I did a fresh install of Manjaro today.
I installed VirtualBox following the Wiki:
sudo pacman -Syu virtualbox linux54-virtualbox-host-modules
When I got to
sudo vboxreload
I got
Unloading modules:
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/5.9.16-1-MANJARO
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/5.9.16-1-MANJARO
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.9.16-1-MANJARO
After a reboot I still got the same error.
System info:
inxi -F
Host: shmuel-manjaro-xfce Kernel: 5.9.16-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/10/2019
Info: 8-Core model: Intel Core i7-9700 bits: 64 type: MCP L2 cache: 12 MiB
Speed: 4508 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4508 2: 4442
3: 4511 4: 4439 5: 4498 6: 4510 7: 4597 8: 4597
Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
Device-2: IMC Networks XHC Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server: ALSA v: k5.9.16-1-MANJARO
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
driver: btusb
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 2.26 TiB used: 621.29 GiB (26.9%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 64.81 GiB used: 15.67 GiB (24.2%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 96 MiB used: 39.2 MiB (40.9%) fs: vfat
dev: /dev/sda2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 271 Uptime: 4m Memory: 15.5 GiB used: 2.47 GiB (15.9%)
Shell: Bash inxi: 3.3.00
