So I have been building my custom Cinnamon ISO for months in my Virt-Manager enviroment and never had any issues. then last week I get the following error:
--> Restoring [/home/delinuxco/packages/pkgbuild/buildiso/cinnamon/x86_64/rootfs/etc/pacman.conf] ...
-> Configuring lsb-release
-> Cleaning [rootfs]
==> Done [Base installation] (rootfs)
--> Loading Packages: [Packages-Desktop] ...
==> Prepare [Desktop installation] (desktopfs)
--> overlayfs mount: [/home/delinuxco/packages/pkgbuild/buildiso/cinnamon/x86_64/desktopfs]
mount: /home/delinuxco/packages/pkgbuild/buildiso/cinnamon/x86_64/desktopfs: mount(2) system call failed: Stale file handle.
==> ERROR: A failure occurred in make_image_desktop().
Aborting...
delinuxco-vm/delinuxco ~/
For some reason it can’t mount desktopfs, system call failed: stale file handle.
I have tried switching kernels, I have updated and rebooted both Host and guest os’ to no avail! THis one has me stumped…
Here is my enviroment:
delinuxco-vm delinuxco ~ buildiso -f -p cinnamon -b stable -fqv
[sudo] password for delinuxco:
==> manjaro-tools
-> version: 0.15.10
-> config: ~/.config/manjaro-tools/manjaro-tools.conf
==> PROFILE:
-> gitlab branch: master
-> build_lists: community|default|manjaro
-> build_list_iso: cinnamon
-> is_build_list: false
==> OPTIONS:
-> arch: x86_64
-> branch: stable
-> kernel: linux59
==> ARGS:
-> clean_first: true
-> images_only: false
-> iso_only: false
-> persist: false
-> extra: true
-> permalink: false
-> office_installer:
==> DIST SETTINGS:
-> dist_name: Manjaro
-> dist_release: 20.1.2
-> dist_codename: Mikah
==> ISO INFO:
-> iso_compression: zstd
==> BUILD QUEUE:
–> Profile: [cinnamon]
-> iso_file: manjaro-cinnamon-20.1.2-201023-linux59.iso
-> iso_label: MANJARO_CINNAMON_2012
-> autologin: true
-> nonfree_mhwd: true
-> multilib: true
-> extra: true
-> office_installer: false
-> permalink: false
-> netinstall: false
-> chrootcfg: false
-> geoip: true
-> oem_used: false
-> efi_boot_loader: grub
-> custom_boot_args:
-> hostname: delinuxco
-> username: manjaro
-> password: manjaro
-> login_shell: /bin/bash
-> addgroups: lp,network,power,sys,wheel
-> enable_systemd: avahi-daemon bluetooth cronie ModemManager NetworkManager org.cups.cupsd tlp tlp-sleep haveged ufw apparmor lightdm
-> enable_systemd_live: manjaro-live mhwd-live pacman-init mirrors-live
-> disable_systemd: pacman-init
-> strict_snaps:
-> classic_snaps:
-> snap_channel: stable
