Issue with dual display
Ok so I’m fairly new to Manjaro but not linux itself. I’m a happy Debian/Ubuntu user who has decided to jump ship to Manjaro because it is so much snappier than any thing I’ve used (other than Pop_OS). So I recently tried Pop_OS and had this issue and assumed it was a PopOS issue until it started to show up in Manjaro.
I have two monitors connected to my Asus ROG RX 570 video card. One through HDMI and the other through DisplayPort (DP from now onwards). The issue I have is when I first installed Manjaro, I found myself stuck on a manjaro screen with a background but no DE in my HDMI monitor but no output on my DP monitor. I assumed it was hung somehow, used ALT-F3 to get to a login and then CTRL-ALT-DELed it till I could modify the boot options. I used “nomodeset” and that seemed to remediate the problem but I had both screens showing the same display (of course) but I got the prompts, and did my install.
Upon reboot, I got the same issue, with my HDMI monitor showing me a wallpaper and a mouse pointer but no other DE info like taskbar, etc. So after moving my mouse, I realized that my DP monitor (which physically sits on the right) was “VIRTUALLY” to the left of my HDMI monitor. However, my DP monitor was in power-saving mode with no display. After doing some forum research, I found the solution:
  1. Disconnect my DP monitor.
  2. Go to DISPLAY SETTINGS and have it ready.
  3. Reconnect my DP monitor.
  4. In DISPLAY SETTINGS, select my DP monitor and disable it. Click APPLY.
  5. In DISPLAY SETTINGS, select my DP monitor and enable it. Click APPLY.
Voila… it came to life!! Thank you to this forum.
TL;DR
Occasionally my DisplayPort monitor goes to black and never comes back till I repeat the above steps. Specifically, when I run LUTRIS (World of Tanks), it tends to go black and not return back. What am I changing or what is being overwritten that keeps me having to do this? I’m assuming this isn’t a strickly WINE issue just because I can only get this effect from Lutris (for now).
INXI output below:
System:    Host: Majaro Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=faa6c4f1-1ce2-4a10-bee9-38f7990483fc ro quiet apparmor=1
           Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x serial: <superuser required>
           UEFI: American Megatrends v: 5603 date: 07/28/2020
Memory:    RAM: total: 15.63 GiB used: 2.95 GiB (18.9%)
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU:       Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
           microcode: 800820D L2 cache: 3 MiB bogomips: 92428
           Speed: 1418 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz): 1: 1418 2: 2499 3: 1378 4: 1375 5: 1293
           6: 1377 7: 1377 8: 1376 9: 1521 10: 3384 11: 1291 12: 1375
           Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
           cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
           fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
           mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
           perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
           sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
           tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: ASUSTeK
           driver: amdgpu v: kernel bus ID: 0a:00.0 chip ID: 1002:67df class ID: 0300
           Device-2: Realtek FULL HD 1080P Webcam type: USB driver: uvcvideo bus ID: 5-2.3:10 chip ID: 0bda:5822
           class ID: 0e02 serial: 200901010001
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
           alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
           Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
           Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
           OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.1) v: 4.6 Mesa 20.3.4
           direct render: Yes
Audio:     Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
           bus ID: 06:00.0 chip ID: 1102:0012 class ID: 0403
           Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 0a:00.1 chip ID: 1002:aaf0 class ID: 0403
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 0c:00.3 chip ID: 1022:1457 class ID: 0403
           Device-4: Conexant Systems (Rockwell) LT2223Z type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-2.4:11
           chip ID: 0572:1415 class ID: 0300 serial: 000000000000
           Sound Server: ALSA v: k5.9.16-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: e000 bus ID: 08:00.0
           chip ID: 8086:1539 class ID: 0200
           IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: 60:45:cb:9b:39:6c
           IP v4: 192.168.2.23/24 type: dynamic noprefixroute scope: global broadcast: 192.168.2.255
           IP v6: fe80::1250:fb01:12b7:1043/64 type: noprefixroute scope: link
           WAN IP: 216.25.254.231
Bluetooth: Message: No Bluetooth data was found.
Logical:   Message: No LVM data was found.
RAID:      Message: No RAID data was found.
Drives:    Local Storage: total: 953.88 GiB used: 155.47 GiB (16.3%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS512G1X0C-00ENX0 size: 476.94 GiB block size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: 174459801474 rev: B35900WD
           temp: 50.9 C scheme: GPT
           ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SP900 size: 476.94 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s rotation: SSD serial: 2F4220022493 rev: 3b scheme: MBR
Partition: ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%) used: 155.47 GiB (33.2%) fs: ext4 dev: /dev/nvme0n1p2
           maj-min: 259:2 label: N/A uuid: faa6c4f1-1ce2-4a10-bee9-38f7990483fc
           ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
           maj-min: 259:1 label: N/A uuid: F189-8A3E
Swap:      Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 476.94 GiB fs: ntfs label: SATA512 uuid: AC9E86549E8616CC
USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
           Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
           Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
           Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
           Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
           Hub-6: 5-2:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 0424:2134
           class ID: 0900
           Hub-7: 5-2.2:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5411 class ID: 0900
           Device-1: 5-2.3:10 info: Realtek FULL HD 1080P Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 0bda:5822 class ID: 0e02 serial: 200901010001
           Device-2: 5-2.4:11 info: Conexant Systems (Rockwell) LT2223Z type: Audio,HID
           driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s chip ID: 0572:1415 class ID: 0300
           Device-3: 5-3:3 info: Razer USA DeathAdder Chroma type: Mouse,HID,Keyboard driver: hid-generic,usbhid interfaces: 3
           rev: 2.0 speed: 12 Mb/s chip ID: 1532:0043 class ID: 0301
           Device-4: 5-4:5 info: Microdia USB Keyboard type: Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
           speed: 1.5 Mb/s chip ID: 0c45:7603 class ID: 0301
           Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
           Hub-9: 6-2:2 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 0424:5534 class ID: 0900
           Hub-10: 6-2.2:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 0bda:0411 class ID: 0900
Sensors:   System Temperatures: cpu: 36.1 C mobo: N/A gpu: amdgpu temp: 32.0 C
Repos:     Packages: pacman: 1323 lib: 383 flatpak: 0
           1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
           2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
           3: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes: CPU top: 5 of 305
           1: cpu: 9.3% command: chromium pid: 3714 mem: 195.2 MiB (1.2%)
           2: cpu: 7.7% command: chromium pid: 4301 mem: 257.5 MiB (1.6%)
           3: cpu: 7.3% command: chromium pid: 4248 mem: 291.2 MiB (1.8%)
           4: cpu: 6.3% command: chromium pid: 3687 mem: 274.3 MiB (1.7%)
           5: cpu: 5.3% command: wgc.exe pid: 5720 mem: 277.6 MiB (1.7%)
           Memory top: 5 of 305
           1: mem: 333.4 MiB (2.0%) command: plasmashell pid: 1475 cpu: 0.9%
           2: mem: 291.2 MiB (1.8%) command: chromium pid: 4248 cpu: 7.3%
           3: mem: 277.6 MiB (1.7%) command: wgc.exe pid: 5720 cpu: 5.3%
           4: mem: 274.3 MiB (1.7%) command: chromium pid: 3687 cpu: 6.3%
           5: mem: 257.5 MiB (1.6%) command: chromium pid: 4301 cpu: 7.7%
Info:      Processes: 305 Uptime: 39m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0 Shell: Bash v: 5.1.0
           running in: yakuake inxi: 3.3.01
