Issue: My Manjaro Mirror not public
Hello
I have created Manjaro mirror my url address is repo. inara. pk (Ignore spaces)
i have made it to update every 24h. But the issue i am facing is that my mirror is not appearing in software update section when i search for it…
How will i make my mirror public, so that i can use it for updates
The mirrorlist is manually maintained by the manjaro team. If you want your mirror to appear on that list you’d need to contact the team.
Pinging @philm
Url: Index of /manjaro/
Create a custom-mirrors.json file
sudo nano /var/lib/pacman-mirrors/custom-mirrors.json
Add the following content
        "country": "Pakistan",
        "url": "https://repo.inara.pk/manjaro/",
        "protocols": [
            "https"
thanks for mirror
And you can open ticket
can you give me email address of the concerned team?
