i am using video-hybrid-intel-nvidia-prime driver installed through mhwd.
I noticed that it has version 2023.03.23, so i wonder if that driver is just really outdated, or if there is another driver that supports hybrid graphics and is more up2date.
Reason why i am concerned is, that this driver does not support cuda 12.5 and newer, so I am stuck with an older cuda version in my workflow.
Is just the version of the mhwd database.
The version of the nvidia driver for example is from the nvidia package you have installed.
Something like linux610-nvidia, which on Unstable is 555.58.02-6, and on Stable is 550.100-2.
You can also see that there are newer drivers available, but as with all packages, the version available is different depending on which branch you use.
What do you mean?
The cuda package in all branches is currently 12.5.1-1.
But if you need guidance on software availability, branches, and/or switching between them:
