Is virtualbox 6.1.34 not supported on stable branch kernels?
Virtualbox 6.1.34 on Manjaro KDE, Kernel: 5.15.55-1-MANJARO
Issue: Frequent crashes, graphical glitches/black screen on guest OS.
Found out that virtualbox 6.1.36 supports Linux kernels 5.18, 5.17.12+, 5.15.44+, 5.10.119+
Are there any workarounds? or waiting for 6.1.36 to land in stable my only option, if i don’t want to switch to testing on my main workstation?
Try using an older kernel…should do it…maybe
Virtualbox 6.1.34 had issues - there’s a long tread on the subject - if you had bother to search before asking.
Virtualbox 6.1.36 is in testing and unstable.
Updating your kernel to 5.18 is likely to remedy your issue.
