Issue with hibernation
Hello, this is my first post on this forum, so Hi everyone, I started using Manjaro last month so far experience have been good, it is quite stable compared to other Distributions, however I’ve experienced issues with hibernation and suspend because of that I cannot resume my work and my battery drains very fast. Also last update for 400+ packages caused some issues with my AMD GPU driver apparently, when I boot up I get some message but it’s too fast to look up, however I’ve found boot log. And lastly my grubs not working when I try to enter I am redirected to grub rescue.
Update : Updated title and here’s boot log anyway
------------ Sat Nov 20 02:54:45 IST 2021 ------------
ERROR: resume: hibernation device '/dev/mapper/luks-b3eb71b7-9b8e-4fbd-8d09-02112522ec54' not found
e%@Info: Fix the reported corruption.
Info: Segments per section = 1
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 981129369 (479067 MB)
Info: MKFS version
  "Linux version 5.13.19-2-MANJARO (builduser@fv-az39-393) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021"
Info: FSCK version
  from "Linux version 5.13.19-2-MANJARO (builduser@fv-az39-393) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021"
    to "Linux version 5.13.19-2-MANJARO (builduser@fv-az39-393) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021"
Info: superblock features = 0 :
Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
Info: total FS sectors = 981129368 (479067 MB)
Info: CKPT version = 562fecc6
Info: checkpoint state = 45 :  crc compacted_summary unmount
Info: No error was reported
[e[0;1;31mFAILEDe[0m] Failed to activate swap e[0;1;39m/d…7-9b8e-4fbd-8d09-02112522ec54e[0m.
[e[0;1;38;5;185mDEPENDe[0m] Dependency failed for e[0;1;39mSwapse[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mTell Plymouth To Write Out Runtime Datae[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mCreate Volatile Files and Directoriese[0m.
         Starting e[0;1;39mRebuild Journal Cataloge[0m...
         Starting e[0;1;39mRecord System Boot/Shutdown in UTMPe[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mRecord System Boot/Shutdown in UTMPe[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mRebuild Journal Cataloge[0m.
         Activating swap e[0;1;39m/dev/disk/…9b8e-4fbd-8d09-02112522ec54e[0m...
See 'systemctl status "dev-disk-by\\x2d…09\\x2d02112522ec54.swap"' for details.
[e[0;32m  OK  e[0m] Finished e[0;1;39mRebuild Dynamic Linker Cachee[0m.
         Starting e[0;1;39mUpdate is Completede[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mUpdate is Completede[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSystem Initializatione[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mCUPS Schedulere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily rotation of log filese[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily man-db regeneratione[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mMonthly clean packages cachee[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mGenerate mirrorlist weeklye[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mpkgfile database update timere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily verification of password and group filese[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mDaily Cleanup of Temporary Directoriese[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mPath Unitse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mTimer Unitse[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mCUPS Schedulere[0m.
[e[0;32m  OK  e[0m] Listening on e[0;1;39mD-Bus System Message Bus Sockete[0m.
         Starting e[0;1;39mSocket activation for snappy daemone[0m...
[e[0;32m  OK  e[0m] Listening on e[0;1;39mSocket activation for snappy daemone[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSocket Unitse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mBasic Systeme[0m.
         Starting e[0;1;39mSave/Restore Sound Card Statee[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mD-Bus System Message Buse[0m.
         Starting e[0;1;39mNetwork Managere[0m...
         Starting e[0;1;39mClean up modules from old kernelse[0m...
         Starting e[0;1;39mAuthorization Managere[0m...
         Starting e[0;1;39mSnap Daemone[0m...
         Starting e[0;1;39mUser Login Managemente[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mSave/Restore Sound Card Statee[0m.
[e[0;32m  OK  e[0m] Finished e[0;1;39mClean up modules from old kernelse[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mSound Carde[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mNetwork Managere[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mNetworke[0m.
         Starting e[0;1;39mCUPS Schedulere[0m...
         Starting e[0;1;39mMySQL Servere[0m...
         Starting e[0;1;39mPermit User Sessionse[0m...
         Starting e[0;1;39mHostname Servicee[0m...
[e[0;32m  OK  e[0m] Finished e[0;1;39mPermit User Sessionse[0m.
         Starting e[0;1;39mGNOME Display Managere[0m...
         Starting e[0;1;39mHold until boot process finishes upe[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mGNOME Display Managere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mAuthorization Managere[0m.
         Starting e[0;1;39mModem Managere[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mHostname Servicee[0m.
         Starting e[0;1;39mNetwork Manager Script Dispatcher Servicee[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mNetwork Manager Script Dispatcher Servicee[0m.
         Starting e[0;1;39mBluetooth servicee[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mModem Managere[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mBluetooth servicee[0m.
[e[0;32m  OK  e[0m] Reached target e[0;1;39mBluetooth Supporte[0m.
------------ Sat Nov 20 03:19:39 IST 2021 ------------
Info: MKFS version
Info: FSCK version
Info: CKPT version = 562feeaa
[e[0;32m  OK  e[0m] Started e[0;1;39mSnap Daemone[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mMySQL Servere[0m.
------------ Sat Nov 20 03:24:49 IST 2021 ------------
Info: MKFS version
Info: FSCK version
Info: CKPT version = 562feed7
         Starting e[0;1;39mLoad/Save RF Kill Switch Statuse[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mLoad/Save RF Kill Switch Statuse[0m.
         Starting e[0;1;39mWPA supplicante[0m...
[e[0;32m  OK  e[0m] Started e[0;1;39mWPA supplicante[0m.
[e[0;32m  OK  e[0m] Started e[0;1;39mUser Login Managemente[0m.
------------ Sat Nov 20 03:36:21 IST 2021 ------------
Info: MKFS version
Info: FSCK version
Info: CKPT version = 562fef0c
------------ Sat Nov 20 03:46:05 IST 2021 ------------
Info: MKFS version
Info: FSCK version
Info: CKPT version = 562fefbc
The /dev/mapper/luks-b3eb71b7-9b8e-4fbd-8d09-02112522ec54 folder is present on my device.
Hi. One thought/question - how much RAM do you have & how big is your swap partition?
I hope you find a solution soon.
R.
