I have just instal manjaro cinnamon which base on btrfs. but It doesn’t has btrfs snap like the newest manjaro gnome. Is there any way to config btrfs snap for manjaro cinnamon like manjaro gnome 21.1.2
sudo pacman -S snapper snapper-gui
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
