Trying to run FreeCAD (link-stable by RealThunder) from an AppImage, getting this:
~ ./FreeCAD-Link-Stable-Linux-x86_64-py3.11-20240123.AppImage ✔
/tmp/.mount_FreeCAO8QJnN
FreeCAD 0.21.0, Libs: 2024.123.0R14555 (Git shallow)
Could not find the Qt platform plugin "wayland" in ""
MESA-LOADER: failed to open radeonsi: /usr/lib/dri/radeonsi_dri.so: undefined symbol: amdgpu_va_get_start_addr (search paths /usr/lib/dri, suffix _dri)
failed to load driver: radeonsi
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: undefined symbol: amdgpu_va_get_start_addr (search paths /usr/lib/dri, suffix _dri)
failed to load driver: swrast
WebEngineContext used before QtWebEngine::initialize() or OpenGL context creation failed.
QGLXContext: Failed to create dummy context
Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags<QSurfaceFormat::FormatOption>(), depthBufferSize 24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples 0, swapBehavior QSurfaceFormat::DefaultSwapBehavior, swapInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::NoProfile)
/tmp/.mount_FreeCAO8QJnN/AppRun: line 52: 4210 Aborted (core dumped) "./$name" "$@"
~ IOT ✘
Olli
10 March 2024 08:30
2
post the output of
inxi -v8zy
first. the error messages indicate some missing mesa-modules.
~ inxi -v8zy IOT ✘ 9s
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=1d88e134-16a4-4219-ad4d-c6ad41de3637 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland tools: avail: light-locker vt: 1 dm: 1: LightDM
v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F6 date: 08/23/2021
System RAM: total: 32 GiB available: 31.22 GiB used: 14.86 GiB (47.6%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: no module installed
Device-2: Controller0-ChannelA-DIMM1 type: DDR4 detail: synchronous
size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: G Skill Intl
part-no: F4-3600C18-16GVK serial: N/A
Device-3: Controller0-ChannelB-DIMM0 type: no module installed
Device-4: Controller0-ChannelB-DIMM1 type: DDR4 detail: synchronous
Info: model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x5D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 4617 high: 4700 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4700 2: 4600 3: 4634
4: 4605 5: 4606 6: 4669 7: 4612 8: 4601 9: 4606 10: 4601 11: 4598 12: 4601
13: 4628 14: 4612 15: 4609 16: 4600 bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Tul / PowerColor
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0 chip-ID: 1002:73ff
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-3 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 16.0.6 DRM 3.57 6.7.7-1-MANJARO) device-ID: 1002:73ff memory: 7.81 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:73ff surfaces: xcb,xlib,wayland
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: Corsair VOID ELITE Wireless Gaming Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-11.3.4.4:14 chip-ID: 1b1c:0a51 class-ID: 0300
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 10.01 TiB used: 3.55 TiB (35.5%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731030WD temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD40EZRZ-22GXCB0
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD60EZRZ-00GZ5B1 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5700 serial: <filter> fw-rev: 4004 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE WH16NS40 rev: 1.05
dev-links: cdrom
ID-1: / raw-size: 72.55 GiB size: 70.86 GiB (97.67%) used: 59.89 GiB (84.5%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: manjaro
uuid: 1d88e134-16a4-4219-ad4d-c6ad41de3637
ID-2: /boot/efi raw-size: 512.2 MiB size: 511.2 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
label: MANJARO-EFI uuid: 5D43-E744
ID-3: /home raw-size: 110.12 GiB size: 107.84 GiB (97.92%)
used: 91.51 GiB (84.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: Home uuid: 55b7906c-f1ec-4c39-9768-2faf19a9af19
ID-4: /mnt/HomeBackLinux raw-size: 178.09 GiB size: 174.73 GiB (98.11%)
used: 118.98 GiB (68.1%) fs: ext4 dev: /dev/sdb5 maj-min: 8:21
label: Home Back Linux uuid: 876f27ea-c6f8-40e1-a2cf-64629911c3cf
ID-5: /mnt/LinuxGames raw-size: 746.82 GiB size: 734.03 GiB (98.29%)
used: 397.95 GiB (54.2%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
label: Linux Games uuid: 16551719-993b-4992-a8a8-23cc5155ce75
ID-6: /mnt/Plex raw-size: 1014.46 GiB size: 1014.46 GiB (100.00%)
used: 778.04 GiB (76.7%) fs: ntfs dev: /dev/sda4 maj-min: 8:4 label: Plex
uuid: 0CF903020CF90302
ID-7: /mnt/SSD Games raw-size: 424.58 GiB size: 424.58 GiB (100.00%)
used: 412.43 GiB (97.1%) fs: ntfs dev: /dev/nvme0n1p7 maj-min: 259:7
label: SSD Games uuid: 084E1526084E1526
ID-8: /mnt/Software and Games raw-size: 1.3 TiB size: 1.3 TiB (100.00%)
used: 1.24 TiB (95.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2
label: Software and Games uuid: 78DEF03EDEEFF1F4
ID-9: /mnt/SteamMusic raw-size: 101.73 GiB size: 101.73 GiB (100.00%)
used: 13.22 GiB (13.0%) fs: ntfs dev: /dev/sda5 maj-min: 8:5
label: SteamMusic uuid: 0D1C13C90D1C13C9
ID-10: /run/media/jeremiah/User Files raw-size: 478.64 GiB
size: 478.64 GiB (100.00%) used: 320.1 GiB (66.9%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: User Files uuid: 080E0EA5080E0EA5
ID-11: /run/timeshift/12114/backup raw-size: 173.15 GiB
size: 169.87 GiB (98.11%) used: 169.52 GiB (99.8%) fs: ext4 dev: /dev/sdb4
maj-min: 8:20 label: System Back Linx
uuid: b9ef7b00-101b-4bb1-81e2-ff1ae5106443
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 600 MiB fs: vfat label: N/A
uuid: 0D5E-1D28
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 322.61 GiB fs: ntfs label: N/A
uuid: 08E64F84E64F714C
ID-3: /dev/nvme0n1p6 maj-min: 259:6 size: 580 MiB fs: ntfs label: N/A
uuid: 8072802F72802C4A
ID-4: /dev/sda1 maj-min: 8:1 size: 48.83 GiB fs: ntfs label: Swap
uuid: 10421BE610421BE6
ID-5: /dev/sdb1 maj-min: 8:17 size: 3.66 TiB fs: ntfs label: Main PC Backup
uuid: 08000F1708000F17
ID-6: /dev/sdb2 maj-min: 8:18 size: 1.36 TiB fs: ntfs label: System Backup
uuid: 0FD214480FD21448
ID-7: /dev/sdb3 maj-min: 8:19 size: 100.66 GiB fs: ntfs
label: Other Backups uuid: 1098050410980504
Device-1: 1-5:2 info: Razer USA BlackWidow (2019) type: keyboard,mouse
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0241 class-ID: 0300
Hub-2: 1-11:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11.1:5 info: Logitech M-R0017 [G700s Rechargeable Gaming Mouse]
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
chip-ID: 046d:c07c class-ID: 0300 serial: <filter>
Hub-3: 1-11.3:8 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11.3.1:10 info: Logitech C-U0007 [Unifying Receiver]
type: mouse,HID driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c531 class-ID: 0300
Hub-4: 1-11.3.3:11 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-5: 1-11.3.4:12 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-11.3.4.3:13 info: Saitek PLC X52 Flight Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 06a3:075c class-ID: 0300
Device-2: 1-11.3.4.4:14 info: Corsair VOID ELITE Wireless Gaming Dongle
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-6: 1-12:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-12.3:7 info: Corsair RM750i Power Supply type: HID
driver: corsair-psu,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1b1c:1c0b class-ID: 0300
Device-2: 1-13:6 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-3: 1-14:9 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-7: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Device-1: 2-5:2 info: Western Digital My Book 25EE type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 8mA chip-ID: 1058:25ee class-ID: 0806
serial: <filter>
System Temperatures: cpu: 31.0 C mobo: 25.0 C gpu: amdgpu temp: 30.0 C
mem: 24.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 2131 pm: pacman pkgs: 2072 libs: 528 tools: pamac pm: flatpak
pkgs: 42 pm: snap pkgs: 17
1: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
2: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
3: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
4: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
5: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
7: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
9: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
10: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
12: https://manjaro.ynh.ovh/stable/$repo/$arch
13: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
14: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
15: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
16: https://mirror.dc.uz/manjaro/stable/$repo/$arch
17: https://mirror.easyname.at/manjaro/stable/$repo/$arch
18: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
19: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
21: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
22: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
24: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
25: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
26: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
27: https://mirror.23m.com/manjaro/stable/$repo/$arch
28: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
29: http://mirror.fcix.net/manjaro/stable/$repo/$arch
30: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
31: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
32: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
33: https://mirror.init7.net/manjaro/stable/$repo/$arch
34: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
35: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
36: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
37: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
39: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
40: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
41: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
42: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
43: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
44: https://linorg.usp.br/manjaro/stable/$repo/$arch
45: https://manjaro.kyberorg.fi/stable/$repo/$arch
46: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
47: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
49: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
50: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
51: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
52: https://muug.ca/mirror/manjaro/stable/$repo/$arch
53: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
54: https://manjaro.kurdy.org/stable/$repo/$arch
55: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
56: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
57: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
58: https://mirrors2.manjaro.org/stable/$repo/$arch
59: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
60: https://mirrors.netix.net/manjaro/stable/$repo/$arch
61: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
62: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
63: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
64: http://manjaro.grena.ge/stable/$repo/$arch
65: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
66: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
68: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
69: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
70: https://repos.silknet.com/manjaro/stable/$repo/$arch
71: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
72: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
73: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
74: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
75: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
76: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
77: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
78: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
79: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
80: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
81: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
82: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
83: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
84: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
85: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
86: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
88: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
90: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
91: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
92: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
93: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
94: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
95: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
96: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
99: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
100: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
101: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
102: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
103: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
104: https://mirror.koddos.net/manjaro/stable/$repo/$arch
105: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
106: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
107: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
108: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
109: https://mirror.funami.tech/manjaro/stable/$repo/$arch
110: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
111: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
112: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
113: https://mirror.zetup.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 578
1: cpu: 14.2% command: firefox pid: 4512 mem: 1432.0 MiB (4.4%)
2: cpu: 7.0% command: firefox pid: 17734 mem: 226.5 MiB (0.7%)
3: cpu: 3.5% command: firefox pid: 5899 mem: 346.4 MiB (1.0%)
4: cpu: 2.4% command: pamac-manager pid: 16754 mem: 1059.3 MiB (3.3%)
5: cpu: 1.7% command: rsync pid: 16574 mem: 47.1 MiB (0.1%)
Memory top: 5 of 578
1: mem: 1432.0 MiB (4.4%) command: firefox pid: 4512 cpu: 14.2%
2: mem: 1059.3 MiB (3.3%) command: pamac-manager pid: 16754 cpu: 2.4%
3: mem: 785.8 MiB (2.4%) command: firefox pid: 4823 cpu: 0.4%
4: mem: 769.6 MiB (2.4%) command: plasma-discover pid: 8146 cpu: 0.1%
5: mem: 493.9 MiB (1.5%) command: plasmashell pid: 2117 cpu: 0.0%
Processes: 578 Power: uptime: 8h 3m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Olli
10 March 2024 12:26
4
there are 2 things that you can check. first, there are non-free mesa drivers for amd, check the forum how to install them. second, these error messages indicate problems with qt-development system what imho does work more reliable with x11 instead of wayland. you can choose between these 2 at the login-screen (left-bottom-corner). there is a menu to switch between them. it#s worth to give it a try and use x11.
Trying X11 didn’t work. Will have to figure out mesa when I get some time later today.
I have no idea how these things work
I think this started with the most recent update, this very version of FreeCAD worked before on this system.
The version of FreeCAD that comes from the package manager works fine, but I very much prefer the RealThunder branch.
Olli
10 March 2024 13:21
6
i don’t know from what version to what you’ve updated but there are problems (i think licencing-issues) why there is a “mesa-non-free” discussion. ask the forum for help in this direction “mesa-non-free”.
cscs
10 March 2024 22:04
7
I dont know if that will fix it.
I didnt try a whole lot … but here where I have acceleration codecs etc (and on plasma 6 wayland)
$ ./FreeCAD-Link-Stable-Linux-x86_64-py3.11-20240123.AppImage
/tmp/.mount_FreeCA6AU3jY
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: undefined symbol: amdgpu_va_get_start_addr (search paths /usr/lib/dri, suffix _dri)
2.869715 <asm3.main> init_gui.py(14): no solver backend found
/tmp/.mount_FreeCA6AU3jY/AppRun: line 52: 86267 Aborted (core dumped) "./$name" "$@"
maybe not that helpful but do with that what you will.
Tracked the problem down. There’s some libdrm stuff that doesn’t play nicely, as documented in an issue on its own github . Repacking the appimage worked.
system
Closed
12 March 2024 13:07
9
