So I have been following instructions to install the wifi stick, since it does not automatically set itself up, but I am getting a weird problem that I did not get on Debian/Ubuntu distros.
The results I am getting are:
sudo git clone "(github)/RinCat/RTL88x2BU-Linux-Driver.git" /usr/src/rtl88x2bu-git ✔
fatal: destination path '/usr/src/rtl88x2bu-git' already exists and is not an empty directory.
~ sudo sed -i 's/PACKAGE_VERSION="@PKGVER@"/PACKAGE_VERSION="git"/g' /usr/src/rtl88x2bu-git/dkms.conf 128 ✘
~ sudo dkms add -m rtl88x2bu -v git ✔
Error! DKMS tree already contains: rtl88x2bu-git
You cannot add the same module/version combo more than once.
~ sudo dkms autoinstall 3 ✘
Error! Your kernel headers for kernel 5.15.16-1-MANJARO cannot be found at /usr/lib/modules/5.15.16-1-MANJARO/build or /usr/lib/modules/5.15.16-1-MANJARO/source.
Please install the linux-headers-5.15.16-1-MANJARO package or use the --kernelsourcedir option to tell DKMS where it's located.
I am not sure how to fix the kernel issue. The driver link/instructions is at:
(cudy)/wu1300_software_download
Is the no link thing temporary or permanent?
