Hello. I’m using Manjaro with KDE plasma and I try to run a Java program that runs in a web browser.
Here’s the program: https://github.com/thewca/tnoodle/releases/download/v1.2.2/TNoodle-WCA-1.2.2.jar
But there seems to be an issue with “BROWSE”. Here’s the output when I run the jar file:
Detected os: Linux
needsReExecing: false
Unable to get tray image size. Using fallback: 24
Successfully loaded
Please disable tooltips, as they are not consistent across all platforms and tray types.
TNoodle-WCA-1.2.2 started
Autoreload is disabled because the development mode is off.
Application started in 0.454 seconds.
Responding at http://0.0.0.0:2014
Sorry, it appears the Desktop api is supported on your platform, but the BROWSE action is not.
I see the program in the taskbar but it won’t open the browser. I also tried using an AUR package of the program and same problem.
There is a log file that gets created when I run the program. Here is its content:
2024-08-29 17:42:46,470 INFO [main] o.w.t.d.j.s.MainLauncher [MainLauncher.kt:43] Detected os: Linux
2024-08-29 17:42:46,474 INFO [main] o.w.t.d.j.s.MainLauncher [MainLauncher.kt:49] needsReExecing: false
2024-08-29 17:42:46,940 WARN [main] d.j.l.GtkTheme [GtkTheme.java:467] Unable to get tray image size. Using fallback: 24
2024-08-29 17:42:47,079 INFO [main] d.s.SystemTray [SystemTray.java:813] Successfully loaded
2024-08-29 17:42:47,085 WARN [main] d.s.SystemTray [MenuItem.java:465] Please disable tooltips, as they are not consistent across all platforms and tray types.
2024-08-29 17:42:47,116 INFO [main] o.w.t.d.j.WebscramblesServer [WebscramblesServer.kt:81] TNoodle-WCA-1.2.2 started
2024-08-29 17:42:47,225 INFO [main] Application [ApplicationEngineEnvironmentReloading.kt:161] Autoreload is disabled because the development mode is off.
2024-08-29 17:42:47,647 INFO [main] Application [BaseApplicationEngine.kt:65] Application started in 0.454 seconds.
2024-08-29 17:42:47,775 INFO [DefaultDispatcher-worker-1] Application [BaseApplicationEngine.kt:77] Responding at http://0.0.0.0:2014
2024-08-29 17:42:48,230 ERROR [main] o.w.t.d.j.s.OfflineJarUtils [OfflineJarUtils.kt:32] Sorry, it appears the Desktop api is supported on your platform, but the BROWSE action is not.
2024-08-29 17:44:52,492 ERROR [SystemTrayEventDispatch-1] o.w.t.d.j.s.OfflineJarUtils [OfflineJarUtils.kt:32] Sorry, it appears the Desktop api is supported on your platform, but the BROWSE action is not.
2024-08-29 17:44:55,849 INFO [SystemTrayEventDispatch-1] o.w.t.d.j.s.OfflineJarUtils [OfflineJarUtils.kt:57] Exit initiated from tray icon
I tried using both chrome and firefox as default browsers. The same issue happened. Can someone help me make this work?
