I’m currently using manjaro xfce on a thinkpad t480.
I don’t have any dedicated media controll keys.
Can i make a shortcut for it? Fg: super+p to pause music?
You’ll have to set it up per-application…
I would only need it for firefox and spotify.
Can i do that?
I don’t have Xfce, or Spotify. And I don’t use any sound in Firefox. Or even the rest of my PC, for that matter. So, while I’m sure it’s doable, unfortunately I won’t be able to help you.
Edit:
Thanks for your time!
These are some commands I use in my i3 config and they will work perfectly fine in xfce. Go to Settings > Keyboard > Shortcuts > Add > Add command and then the keybinding. Use these commands to:
pactl set-sink-volume 0 +5% #increase sound volume
pactl set-sink-volume 0 -5% #decrease sound volume
pactl set-sink-mute 0 toggle # toggle sound
playerctl play-pause #toggle to play/pause
playerctl next #next song/video
playerctl previous #previous song/video
pactl
is used to issue control commands to the PulseAudio sound server. Install playerctl
though:
sudo pacman -S playerctl
(I am not sure if this will work if you are using pipewire
but this will work if you are using just pulseaudio
and even both. Check with inxi -A
Man!
I love you!
This is what i was looking for.
Thank you so much.
