Issue during build image process after manjaro-arm-tools update
Hi,
I tried to build arm image today (08/14) issue during the build process
manjaro-arm-tools update yesterday (08/13) => Slowdown in Manjaro ARM development? - #16 by nl.smart
No issue during the build process before the manjaro-arm-tools update (08/13), no issue during the build process with the last arm images I built the 08/12
qemu-user-static-binfmt is already installed…
[nls@lap ~]$ sudo buildarmimg -d oc4 -e kde-plasma -v 2024.08.14 -b unstable n
ERROR: This utility requires package 'qemu-user-static-binfmt'\n
[nls@lap ~]$ sudo pacman -S qemu-user-static-binfmt
warning: qemu-user-static-binfmt-9.0.2-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) qemu-user-static-binfmt-9.0.2-1
Total Installed Size:  0,05 MiB
Net Upgrade Size:      0,00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring        [########################################################] 100%
(1/1) checking package integrity                                                               [########################################################] 100%
(1/1) loading package files        [########################################################] 100%
(1/1) checking for file conflicts                                                              [########################################################] 100%
(1/1) checking available disk space                                                            [########################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling qemu-user-static-binfmt                                                     [########################################################] 100%
(1/3) Registering binary formats...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
[nls@lap ~]$
Thanks for your help. I build manjaro arm images for years, first time I encounter this issue.
This is on x86_64 system?
As the qemu was made an optional dependency I created a check that only trigger if
  • host is x86_64
  • and qemu-aarch64-static not present
I am sure I checked the condition without the binary installed - but alas it is flawed - my mistake somehow.
I can see I goofed it somehow.
Edit the file /usr/share/manjaro-arm-tools/lib/functions.sh and replace lines 199-201 with
if [[ $(uname -m) == "x86_64" ]] && [[ $(command -v qemu-aarch64-static)x == "x" ]]; then
    echo "ERROR: This utility requires package 'qemu-user-static-binfmt'"
    exit 1
fi
Yes. I had the same issue on GitHub Actions runners (x86_64). The new logic is not working as it should.
I just realized that the =~ returns true because the qemu-aarch64-static is mentioned in the result even when it does not exist.
I think that you can use ! which qemu-aarch64-static > /dev/null as it will return -1 when executable is not found
Something like [[ $(uname -m) == "x86_64" ]] && ! which qemu-aarch64-static > /dev/null && { echo -e "ERROR: This utility requires package 'qemu-user-static-binfmt'\n"; exit 1; } might work…
I don’t why - but I have mistakenly use uname -r instead of uname -m - a stupid keyboard error
This one works as I intended - my apoligies for the inconvenience
    exit 1
fi
My test (test.sh)
Move binary
 $ sudo mv /usr/bin/qemu-aarch64-static /usr/bin/qemu-aarch64-static.bak
run script snippet (generate error message)
 $ bash test.sh
move binary back
 $ sudo mv /usr/bin/qemu-aarch64-static.bak /usr/bin/qemu-aarch64-static
run test script again (no output) - binary exist
 $ bash test.sh
Thanks for your reply.
Yes, I build manjaro arm images with x86_64 system
Edit 1 : I replace the lines 199-201, now the build image is running, I hope a nice image in the end of the process.
Edit 2 : the build image finished graceful, image not tested…
==> Creating kde-plasma edition image for oc4...
  -> Creating ext4 partitions...
  -> Copying files to image...
  -> Writing the boot loader images...
Boot PARTUUID is ca6b25a3-01...
Root PARTUUID is ca6b25a3-02...
Root UUID is 9f096697-9e5b-4ec7-852e-aafd5547ffaa...
  -> Cleaning up image...
  -> Compressing Manjaro-ARM-kde-plasma-oc4-2024.08.14.img with xz...
Manjaro-ARM-kde-plasma-oc4-2024.08.14.img: 1 709,0 MiB / 9 163,0 MiB = 0,187, 15 MiB/s, 10:03
  -> Removing rootfs_aarch64...
==> Time elapsed: 33.90 minute(s)
[nls@lap ~]$
