Removed from /etc/pacman.conf
[community]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
Run sudo pacman-mirrors --fasttrack && sudo pacman -Syyu and got these errors:
core 139.9 KiB 219 KiB/s 00:01 [----------------------] 100%
extra 8.3 MiB 2.86 MiB/s 00:03 [----------------------] 100%
multilib 140.0 KiB 532 KiB/s 00:00 [----------------------] 100%
warning: zsh-theme-powerlevel10k: local (1.20.0-4) is newer than extra (1.20.0-2)
resolving dependencies...
:: installing boost-libs (1.87.0-3) breaks dependency 'boost-libs=1.86.0' required by pokerth
Any idea how to fix it?
pokerth
is an AUR package, so you need to remove it before you update:
sudo pacman -R pokerth
After the update, you can then re-build pokerth
against the new boost
libraries:
pamac build pokerth
Just be aware of the pokerth package maintainer’s note from 2025-02-20:
For the moment, if you upgrade boost-libs and boost to 1.87.0, for pokerth to continue working you need to downgrade boost & boost-libs to version 1.86.0 and perhaps skip updating them until a fix is available
Info about AUR packages
AUR (Arch User Repository ) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
For help with AUR packages, please create a new topic in AUR and a helpful volunteer may be able to assist you.
I’ve moved the discussion to a new topic as outlined.
Users are responsible for maintaining their own AUR packages.
Hint: Make a list of what packages need to be rebuilt on what for the future. That’s how I learned.
system
Closed
9 March 2025 02:04
5
