389-b628-98b88f89bc0b
  ID-4: /var/cache raw-size: 931.4 GiB size: 931.4 GiB (100.00%)
  ID-5: /var/log raw-size: 931.4 GiB size: 931.4 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:6 size: 930.87 GiB fs: ntfs
    label: Windows11 uuid: 147E6E3E7E6E18AE
  ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 657 MiB fs: ntfs label: N/A
    uuid: 8C2627042626EEC0
  ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 1.82 TiB fs: ntfs label: Gaming
    uuid: 34DEF050DEF00C3C
  ID-6: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
  ID-7: /dev/sda2 maj-min: 8:2 size: 1.63 TiB fs: ntfs
    label: Legacy 3#1 - Torrent uuid: 648A98478A98179E
  ID-8: /dev/sda4 maj-min: 8:4 size: 1.82 TiB fs: ntfs label: Legacy 3#2 - DF
    uuid: A42266E02266B748
  ID-9: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs label: Download
    uuid: 546A1B0061366AC4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11:5 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-8: 5-2.4:3 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-9: 5-2.4.2:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 5-2.4.2.1:6 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 5-2.4.2.2:8 info: Nordic NuPhy Air75 V2 Dongle type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 19f5:3247 class-ID: 0300
  Device-3: 5-2.4.2.3:10 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-4: 5-2.4.2.4:12 info: C-Media BIRD UM1 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Hub-10: 5-2.4.3:5 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
  Hub-11: 5-2.4.3.4:7 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 5-2.4.3.4.1:9 info: LG USA 27UP850 - WK.AEUDCSN External Monitor
    4K type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a39 class-ID: 0a00 serial: <filter>
  Device-2: 5-2.4.3.4.2:11 info: Realtek LG Monitor Headset MIC type: HID
  Hub-12: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-13: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-14: 6-2.4:3 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-15: 6-2.4.2:4 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
  Hub-16: 6-2.4.3:5 info: Realtek Hub ports: 4 rev: 3.2
  Device-1: 6-2.4.4:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-17: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-18: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 44.5 C mobo: 30.0 C gpu: nvidia temp: 41 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Processes: 419 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1684 pm: pacman pkgs: 1661 libs: 340 tools: pamac pm: flatpak
    pkgs: 23 Compilers: clang: 19.1.7 gcc: 15.1.1 alt: 14 Shell: fish v: 4.0.2
    running-in: blackbox inxi: 3.3.38
Problem description
This issue occurs on both Gnome and KDE, under both Wayland and X11. When using the open-source Nvidia driver, everything works fine. However, I need to work with CUDA, PyTorch, etc., which require the proprietary drivers.
When I switch to the proprietary Nvidia driver (Manjaro installs version 5.70), I no longer get a login screen. My monitor just turns on and off repeatedly with a black screen. The monitor becomes unresponsive - I cannot access its menu. I also cannot access terminals using CTRL+ALT+Fn key combinations.
Interestingly, when I activate PBP mode (Picture by Picture - displaying two sources on my screen, with Manjaro only showing on half the screen at 1920x1600), everything works normally! Manjaro functions without any issues in this configuration.
I’ve read that Wayland/SDDM/GDM can have issues with Nvidia drivers, but I haven’t been able to resolve my problem.
Help would be greatly appreciated!
Not much technical info for support, but a data point to give you hope:
Manjaro KDE kernel 6.14.6 running 3840x2160 running flawlessly in X11 on a Dell U3219Q monitor.
NVidia RTX 4070ti and proprietary NVidia 570.144
Last time on Wayland a few weeks ago I still had some drag/drop/smearing/misalignment flaws but those are becoming far less common as time goes on. About ready to switch to Wayland full time.
Good luck
Hi
Your configuration looks quite like mine. I have tried so many combinations to make it work that i think i am in a dead end :slight_smile:
