hello
when i’ve been on ubuntu it worked as a plug and play.
on manjaro i’ve tried to add the printer but it didn’t printed a test page.
i’ve tried to find solutions but there are many options and i don’t know what exactly is needed and if it may be pretty complicated to use the solution…
can you assist a bit in telling me what do i need?
i’ve tried the link that you sent here. but when typing pamac build hplip-plugin
in the terminal i got…
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Error: target not found: hplip-plugin
