cat /var/log/Xorg.0.log ✔
[ 51.854] (--) Log file renamed from "/var/log/Xorg.pid-584.log" to "/var/log/Xorg.0.log"
[ 51.984]
X.Org X Server 1.21.1.3
[ 51.984] Current Operating System: Linux Chette 5.15.41-1-MANJARO #1 SMP PREEMPT Wed May 18 09:20:01 UTC 2022 x86_64
[ 51.984] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=9748a88c-571c-4c2b-b74c-9b3649d57bc8 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 51.984]
[ 51.984] Current version of pixman: 0.40.0
[ 51.984] Before reporting problems, check http://wiki.x.org
[ 51.984] Markers: (--) probed, (**) from config file, (==) default setting,
[ 51.984] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 8 11:00:45 2022
[ 52.123] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 52.123] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 52.229] (==) No Layout section. Using the first Screen section.
[ 52.229] (==) No screen section available. Using defaults.
[ 52.229] (**) |-->Screen "Default Screen Section" (0)
[ 52.229] (**) | |-->Monitor "<default monitor>"
[ 52.229] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 52.229] (**) | |-->Device "Device0"
[ 52.229] (==) No monitor specified for screen "Default Screen Section".
[ 52.229] (==) Automatically adding devices
[ 52.229] (==) Automatically enabling devices
[ 52.229] (==) Automatically adding GPU devices
[ 52.229] (==) Automatically binding GPU devices
[ 52.229] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 52.400] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 52.400] Entry deleted from font path.
[ 52.400] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 52.400] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 52.400] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 52.400] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 52.400] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 52.400] (**) Extension "Composite" is enabled
[ 52.400] (**) Extension "RENDER" is enabled
[ 52.402] (II) The server relies on udev to provide the list of input devices.
[ 52.402] (II) Module ABI versions:
[ 52.402] X.Org ANSI C Emulation: 0.4
[ 52.402] X.Org Video Driver: 25.2
[ 52.402] X.Org XInput driver : 24.4
[ 52.402] X.Org Server Extension : 10.0
[ 52.403] (++) using VT number 1
[ 52.403] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 52.405] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 52.405] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 52.425] (--) PCI:*(0@0:2:0) 8086:0166:1043:1477 rev 9, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 52.425] (--) PCI: (1@0:0:0) 10de:0fdf:1043:1477 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 52.425] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 52.425] (II) LoadModule: "glx"
[ 52.453] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 52.641] (II) Module glx: vendor="X.Org Foundation"
[ 52.641] compiled for 1.21.1.3, module version = 1.0.0
[ 52.641] ABI class: X.Org Server Extension, version 10.0
[ 52.641] (II) LoadModule: "intel"
[ 52.708] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 52.813] (II) Module intel: vendor="X.Org Foundation"
[ 52.813] compiled for 1.21.1.1, module version = 2.99.917
[ 52.813] Module class: X.Org Video Driver
[ 52.813] ABI class: X.Org Video Driver, version 25.2
[ 52.813] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 52.814] (II) intel: Driver for Intel(R) HD Graphics
[ 52.814] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 52.814] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 52.815] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[ 52.815] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[ 52.842] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4000
[ 52.842] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx; using a maximum of 4 threads
[ 52.842] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 52.843] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 52.843] (==) intel(0): RGB weight 888
[ 52.843] (==) intel(0): Default visual is TrueColor
[ 52.843] (**) intel(0): Option "AccelMethod" "sna"
[ 52.843] (**) intel(0): Option "DRI" "true"
[ 52.843] (II) intel(0): Output LVDS1 has no monitor section
[ 52.844] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output LVDS1
[ 52.844] (II) intel(0): Enabled output LVDS1
[ 52.844] (II) intel(0): Output VGA1 has no monitor section
[ 52.844] (II) intel(0): Enabled output VGA1
[ 52.844] (II) intel(0): Output HDMI1 has no monitor section
[ 52.844] (II) intel(0): Enabled output HDMI1
[ 52.844] (II) intel(0): Output DP1 has no monitor section
[ 52.844] (II) intel(0): Enabled output DP1
[ 52.844] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 52.845] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 52.845] (II) intel(0): Enabled output VIRTUAL1
[ 52.845] (--) intel(0): Output LVDS1 using initial mode 1600x900 on pipe 0
[ 52.845] (==) intel(0): TearFree disabled
[ 52.845] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 52.845] (==) intel(0): DPI set to (96, 96)
[ 52.845] (II) Loading sub module "dri3"
[ 52.845] (II) LoadModule: "dri3"
[ 52.845] (II) Module "dri3" already built-in
[ 52.845] (II) Loading sub module "dri2"
[ 52.845] (II) LoadModule: "dri2"
[ 52.845] (II) Module "dri2" already built-in
[ 52.845] (II) Loading sub module "present"
[ 52.845] (II) LoadModule: "present"
[ 52.845] (II) Module "present" already built-in
[ 52.873] (II) intel(0): SNA initialized with Ivybridge (gen7, gt2) backend
[ 52.873] (==) intel(0): Backing store enabled
[ 52.873] (==) intel(0): Silken mouse enabled
[ 52.873] (II) intel(0): HW Cursor enabled
[ 52.874] (==) intel(0): DPMS enabled
[ 52.874] (==) intel(0): Display hotplug detection enabled
[ 52.874] (II) intel(0): [DRI2] Setup complete
[ 52.874] (II) intel(0): [DRI2] DRI driver: i965
[ 52.874] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 52.874] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 52.874] (II) intel(0): hardware support for Present enabled
[ 52.874] (II) Initializing extension Generic Event Extension
[ 52.874] (II) Initializing extension SHAPE
[ 52.874] (II) Initializing extension MIT-SHM
[ 52.874] (II) Initializing extension XInputExtension
[ 52.875] (II) Initializing extension XTEST
[ 52.875] (II) Initializing extension BIG-REQUESTS
[ 52.875] (II) Initializing extension SYNC
[ 52.875] (II) Initializing extension XKEYBOARD
[ 52.876] (II) Initializing extension XC-MISC
[ 52.876] (II) Initializing extension SECURITY
[ 52.876] (II) Initializing extension XFIXES
[ 52.876] (II) Initializing extension RENDER
[ 52.876] (II) Initializing extension RANDR
[ 52.876] (II) Initializing extension COMPOSITE
[ 52.876] (II) Initializing extension DAMAGE
[ 52.876] (II) Initializing extension MIT-SCREEN-SAVER
[ 52.876] (II) Initializing extension DOUBLE-BUFFER
[ 52.877] (II) Initializing extension RECORD
[ 52.877] (II) Initializing extension DPMS
[ 52.877] (II) Initializing extension Present
[ 52.877] (II) Initializing extension DRI3
[ 52.877] (II) Initializing extension X-Resource
[ 52.877] (II) Initializing extension XVideo
[ 52.877] (II) Initializing extension XVideo-MotionCompensation
[ 52.877] (II) Initializing extension GLX
[ 52.923] (EE) AIGLX error: dlopen of /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: cannot open shared object file: No such file or directory)
[ 52.923] (EE) AIGLX error: unable to load driver i965
[ 59.668] (II) IGLX: Loaded and initialized swrast
[ 59.668] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 59.668] (II) Initializing extension XFree86-VidModeExtension
[ 59.669] (II) Initializing extension XFree86-DGA
[ 59.669] (II) Initializing extension XFree86-DRI
[ 59.669] (II) Initializing extension DRI2
[ 59.740] (II) intel(0): switch to mode 1600x900@60.0 on LVDS1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 59.741] (II) intel(0): Setting screen physical size to 423 x 238
[ 60.171] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 60.171] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 60.171] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 60.171] (**) Power Button: Applying InputClass "system-keyboard"
[ 60.171] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 60.171] (II) LoadModule: "libinput"
[ 60.197] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 60.235] (II) Module libinput: vendor="X.Org Foundation"
[ 60.235] compiled for 1.21.1.3, module version = 1.2.1
[ 60.235] Module class: X.Org XInput Driver
[ 60.235] ABI class: X.Org XInput driver, version 24.4
[ 60.235] (II) Using input driver 'libinput' for 'Power Button'
[ 60.235] (**) Power Button: always reports core events
[ 60.235] (**) Option "Device" "/dev/input/event2"
[ 60.367] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 60.367] (II) event2 - Power Button: device is a keyboard
[ 60.367] (II) event2 - Power Button: device removed
[ 60.386] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 60.386] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 60.386] (**) Option "xkb_layout" "fr"
[ 60.386] (**) Option "xkb_variant" "azerty"
[ 60.386] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.443] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 60.443] (II) event2 - Power Button: device is a keyboard
[ 60.445] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event4)
[ 60.445] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 60.445] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 60.445] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[ 60.445] (**) Asus Wireless Radio Control: Applying InputClass "Keyboard Defaults"
[ 60.445] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[ 60.445] (**) Asus Wireless Radio Control: always reports core events
[ 60.445] (**) Option "Device" "/dev/input/event4"
[ 60.447] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 60.447] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 60.447] (II) event4 - Asus Wireless Radio Control: device removed
[ 60.496] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4001:00/input/input8/event4"
[ 60.496] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[ 60.496] (**) Option "xkb_layout" "fr"
[ 60.496] (**) Option "xkb_variant" "azerty"
[ 60.496] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.498] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 60.499] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 60.501] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 60.501] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 60.501] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 60.501] (**) Video Bus: Applying InputClass "system-keyboard"
[ 60.501] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 60.501] (II) Using input driver 'libinput' for 'Video Bus'
[ 60.501] (**) Video Bus: always reports core events
[ 60.501] (**) Option "Device" "/dev/input/event8"
[ 60.503] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 60.503] (II) event8 - Video Bus: device is a keyboard
[ 60.503] (II) event8 - Video Bus: device removed
[ 60.576] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16/event8"
[ 60.576] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 60.576] (**) Option "xkb_layout" "fr"
[ 60.576] (**) Option "xkb_variant" "azerty"
[ 60.576] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.579] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 60.579] (II) event8 - Video Bus: device is a keyboard
[ 60.581] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 60.581] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 60.581] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 60.581] (**) Video Bus: Applying InputClass "system-keyboard"
[ 60.581] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 60.581] (II) Using input driver 'libinput' for 'Video Bus'
[ 60.581] (**) Video Bus: always reports core events
[ 60.581] (**) Option "Device" "/dev/input/event7"
[ 60.583] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 60.584] (II) event7 - Video Bus: device is a keyboard
[ 60.584] (II) event7 - Video Bus: device removed
[ 60.656] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:02/LNXVIDEO:00/input/input15/event7"
[ 60.656] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
[ 60.656] (**) Option "xkb_layout" "fr"
[ 60.656] (**) Option "xkb_variant" "azerty"
[ 60.656] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.659] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 60.660] (II) event7 - Video Bus: device is a keyboard
[ 60.661] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 60.661] (II) No input driver specified, ignoring this device.
[ 60.661] (II) This device may have been added with another device file.
[ 60.662] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 60.662] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 60.662] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 60.662] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 60.662] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[ 60.662] (II) Using input driver 'libinput' for 'Sleep Button'
[ 60.662] (**) Sleep Button: always reports core events
[ 60.662] (**) Option "Device" "/dev/input/event1"
[ 60.664] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 60.664] (II) event1 - Sleep Button: device is a keyboard
[ 60.665] (II) event1 - Sleep Button: device removed
[ 60.696] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 60.696] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 60.696] (**) Option "xkb_layout" "fr"
[ 60.696] (**) Option "xkb_variant" "azerty"
[ 60.696] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.699] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 60.699] (II) event1 - Sleep Button: device is a keyboard
[ 60.702] (II) config/udev: Adding input device ASUS USB2.0 Webcam: ASUS USB2.0 (/dev/input/event10)
[ 60.702] (**) ASUS USB2.0 Webcam: ASUS USB2.0: Applying InputClass "evdev keyboard catchall"
[ 60.702] (**) ASUS USB2.0 Webcam: ASUS USB2.0: Applying InputClass "libinput keyboard catchall"
[ 60.702] (**) ASUS USB2.0 Webcam: ASUS USB2.0: Applying InputClass "system-keyboard"
[ 60.702] (**) ASUS USB2.0 Webcam: ASUS USB2.0: Applying InputClass "Keyboard Defaults"
[ 60.702] (II) Using input driver 'libinput' for 'ASUS USB2.0 Webcam: ASUS USB2.0'
[ 60.702] (**) ASUS USB2.0 Webcam: ASUS USB2.0: always reports core events
[ 60.702] (**) Option "Device" "/dev/input/event10"
[ 60.705] (II) event10 - ASUS USB2.0 Webcam: ASUS USB2.0: is tagged by udev as: Keyboard
[ 60.705] (II) event10 - ASUS USB2.0 Webcam: ASUS USB2.0: device is a keyboard
[ 60.705] (II) event10 - ASUS USB2.0 Webcam: ASUS USB2.0: device removed
[ 60.776] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input17/event10"
[ 60.776] (II) XINPUT: Adding extended input device "ASUS USB2.0 Webcam: ASUS USB2.0" (type: KEYBOARD, id 11)
[ 60.776] (**) Option "xkb_layout" "fr"
[ 60.776] (**) Option "xkb_variant" "azerty"
[ 60.776] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.780] (II) event10 - ASUS USB2.0 Webcam: ASUS USB2.0: is tagged by udev as: Keyboard
[ 60.780] (II) event10 - ASUS USB2.0 Webcam: ASUS USB2.0: device is a keyboard
[ 60.782] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 60.782] (II) No input driver specified, ignoring this device.
[ 60.782] (II) This device may have been added with another device file.
[ 60.783] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event12)
[ 60.783] (II) No input driver specified, ignoring this device.
[ 60.783] (II) This device may have been added with another device file.
[ 60.783] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 60.784] (II) No input driver specified, ignoring this device.
[ 60.784] (II) This device may have been added with another device file.
[ 60.784] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event6)
[ 60.785] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 60.785] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 60.785] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[ 60.785] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 60.785] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[ 60.785] (**) Asus WMI hotkeys: always reports core events
[ 60.785] (**) Option "Device" "/dev/input/event6"
[ 60.786] (II) event6 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 60.786] (II) event6 - Asus WMI hotkeys: device is a keyboard
[ 60.787] (II) event6 - Asus WMI hotkeys: device removed
[ 60.842] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input14/event6"
[ 60.842] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 12)
[ 60.843] (**) Option "xkb_layout" "fr"
[ 60.843] (**) Option "xkb_variant" "azerty"
[ 60.843] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.845] (II) event6 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 60.845] (II) event6 - Asus WMI hotkeys: device is a keyboard
[ 60.847] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 60.847] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 60.847] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 60.847] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 60.847] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[ 60.847] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 60.847] (**) AT Translated Set 2 keyboard: always reports core events
[ 60.847] (**) Option "Device" "/dev/input/event3"
[ 60.849] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 60.849] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 60.851] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 60.883] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 60.883] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 60.883] (**) Option "xkb_layout" "fr"
[ 60.883] (**) Option "xkb_variant" "azerty"
[ 60.883] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 60.886] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 60.886] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 60.889] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event9)
[ 60.889] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 60.889] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 60.889] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 60.889] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 60.889] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 60.889] (**) Option "Device" "/dev/input/event9"
[ 60.891] (II) event9 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 60.895] (II) event9 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 60.895] (II) event9 - ETPS/2 Elantech Touchpad: device removed
[ 60.949] (**) Option "Tapping" "on"
[ 60.950] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input13/event9"
[ 60.950] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 14)
[ 60.953] (**) Option "AccelerationScheme" "none"
[ 60.953] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 60.953] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 60.953] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 60.956] (II) event9 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 60.959] (II) event9 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 60.961] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 60.961] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 60.961] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 60.961] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 60.961] (**) Option "Device" "/dev/input/mouse0"
[ 61.016] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 61.016] (EE) libinput: ETPS/2 Elantech Touchpad: Failed to create a device for /dev/input/mouse0
[ 61.016] (EE) PreInit returned 2 for "ETPS/2 Elantech Touchpad"
[ 61.016] (II) UnloadModule: "libinput"
[ 61.017] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 61.017] (II) No input driver specified, ignoring this device.
[ 61.017] (II) This device may have been added with another device file.
[ 61.046] (II) intel(0): EDID vendor "AUO", prod id 4766
[ 61.046] (II) intel(0): Printing DDC gathered Modelines:
[ 61.047] (II) intel(0): Modeline "1600x900"x0.0 97.55 1600 1648 1680 1754 900 903 909 926 -hsync -vsync (55.6 kHz eP)
[ 667.156] (EE) event9 - ETPS/2 Elantech Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.20.1/touchpad-jumping-cursors.html for details
