After the last Update, the Issue of my Nvidia 970 dGPU losing the Display Signal returned when playing Games.
Civ:Beyond Earth: Rising Tide works fine on Windows. But I’m thinking that something is wrong with the Driver itself.
In any case I have Replacement Fans on the way and that might fix the Problem.
Is anything relevant in the journal (journalctl -b0
)? Alternatively, start journalctl -f
in a terminal, then run the game, and after the problem occurs, check if it printed anything relevant. In any case, post the output of inxi -Gazy
journalctl -b0
will open a pager with the journal since the last boot. You should use the timestamps in the left column to find the entries which were saved when the issue occurred and see if any of them are relevant. (You may specify -b-1
, -b-2
, etc. to get the journal for previous boots.)
Nevermind I replace the Fans on the Card and that fixed the Issue.
