i’m seeing shadow.service loaded failed failed Verify integrity of password and group files and i think the problem is user ‘ice’: directory ‘/var/lib/ice’ does not exist …
$ journalctl -b -u shadow.service --no-hostname --no-pager
Aug 31 06:34:41 systemd[1]: Started Verify integrity of password and group files.
Aug 31 06:34:42 sh[740]: user 'ice': directory '/var/lib/ice' does not exist
Aug 31 06:34:42 sh[740]: pwck: no changes
Aug 31 06:34:42 systemd[1]: shadow.service: Main process exited, code=exited, status=1/FAILURE
Aug 31 06:34:42 systemd[1]: shadow.service: Failed with result 'exit-code'.
i get the impression zeroc-ice is a default/system package - is that true?
i may have dumped /var/lib/ice thinking it was a leftover from a mumble package i removed
Answering your question in the title of this thread, zeroc-ice is indeed a package from the official repository, but I do not have it installed on my system, so it’s not part of the default install.
i installed zeroc-ice to see what would happen and the shadow.service error disappeared, so then i removed the package to see if the error would reappear - it did not, so all is well
BTW there is a nice script that compares the default package list with the currently installed packages and tells you what is missing - MAnjaro PAcket REstore - MAPARE
